high idle then nothing
hey. i just rewired my relay for my saleen water pump... instead of dissconnecting the battery like a smart person would do i just carried on with the business... i took out the 10mm that hold the power lead to the relaw to main dist. block... of which doing this cut the power to the block also let off a little spark... when i reconnected everything the car would just go to a high idle then slowly cut out... any ideas what this may be... i would try to re-tune it but my tuner is at JDM right now... please let me know any and all explinations and possible things to look at... thanks
2007 GT
did u check all the fuses and relays?
i checked all the fuses... how do you check the relays? any suggestion on pinpoint whihc one?
2007 GT
I'm pretty sure u check with ohms to see if you got continity sorry not the best speller
2006 GT
11.99@114
Try removing the positive lead to the battery for 15 minutes. If you haven’t already.
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
Threads Similar to: high idle then nothing
| high idle | RAMS#20 | 94-95 | 4 | October 24th, 2007 02:23 PM |
| High idle | 8A_Honda | 5.0 Mustangs | 16 | September 17th, 2007 07:53 PM |
| high idle | buddie | 94-95 | 1 | June 30th, 2007 02:40 PM |
| Idle Too High | terribleonexx88 | 5.0 Mustangs | 28 | October 15th, 2006 11:27 PM |
| Idle Too High | DaveCarey | V6 Mustangs | 14 | October 11th, 2006 11:17 PM |
