Biggest tires for stock 18" 07 GT mustang - Forums at Modded Mustangs
post #1 of 41 Old September 5th, 2013, 05:17 PM Thread Starter
I searched but did not find.
I have a stock 07 GT mustang with 18" stock wheels.
What is the biggest tires ( both high & wide) that I can run with out rubbing?
Any one have any suggestions?
Where / what to buy?
Thank you for all information.
crazy horse is offline
post #2 of 41 Old September 5th, 2013, 05:31 PM
fullmetal7777's Avatar
I'm kinda interested about this to, wanna get some 18's soon and big tired are sexy
fullmetal7777 is offline
post #3 of 41 Old September 5th, 2013, 05:33 PM
If you get a tire that fits the stock rims you will never have a rubbing issue. I think 235/50's come on the stock 18's. I wouldn't go wider than 255 if you are getting a 40, 45 or 50 series profile. I wouldn't do 255's with a side wall shorter than that.
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #4 of 41 Old September 5th, 2013, 05:55 PM
Insomniac
BIGCHRISS197's Avatar
I've squeezed a 275 on my stock wheels with zero issues, height wise I'm about to go with a 29" tire but there's still room to play, I reference this chart for side profile to inch conversions
Tire Height Chart
BIGCHRISS197 is offline
post #5 of 41 Old September 5th, 2013, 06:07 PM
I <3 Car Crashes
YoungBlood's Avatar
does the width go the same for 17 wheels? I can squeeze a 275 on? Cuz I have my stock wheels and I want some drag radials but I don't wanna DD on them, I just want them for track days
07 Honda CBR600RR--Akrapovic exhaust--power commander V--Flush & integrated signals--1000rr mirrors--Puig double bubble screen--shogun sliders, -1 +2 gearing coming soon
Selling and parting out my Mustang for another Jeep WJ!
YoungBlood is offline
post #6 of 41 Old September 5th, 2013, 06:38 PM
You guys all need to know why going too big is not going to give you any more performance and actually prevents the tire from performing the way it should. Too big of a tire can adversely effect tire wear and performance. Sure lots of people do it and are unaware of the of the issues because they either just are not that good of a driver (meaning really in tune with their car) or don't push it to a point where the effects are evident. But if you take the same size tire and put it on a proper size rim you will have a car that accelerates, corners, and stops better. Please read post #30 in this thread. I just don't want to type it all out and this guy pretty much nails it on the head.
315 Nitto NT05R's mounted on stock 9" wheels *pics inside* - Page 2 - SVTPerformance
I would like to think that us MMers are smarter than the rest of the folks out there. If you wanna run a big tire, please by a big rim. We make fun of the import guys when they do stupid shit. This falls right into that same boat. It looks stupid and is stupid if you think you're gonna get better performance by going too big. I think we might even refer to it being rice. Do it right please.
07 Boss is offline
post #7 of 41 Old September 5th, 2013, 07:17 PM
Na306Fox's Avatar
I got 285/40/18's on the back of my '06
Sent from my EVO
GET SOME
Na306Fox is offline
post #8 of 41 Old September 5th, 2013, 08:08 PM
And I have 305/45/18's on the back of my 07.
07 Boss is offline
post #9 of 41 Old September 5th, 2013, 08:17 PM
I <3 Car Crashes
YoungBlood's Avatar
So if I wanted the widest DR i could fit on a stock 17 rim what would that be? it would be a track only setup.
post #10 of 41 Old September 5th, 2013, 08:20 PM
mamonti's Avatar
I know they made a 18"X8" and a 18"X8.5" wheel so check to see which you have,,, also if you go to Tirerack site you can check each tires manufactures spec's on each tire.. This puzzled me as I thought (lets say) a 255x45x18 tire no matter who makes it is the same! But under the spec's of the tire you will see recommended wheel width. some may say 8" to 9" and others will be smaller???? so as an example (Just to say) a goodyear 245X50X18 has a recommended rim of 8 to 8.5" but a firestone 265X45X18 will have a recommended 8" to 9" rim!!!! I am not sure why???? but in reality,,I want to go with continentals ,, the biggest tire I can get in a continental is 255X45X18 but I could get a 265 or bigger from other companies!!!
2006 Mustang GT Convertible TVS S/C
mamonti is offline
post #11 of 41 Old September 5th, 2013, 08:24 PM
I <3 Car Crashes
YoungBlood's Avatar
I fit 12.5 tires on 8-9 rims all day on Jeeps that was to keep the wheel tucked in though
post #12 of 41 Old September 5th, 2013, 08:33 PM
Originally Posted by mamonti View Post
I know they made a 18"X8" and a 18"X8.5" wheel so check to see which you have,,, also if you go to Tirerack site you can check each tires manufactures spec's on each tire.. This puzzled me as I thought (lets say) a 255x45x18 tire no matter who makes it is the same! Buy under the spec's of the tire you will see recommended wheel width. some may say 8" to 9" and others will be smaller???? so as an example (Just to say) a goodyear 245X50X18 has a recommended rim of 8 to 8.5" but a firestone 265X45X18 will have a recommended 8" to 9" rim!!!! I am not sure why???? but in reality,,I want to go with continentals ,, the biggest tire I can get in a continental is 255X45X18 but I could get a 265 or bigger from other companies!!!
