What optima
Old September 2nd, 2007, 08:21 PM   #1
07gtmustang's Avatar
2007 GT
07gtmustang is on a distinguished road
What optima
Which Optima battery are you using for your 3v red or yellow and what model thanks
Old September 2nd, 2007, 08:59 PM   #2
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
Most people use the yellow top.
ΜΟΛΩΝ ΛΑΒΕ
Old September 2nd, 2007, 10:27 PM   #3
05mustang_TT_charged's Avatar
2005 Mustang GT
10.32@137.70
05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough
I think yellow has more cranking amps, but I always used the red ones with no problems from them
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system
326 cubic inches of Twin Turbocharged hell will be running soon
Tuned by Wes @ TPS
Old September 5th, 2007, 07:52 PM   #4
2007 GT
anybody have a model number for me. stock is 500 cca and I think a red top would be fine but idk
Old September 5th, 2007, 07:57 PM   #5
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
I use a red top.
I'll pull up the model numbers in a few.
Old September 5th, 2007, 07:57 PM   #6
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
I'm running a red top, but would need to check my model. I didn't go with what the spec sheet said would fit, I wanted my wiring on the opposite side of the battery (towards the fire wall) so I used one that fit my coniguration. I'll see if I can pull the model number and get a picture so you understand what I mean about the wiring.. Just a clean up/appearance thing.
FLICKR Unique Imagery
Old September 5th, 2007, 07:58 PM   #7
2007 GT
thanks guys
Old September 5th, 2007, 07:59 PM   #8
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
http://www.1st-optima-batteries.com/#redspecs
Old September 5th, 2007, 08:05 PM   #9
2007 GT
I know this is going to sound stupid put I heard that if you have too much cca then needed your battery won't last as long
Old September 5th, 2007, 08:18 PM   #10
May 08 ROTM
2008 Audi S6
Mines a 34/78 and the terminals are middle of battery rather than toward the side. This is the only pic I got right now, but you can kinda see the mid mount terminal location.
Old September 5th, 2007, 08:23 PM   #11
May 08 ROTM
2008 Audi S6
Wives tale. You can have overkill, the demand is no more or no less under normal conditions. Winter temps and extreme heat are what eat batteries.
Old September 5th, 2007, 11:38 PM   #12
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
I have a 1000 cca battery on my boat which as a 2.xL V6 and it gets a kick in the ass when you turn that key. It is a noticable difference that the 650 cca that was on there.
ΜΟΛΩΝ ΛΑΒΕ
Old September 6th, 2007, 12:01 AM   #13
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
Eats Chevys, Shits Imports...
Grabber523 has a spectacular aura aboutGrabber523 has a spectacular aura aboutGrabber523 has a spectacular aura about
Red tops are your standard starting/normal use batteries. The Yellow tops are deep cycle, like if you're running a powerful sound system with the car turned off, or a lot of electrical accessories, or whatever. Either one will work just fine.
http://www.moddedmustangs.com/forums...p-vote-me.html
TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER)
MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER
TRUNK MONKEY CREW FOUNDER
Old September 6th, 2007, 12:09 AM   #14
evilcow is on a distinguished road
Why are you guys with new Mustangs already replacing the battery?
2007 GT auto Grabber Orange
Sequential Tail Lights, JLT II, XCAL3, 3.73
Old September 6th, 2007, 12:33 AM   #15
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
You haven't had your battery drain itself for no apparent reason yet? If you let your car sit parked for 3 days or so...get out the jumper cables...I though it had something to do with the Shaker 1000, others thought the security system did it...still never heard what the actual cause is...
Old September 6th, 2007, 02:24 AM   #16
May 08 ROTM
2008 Audi S6
Lots of talk about this, a known problem with the 05-07 mustangs and the pcm continually running while parked for long durations of time. That combined with the shaker 500 and 1000 cycling disc in the changer while off also aids to the drain.
Ford can't fix, they acknoledge a problem, but no fix. Seems a decent red or yellow top nets 3 to 4 week storage times with no start up problems..
Old September 6th, 2007, 03:32 PM   #17
No the only problem I've had so far is where only half the fuel tank will fill if the gas pump is too fast. I've let my car sit for a week with no problems, but it hasn't been cold here yet. Time to invest in new jumper cables. Thanks for the heads up.
Old September 6th, 2007, 03:45 PM   #18
2007 GT
I just want to replace mine before anything happens I can get a really good deal though work on one red for 55 yellow for 65 so I figure I'd jump on it
Old September 6th, 2007, 04:02 PM   #19
May 08 ROTM
2008 Audi S6
you better do a group buy and help us all out. I want a yellow and a red. Hook us up...
Old September 6th, 2007, 04:04 PM   #20
2007 GT
I can only get 2 a year
Threads Similar to: What optima
Redtop Optima MustangMatt96GT 96-98 10 November 4th, 2007 07:19 PM
Optima Battery New88MustangOwner 5.0 Mustangs 4 November 19th, 2006 08:56 PM
