Broke Idler Pulley - Twice!!!
Okay, I just broke my second idler pulley, the one provided with the 8 rib kit. I figured the first time it happened that it was just an anomaly. Apparently that's not the case. Both pulleys broke in an identical fashion, and both belts shredded in half at the moment of pulley failure.
I've got the Whipple with 13 PSI pulley, 8 rib kit, and Kenne Bell tensioner. 1) What would you do to solve the problem? 2) Should I purchase an aftermarket pulley, something a little stronger? 3) Is this common on forced induction vehicles? 4) Is it normal for the belt to break at the same moment the pulley fails?
2007 GT
I would try and check the alimignt of the new tensioner check with a tube light bulb or straigt edge on the pullies. If you have 4 points of contact on the edges, of where straigt edge are then your good. and make sure the tensioner isn't getting bound up
Big timin' in a small town
Just had to say holy shit what a user name
#4 | |
2007 Alloy/Satin Silver KB GT500 703rwhp/628rwtq SAE http://www.cardomain.com/ride/2537363 |
When I installed my Whipple I had to modify my tensioner giving it a greater range of motion. All I can think of is to much tension or misalignment. I assume you are torquing to spec and bearing is free and happy on install.
Your Mom's Favorite
2007 Mustang GT
Eats Chevys, Shits Imports...
Check the position of the upper idler to the right of the alternator (as you're looking at it)...you should have a few different holes to mount that pulley to to adjust your belt wrap and angle, try to make the turns the belt makes a little less sharp, but make sure you still have good tension on the belt...that may help...
http://www.moddedmustangs.com/forums...p-vote-me.html ![]() TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER) MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER TRUNK MONKEY CREW FOUNDER |
Threads Similar to: Broke Idler Pulley - Twice!!!
| WE BROKE MM!!!!!!!!!!!!! | 06RedfireGT | The Clubhouse | 53 | August 18th, 2007 03:38 PM |
| Car broke down. Please Help | ocsailor86 | 96-98 | 6 | June 15th, 2007 10:26 PM |
| I think i broke something :( | Timmano | V6 Mustangs | 12 | June 3rd, 2007 04:10 AM |
| Reverse Idler gear and countershaft gone | 02ponypackage | V6 Mustangs | 3 | March 28th, 2007 08:16 PM |
| Hi-Flo Broke! | GTSilver | 99-04 | 6 | September 15th, 2006 01:02 PM |
