jba long tube headers and check engine light
Old September 11th, 2007, 01:36 AM   #1
msolaas1's Avatar
msolaas1 is on a distinguished road
hey guys... i have jba long tubes and when i had brenspeed do the tune for my car they warned me i was going to get a check engine light for slow response by the oxygen sensors... any1 else get this? i talked to another tune shop and they said brenspeed is lazy and you can fix this with the tuner... any body have any ideas? i appreciate it as always!
thanks
Old September 11th, 2007, 02:11 AM   #2
GT/CS's Avatar
GT/CS is on a distinguished road
Do you still have cats though? If you do and have the rear 02 sensors hooked up there shouldn't be any worries. If you don't have cats you'll for sure have the MIL light go off. Those guys are right though you can take care of that with a tuner no problem. I have an SCT xcal2 and I just plugged it in and deleted the code myself. It never went off again.
Ford Racing heads, Comp stage III cams, 4.10's, Steeda delete plates, SLP long tube headers, Custom 3'' X pipe, Magna flow 3" Magnapacks, Airaid CAI, SCT XCAL 2 93 tune, Steeda front and rear swaybars, Dynotech aluminum driveshaft, HTP TB spacer
Old September 11th, 2007, 09:34 PM   #3
06silvergt is on a distinguished road
I have JBA long tubes sitting in may garage right now. I called Brenspeed first to ask them about a tune and they told me the codes can't be tuned out and I would have to weld the 02 bungs closed and put new ones in closer to the header tubes. When I tried to ask another question I was told they don't deal with JBA headers and was told "Hold on, I gotta check something" and then I was hung up on. I called back and left several messages but they never called me back. Since then I was directed toward VMPTuning of Florida, the guys with JBA LTs swear by them and they will be geting my $400.
Old September 12th, 2007, 02:29 PM   #4
msolaas1's Avatar
yes im running cats... its not the lower sensors that are sending codes... its the uppers... and brenspeed gave me the same shit about rewelding... just wondering if any1 actually has done this or has had some1 retune their car to state the slower response on the upper 02 sensors... Every1 around me tuner wise has said it just takes a little time and brenspeed is apparently to lazy to fix this...
any input is welcome
thanks
kris
Old September 14th, 2007, 08:13 PM   #5
1991 LX, 2003 SNK, 2007 S
11.3
cams-shelbycobra07 is on a distinguished road
Send a message via AIM to cams-shelbycobra07
My tuner told me you send a code that registers on start up that cats are there. But really there not and once its been tricked it just reads they are there and really not.
Threads Similar to: jba long tube headers and check engine light
Long tube headers or short tube headers? 2much4u 99-04 20 October 11th, 2009 10:49 PM
Long tube vs short tube headers Pros and cons cams-shelbycobra07 General Tech 3 July 16th, 2007 08:41 PM
short tube or long tube headers? ishyton4bangers V6 Mustangs 6 July 16th, 2007 01:37 PM
