New Suspension installed have questions.
I have finally finished my BMR stage 1 suspension kit. I installed the LCA relocation brackets, but I have question. What should I do with the E-brake cable? The install instruction does not mention anything about them. Right now they are through the LCA. I am not sure if that is the best place for them, because the tension seems to be a bit too much.
One more thing , I get a thud noise from the front passenger side when I steer hard right and if I hit a little bump or if the pitch in pavement changes. I have jacked it up and moved the wheel up and down and did not get any noise. It seems to do it only if the tire travels up into the wheel well on a turn. I also checked the torque on all the nuts and bolts on that side.
2007 GT: K&N, Hurst shifter, FRPP Exhaust |
On my Metcos, it has apertures but the instructions say to cable tie it to the control arm not feed it through like the stock control arm.
Can't help on nyour other problem except to ask if you put the bump stop on the right way up if you changed the dtrut. Also check it's not the rear control arms which need to be torqued to the correct torque which is something like 138 lb ft from memory.
Past: 85 Vette; 87 & 98 Z28; 02 Z06. Present: Vortech HO Mustang GT
Threads Similar to: New Suspension installed have questions.
| CAI installed.... some questions | Basics | V6 Mustangs | 33 | October 29th, 2007 12:40 PM |
| Installed my Tri-Ax | Mach Boy | 99-04 | 24 | October 23rd, 2007 06:54 PM |
| installed 4.10s | 07stanggt | 2005 - 2010 | 25 | October 13th, 2007 08:34 AM |
| i installed something! | artisan00 | V6 Mustangs | 11 | February 6th, 2006 05:24 PM |
| 8.8 installed | Roadhawg | V6 Mustangs | 4 | January 16th, 2006 01:41 PM |
