Fault codes
Receiving fault code P0152 intermittently which is bank 2 O2 sensor, can someone tell me which side is bank 2?
Also receiving fault code P2198 and I can't find this defined anywhere, any ideas? Thanks Konzy |
48.47@ 12.58
your passenger side 02 sensor is shot.
the second code is also an 02 sensor code.. it's telling you that your running rich.. which is probably just the broken 02 sensor miss reading.
what about p0340 cam shaft position?
bumb cause i need help
Vroom <~~~ Stock Vr0oOm <~~~~ me 2006 silver/Black, red interior, moon roof, shaker 1000 JLT Cai, Steeda TB spacer, Hurst Short Throw Shifter, Pypes O/R H, MangaFlow AxelBack, Diablo Pedator... |
2006 Mustang GT
p0340 is sometimes related to a faulty alternator. Is your battery light coming on?
For the OP HMUSN already got you taken car of, I would replace the upstream O2
![]() 2006 Mustang GT-Borla Stingers, MGW Billet Interior & Underhood, Eibach Pro Kit w/Tokico D-Specs, Steeda Sway Bars, CHE Suspenson Upgrades, BBR Billet Control Arms, Foose 20" Nitrous, BFG g-Force KDWII |
ive had no battery issues what so ever and have no battery light... car is running strong, how can i test for this?
2006 Mustang GT
If the alternator is in fact casuing the issue it is most likely due to a faulty diode sending out interferance. Here is a TSB for it.
http://www.2005stang.com/gallery/albums/userpics/10281/tsb06-02-09%20dtc%20trouble%20code.pdf
Dammit HMUSN why couldn't you answer my question about my cats?!
SLP Loud mouths SLP x-pipe 4.10 gears K&N intake X-Cal II custom tune |
Threads Similar to: Fault codes
| My own dam fault | maddymac07 | The Clubhouse | 13 | June 21st, 2007 10:42 AM |
| EVAPORATIVE EMMISIONS CONTROL FAULT??? | 97S281 | 96-98 | 7 | March 12th, 2007 01:54 PM |
| tire presure monitor fault | trueballerisme | V6 Mustangs | 1 | February 26th, 2007 06:47 PM |
| OBD Fault Codes Help! | ROBBED666 | 2005 - 2010 | 1 | October 6th, 2006 06:16 PM |
| Purge Control Solenoid or Purge Control Valve fault | kdevildog01 | General Tech | 3 | July 17th, 2006 01:45 PM |
