New cams and heads
Old August 15th, 2007, 05:30 AM   #1
GT/CS's Avatar
GT/CS is on a distinguished road
New cams and heads
I have a 2007 Mustanng GT/CS 4.6L and I just got new racing heads with bigger lift cams. The heads are already come installed with the new valve train but not the cams of course. What sort of things can I expect to have to have to do with this kind of swap? Eg oil/lubrication or adjusting anything withing the heads/cams? I already have new gaskets and studs so thats a check. I am told that the stock followers and lash adjusters are to be reused from the stock heads...this means? What do they do? Thanks for any help guys!
Ford Racing heads, Comp stage III cams, 4.10's, Steeda delete plates, SLP long tube headers, Custom 3'' X pipe, Magna flow 3" Magnapacks, Airaid CAI, SCT XCAL 2 93 tune, Steeda front and rear swaybars, Dynotech aluminum driveshaft, HTP TB spacer
Old August 15th, 2007, 04:01 PM   #2
RLY SRS
ChrisJ's Avatar
ChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud of
iTrader: 9 reviews
You need to have the cams degreed...You should have a cam card that came with your cam...
This is not a great frist time do it yourselfer project...
You need a tune as well...
Depends on what the lift/duration of the cam is but you might need new valve springs...
Facebook
Google+
Old August 16th, 2007, 12:25 AM   #3
GT/CS's Avatar
Oh i already have the whole aftermarket valve train installed in the heads and will have the car dynoed once it's done. As for the timing card I'll have to look. What exactly comes on the cam card? Just specs for the degrees? How do you adjust the cam degree?
Threads Similar to: New cams and heads
Heads and cams mystang0673 99-04 1 September 2nd, 2007 03:43 PM
Heads and cams pa.ulB General Tech 4 August 9th, 2007 03:32 AM
CAMS vs Heads nHuman 96-98 10 February 28th, 2007 09:43 AM
Heads and Cams help please! 00silvergt 99-04 4 June 10th, 2006 09:56 PM
heads and cams? Drgnracin72 99-04 4 June 9th, 2006 01:04 PM
