2007 GT
EMAY
Hey I'm going to get a procharger and I'd like to find out some info..numbers on yours or anybody that has a procharger
May 08 ROTM
2008 Audi S6
Power numbers? or kit numbers?
2007 GT
both
2007 GT
do you have the 1-1sc-1 is that the same as the HO?
May 08 ROTM
2008 Audi S6
I went with the P1SC tuner kit with 3" intercooler. Started at 9lbs, recently bumped to 11lbs, but no new tune as yet.
At 9lbs, 455hp / 409tq on my conservative tune. On my race tune at 9lbs it put down 470hp / 425tq. This was on a dyno jet. As mentioned, since then I added my long tubes, 60# injectors, and the 11lb pulley and need to return for the tune..
2007 GT
so the tuner kit would be just the pipes charger and you did the tune injectors fuel pump stuff like that
May 08 ROTM
2008 Audi S6
Thats correct.. I didn't want to run a BAP, went with GT500 pumps kit. Originally went with 39lb injectors and such...
2007 GT
is there problems with the bap or is that preffence what injectors come with the kit do you know
May 08 ROTM
2008 Audi S6
In the tuner kit you get nothing fuel wise. No pumps, no injectors. I'm not sure about the HO offerings, but I think they go with FRPP. I have friends that vend much of the FRPP product and got all the rest of the parts for far cheaper. Which is a main reason for my choices.
As for the BAP, I'm just anal and didn't like boosting voltage for more fuel..Not that there's problems, I just don't like the set up..
2007 GT
what did you give for the gt500 pump the cheapest I can find is like 750
2007 GT
would you be wanting to sell those old injectors
2005 Mustang GT
10.32@137.70
forensicsteve is selling his procharger p1sc for pretty cheap, only has 3k miles on it, pm him for a price
326 cubic inches of Turbocharged hell will be running soon Tuned by Wes @ TPS ![]() |
May 08 ROTM
2008 Audi S6
on the street 699.00 is the best I have seen.
I paid 625.00 prior to the kit releasing to the public (family connection - about 3 months in advance). Then put another 70.00 into the in tank assembly. The change I made makes it so that the pumps don't drop off pressure so dramatically after a WOT pass. Without it pressure sometimes drops to 15-20psi at complete release of the gas pedal. Mine now holds a more accurate and consistent 30psi. It's just an inline deceleration voltage regulator for the most part.
#14 | |
May 08 ROTM
2008 Audi S6
Skirt Chasing Philanderer
Kit Car/Ducati/Explorer
Nike Fast
Emay, you said your kit started off runnung 9lbs, is that what you were reading on your guage or what the pulley was rated at? Im pretty sure I have the same pulley and am only getting 8 out of mine right now. Did the tuner kit come with the electric fan, ect...? of just the charger, brakets, and plumbing?
Might want to consider writing down what is said above, it will help you at some point or another in your life!
May 08 ROTM
2008 Audi S6
Fastfox, Mine came with the fan, head unit, intercooler and plumbing (blow off valve), bracketry, and maf extension.
I originally only made about 8lbs, but found some belt slip and upon tightening got 9lbs. Are you running a 4.25 or a 4.35 pulley on that thing?
Nike Fast
Im pretty sure its 4.25. When I go home during lunch Im definitally going to be doing some tightening, I'll let you know here in two hours if it got up to 9 or not. Ok, from the sounds of it we have the same kit. I thought maybe you got the more simplified one, since you wanted to go your own route on a few of the options.
May 08 ROTM
2008 Audi S6
Nope, I sort of spread my wings a little quicker than I planned, but I think we started with the same kit components as well. Mine was definately the 4.25 pulley standard. So yours should be the same. tighten up the belt a little and see where you are at.
I didn't check your other mods, are you running long tubes or midlength headers? Those will bring the boost down slightly as well. It's not a performance loss, it's a flow gain..
Nike Fast
Thats fine. My parts list has been a little jacked up here recently, I have been adding parts without removing parts ( i.e. running a procharger and a C&L intake
) Im running Long-tubes. I understand the concept of losing boost but gaining power due to efficent flow, so no worries there.
Nike Fast
WElp, went home and tightened my belt. Did get it a little tighter, but no boost gains. Like you said its prob. due to engine flow. Oh well. I guess I will have to settle for 8lbs for now. Im sure I will add more all in due time. I need to work out my tractions issues first anyways... Thanks for the help though.
