Kenne Bell - Page 2
Old November 4th, 2007, 08:33 PM   #21
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
Eats Chevys, Shits Imports...
Grabber523 has a spectacular aura aboutGrabber523 has a spectacular aura aboutGrabber523 has a spectacular aura about
Originally Posted by hellbred07
the windshield washer best i have seen now it is limp because the pump has so much further to push.
Check your plumbing...my windshield washer is as strong as it ever was...It comes out and you can hear it hiss as it hits the windshield, like going through a car wash...
http://www.moddedmustangs.com/forums...p-vote-me.html
TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER)
MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER
TRUNK MONKEY CREW FOUNDER
Old November 4th, 2007, 08:38 PM   #22
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
EMAY, finally got the lurch eliminated!!!! During my 20 hour drive from Northwood to Spokane we were fighting a 40 m.p.h. headwind, and the lurch, even at .025 on the HT0's was awful, so about 7 hours down the road we swapped plugs and it's been completely blowout free. Went back to Motorcraft plugs in the stock heat range at .025 and it hasn't missed a beat. Those Autolite plugs just stopped firing after a few misses...apparently they were, I dunno what else to call it but shorted out from the unburned fuel. I'm never taking these plugs out again. That's 8 times in one week!
Old November 4th, 2007, 08:39 PM   #23
07gtmustang's Avatar
2007 GT
07gtmustang is on a distinguished road
i've never used mine don't like streaks you know where your blades swept
Old November 4th, 2007, 08:46 PM   #24
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
What does it feel like when there is blow out and could that happen at 5psi
It feels like a midget kicking your seat, the car literally bucks, especially noticeable in 5th gear cruising as you go up a hill or something...BAM BAM BAM BAM...mine happened right at about 4 inches of vacuum all the way to 8 lbs of boost, if you're experiencing that, chances are your plugs are shot as well, It took me a few sets of plugs before I got a good set gapped where I need them...it makes your tune go crazy, your fuel pressure is all over the place, and you run stoich waaay too deep into the throttle...mine was so bad initially that it threw a check engine light...all the unburned fuel was forcing the rest of the cylinders lean, and the ecu blamed it on my MAF...which there was absolutely nothing wrong with. It sucks ass.
Old November 4th, 2007, 08:54 PM   #25
05mustang_TT_charged's Avatar
2005 Mustang GT
10.32@137.70
05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough
what about a boost a spark, wouldn't that be cheaper than the coils and it is only a 3 wire hook up
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system
326 cubic inches of Twin Turbocharged hell will be running soon
Tuned by Wes @ TPS
Old November 4th, 2007, 08:57 PM   #26
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
Yeah, you could do that. I looked into that, but would personally rather run a higher voltage set of coil packs. Besides, it wouldn't have fixed the blown plugs that I kept getting. I don't need any of it now! :award
Old November 4th, 2007, 09:04 PM   #27
2005 Mustang GT
10.32@137.70
hear ya, i will swap the plugs out and get it redynoed, i feel i got another 30+ wheel horsepower left in the car, mine starts breaking up around 4800 rpm with 9 psi.
it was pulling strong and made 466 wheel before i started pegging the mass air, and changed to sct 2800 and got some more out of it, last dyno pull made 479 rwhp at 4800 rpm but started falling on it's face and spiking real hard so we got out of it and i thought it was the plugs again
Tuned by Wes @ TPS
Old November 4th, 2007, 09:11 PM   #28
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
You pegged the Cobra MAF?! Damn! Those are pretty impressive numbers for running 9 psi...I'm jealous...most I've seen out of my 8 lb with the stock plug gap was 410 w.h.p. on stock exhaust and canned tune. I have a feeling all the power I'm missing was in the plug gap...fingers crossed...I'm in Spokane Washington the rest of the week, gotta find a dyno to make sure that spiking went away...mine was in the same rpm range as you on the graph. I know from the butt dyno, it's never run stronger or smoother.
Old November 4th, 2007, 09:16 PM   #29
2005 Mustang GT
10.32@137.70
mine made 412 rwhp on the canned tune and 422 rwtq, be took the tune out and started the custom tune, first pull which was rich made 446 rwhp and 477rwtq, 2 pulls later was 466 rwhp and 502 rwtq but the mass air was done it pegged at 5600 rpm, i have the 3.75" pulley which supposed to be 10 psi. but it only makes 9 psi. probably because of the longtubes
Tuned by Wes @ TPS
Old November 4th, 2007, 09:20 PM   #30
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
My 8 lb pulley showed 10 psi on the gauge the other day...but it was 25 degrees outside...how much did those long tubes get ya at the wheels? Cuz a full MAC setup and a drive shaft are my next 2 toys...
Old November 4th, 2007, 09:55 PM   #31
2005 Mustang GT
10.32@137.70
i was still na when i put the on and it was 11 rwhp, really don't know the difference with the kb, i do all my tuning on a mustang dyno so numbers are about 7% lower than a dynojet, i figure on a dynojet i should be around 515 rwhp, but no one around here uses it, it put 479 at shreve's automotive and 477 at 454dyno, and they both use mustangdyne dyno's
it helps alot we are either at or below sea level, so cars around here always put some good numbers with the thick air
Tuned by Wes @ TPS
Old November 9th, 2007, 03:55 PM   #32
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
So here's the result of the plug gapping:
8lb Kenne Bell Intercooled kit
Canned Tune
Stock Exhaust
3.73 FRPP Gears
Stock heat range Motorcraft plugs gapped at .025
SAE Corrected numbers:
Old November 9th, 2007, 04:28 PM   #33
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
Grabber, looks good man. I don't recall seeing your initial attempts on the dyno when blow out was occurring. Did you see significant improvement from then? I'm guessing on your initial session you probably never got a good full pull either.
FLICKR Unique Imagery
Old November 9th, 2007, 05:16 PM   #34
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
405 h.p. was the most I saw until I got the spark nailed down...so HUGE improvement! Can't thank you enough...
Old November 9th, 2007, 06:33 PM   #35
May 08 ROTM
2008 Audi S6
That's awesome, glad it all came together..
Threads Similar to: Kenne Bell
kenne bell ZoomZoomMFer 96-98 6 August 27th, 2007 11:16 AM
Kenne Bell ??? silverstang0988 General Tech 17 April 7th, 2007 11:38 AM
Kenne Bell On 2V? GTSilver 99-04 14 October 14th, 2006 01:31 PM
Kenne Bell 03blownmach1 99-04 11 June 28th, 2006 01:04 AM