There are some variances from one company to the other as far as what they call a 255 or whatever tire size you look at. There are also different types of tire construction. Some tires are supposed to have a bulge in them and some have very stiff flat side walls. The slicks I am looking at are measured across the widest section of the side wall bulge, not the tread. So even within the same company, two different tires might have two different recommended rim widths. Every tire maker has a rim/wheel size chart. The will usually have the ideal size and then an acceptable range listed. When looking for tires I often have looked backwards, looking at suggested rim size and then looking to see what size tire it is.
---------- Post added at 05:33 PM ---------- Previous post was at 05:32 PM ----------
How wide is a stock 17"?
07 Boss is offline
post #13 of 41 Old September 5th, 2013, 08:33 PM
mamonti's Avatar
So I guess it is best to check out the tire manufactures recommendations on the size you want. I am wondering about this also,,,,, So if I want to get a continental tire and I really want to go with 265 or 275 then I will have to buy new rims to have the proper setup. I will see what I can afford to do next spring when I get it out of storage since I want to go with koni's, springs and tires. So may be I will try a set of the 255's and save the cost of going with rims and if I decide I want something bigger the next set I will get a set of rims! Then of course comes the next problem.... if I go with rims, what tire will fit without rubbing and what if I want to go with bigger brakes,,,, will the rims fit??? I like buying once so if I go to bigger rims I will go to the size that will fit the tires I want and the brakes I decide on!! Damn Modding !!!!
mamonti is offline
post #14 of 41 Old September 5th, 2013, 08:34 PM
And with an 8" side wall.
And you will also notice than rim size can change for the same style and width tire because the aspect ratio or side wall height is different. It's not so much bulge but the angle of the side wall from the rim to the edge of the tread.
07 Boss is offline
post #15 of 41 Old September 5th, 2013, 08:53 PM
I was on discounttiredirect.com put in all the info for a 2007 Mustang GT with 18" wheels, they have optional sizes and it looks like the largest 18" is a 275/45R18. Like Boss said, bigger is not always better. Maybe other members with this size can chime in with their experiences.
Saleen rear fascia with center exhaust, MAC longtubes with o/r Prochamber, Steeda CAI w/carbon fiber elbow, SCT X3, Steeda UDPs, Hurst shifter, modified delete plates, Comp Cams and 4.10s.
kraigster is offline
post #16 of 41 Old September 5th, 2013, 09:59 PM
gtscrewd
faym 08's Avatar
I used to run a 265 mt et street on my factory wheel fit great.
July 2013 rotm winner
faym 08 is offline
post #17 of 41 Old September 5th, 2013, 10:26 PM
FBGM
I run a 305 on 10.5 in rims and they worlds better than my 285s granted that was on crappy Goodyears, but that thread that Boss posted he link to, WHY THE HELL WOULD ANYONE DO THAT! I could see for drag racing, all that sidewall would be nice but why not get the correct rim and tire for your application. Make me happy I spent the extra money because I never thought I was going to need bigger than a 285 on my car.
Saleen SuperCharged, C500 Side Exhaust, Cervinis Ram Air IV Hood, Hurst Short Throw Shifter, Chrome GT500 Replica wheels, GT500 Front Splitter ModBMR 1.25 Lowering Springs, ADJ Panhard Bar, CHE Torque Limiters and K Member Brace
kmac1622 is offline
post #18 of 41 Old September 6th, 2013, 12:25 AM
booooost'd
Jucostud's Avatar
For non drag radial tires, max for stock 18x8.5's is 265 width. I'd only recommend 255/45/18 though.
1988 LX Hatch 5.0 - SOLD!
2007 Vortech GT - SOLD!
2009 Procharged GT - SOLD!
2014 Oxford White 5.0 Brembo M6
Jucostud is offline
post #19 of 41 Old September 6th, 2013, 12:40 PM
Rankus06's Avatar
When you guy's say 10" wheel I assume they are only on the back? When it comes time to buy wheels is 9" the way to go if one does not want to be staggered?
322 hp/ 329 tq
C&L Racer CAI
Kooks headers with catted H
Borla Touring Mufflers
FRPP 4:10s
Steeda UDP
CHE UCA
BMR LCA, Relocation Brackets, Panhard, Handling Springs
Steeda Srut Mounts
Koni ST-R
MGW shifter
Rankus06 is offline
post #20 of 41 Old September 6th, 2013, 12:51 PM
ncstang06's Avatar
With the right offset you can easily fit 10s up front, I think you can even fit 10.5s but you might need a spacer
JLT CAI, Bama tuner, MAC LTs/prochamber, flowmaster A/Ts, and much more to come
ncstang06 is offline
Human Verification
