Roush / MGW Short Shifter, Your Preferences, Cons And Pros - Page 2
Old December 22nd, 2007, 03:04 PM   #21
LUV2XLR8 is on a distinguished road
I have read nothing but great things about the MGW, and if you even just look at the unit it appears to be a superior unit.
MGW 05+ Shifter
Got a reply from George at MGW:
"the gear whine you hear is actually quite normal and is not harmful at all . you can lessen the noise by installing "more dynamat" material UNDER the shifter area and making sure that there are no air gaps around the base of the shifter and the oval cutout in the car. the reason you hear more tranny whine however is due to the fact that you do not have all that mushy rubber. call me if you have any questions or concerns."
regards
george
So i think weve already said the sheet of Dynamat thats comes with the shigter should be enough to keep the noise blocked. So maybe my Mechanic didnt install the Dynamat properly ?
But then George is saying I need more dynamat? Im confused here. Any help on this. Thanks All
I agree it is a superior unit bro, and love the way it shifts, but that Whine noise ....somethings wrong...either my mechanic or need more Dynamat?
JLT CAI (BamaTuned), UDP, Delete plates, MagnaFlow, Saleen Suspension System, BMR LCA & UCA, Upper Strut Mounts, MGW Shifter, Shorty Antenna, Pony Mats, Tint Protector.
* Comming Soon: 4.10 Gears, Clutch, Flywheel & Brembo Brakes.
Old December 22nd, 2007, 03:41 PM   #22
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
Dont forget George hasint seen how your mechanic has used the dynomat....He probably didint install it correctly (dynomat that is)
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old December 22nd, 2007, 03:45 PM   #23
07 STROKER's Avatar
07 Mustang GT
Also...its not that much work to take your console apart and check for air gaps...that will tell you soon enough
Old December 22nd, 2007, 04:11 PM   #24
Thanks Bud. Will get to over the weekend and let u know the outcome.
Old December 22nd, 2007, 04:12 PM   #25
07 STROKER's Avatar
07 Mustang GT
Anytime....I still have the install CD if you need it as well....its very Helpfull!
Old December 22nd, 2007, 04:15 PM   #26
Cool, will give u a shout u know if i need it. Thanks A mill
Old December 22nd, 2007, 07:10 PM   #27
2002 BMW 530i
don't know and don't care
Luis_GT is a jewel in the roughLuis_GT is a jewel in the roughLuis_GT is a jewel in the roughLuis_GT is a jewel in the rough
Send a message via MSN to Luis_GT
Well, Me, I have about 1/2 the dynamat it originaly came with... I took about half of it off when I re-installed my stock shifter... and to tell you the truth, I like how it sounds... gives the interior more rumble from the exhaust without the need of waisting 500 bucks on some borlas
Old December 22nd, 2007, 09:56 PM   #28
Goldenpony's Avatar
Goldenpony is on a distinguished road
Shifter
There's only one shifter (for me), that's spelled M-G-W!
Old December 23rd, 2007, 04:23 AM   #29
Why did u resintall ure stock shifter . . Warranty Work ?
MGW ,It does make more "Rumble" in the car but thats normal with or without the shifter. (Whining noise has got to go, looking into it)
Old December 23rd, 2007, 07:58 AM   #30
2002 BMW 530i
yep... I was having some problems with my second gear... it fixed itself over times and I reintalled the MGW... I'm now waiting for it to break-in again... I still can't powershift like I was with the stocker...
Threads Similar to: Roush / MGW Short Shifter, Your Preferences, Cons And Pros
Nitrous - The Pros and Cons TurboLX General Tech 14 November 10th, 2010 02:45 AM
Pros And Cons Of Lowering hotrod General Tech 14 March 22nd, 2008 09:20 PM
Roush short throw shifter install new2mustangs 99-04 5 October 4th, 2007 08:00 PM
Long tube vs short tube headers Pros and cons cams-shelbycobra07 General Tech 3 July 16th, 2007 07:41 PM
Pros and Cons (Supercharger Type) KaZpeR General Tech 20 September 24th, 2006 07:30 PM
