Kenne Bell
To my kenne bell stangers,does your car idle smoothly or does it have a tremor you feel in the back of your seat?Also does your exhaust make any slight popping in between?All at idle.The car tremors comes and goes not constant especially when first started and the idle begins to fall.No codes no warning nothing.Gas milage seems to be less unless i relly baby but one stomp and she drinks is this normal.When i hear the slight pop i feel the tremor,any help with this.
2005 Mustang GT
10.32@137.70
might be a fouled plug, how is the air/fuel ratio
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system 326 cubic inches of Twin Turbocharged hell will be running soonTuned by Wes @ TPS ![]() |
air fuel was in the 11s from bottom of the run but went to 12s at the top.The dyno guy said it was making ten psi but it should make 5psi.Where should i start?
I didn't gap them bren told me they don't gap the hto unless it is a very high horse power application.
2005 Mustang GT
10.32@137.70
you have the non-intercooled kit?
i gap my plugs to .035"
Yeah i do, i'll check the plugs, do you think i could have a cat problem or a vac leak cause it sounds like an exhaust noise along with the tremors rpm gauge don,t move much,would a check engine light come on for these things?
2005 Mustang GT
10.32@137.70
so you are making 10 psi. with a non intercooled kit?
if so not good you are going to blow that thing up, if you didn't already hurt the motor with it on the dyno. the most non intercooled boost is 5 psi. because of the heat, i would get some ht0 autolites and gap at .035" what kind of cats do you have on the car? sometime you will get a check engine light but not all the time, i blew out the driverside highflow cat from dynatech with the longtube headers and took both cats out and i never got a check engine light what kind of numbers did you put down on the dyno?
One Man Wolf Pack
10psi on the non intercooled kit is a no no
![]() ΜΟΛΩΝ ΛΑΒΕ
Check your flanges connecting the X-pipe to the manifolds. Sounds like an exhaust leak to me.
Guys i'm not pulleyed to push 10psi i have a 4inch and some pulley,i am also running stock exhaust except for pypes axle backs.Just how they sent it i installed it and uploaded their tune,car runs fine just nervous at idle.I also have the hto in the car but i did not gap them because brenspeed owner said it was not needed unless i was putting out alot.Called k/b said you have the right pulley,the tuner claims to have an 06 with a k/b i asked to see his data sheet w/ iat and boost his said his iat is 62 degrees and making 17psi with a 8-9 psi pulley
Then said he was having problems with the software that day.Still having problems if you ask me Then said you need a tune.
One Man Wolf Pack
LT headers and an o/r midpipe will lower the boost pressure.
![]() ΜΟΛΩΝ ΛΑΒΕ
2005 Mustang GT
10.32@137.70
that is close the 4" pulley made 8 psi. on my car but i have dynatech longtubes
Your Mom's Favorite
2007 Mustang GT
Eats Chevys, Shits Imports...
I had to gap my plugs to .025 to get the spark blowout to quit, you need to gap those plugs down or you're going to go through a lot of them. I guarantee the ones you have in there are carbon-run and you'll need a new set anyways, so gap those. And yes, my car does have a lope in the idle, I was thinking it was because I gapped the plugs so tight, but in your case it's because you need to gap the plugs down...And stick with the Motorcraft Plugs!! My car hated the Autolites, I went through several sets trying to chase down a spark problem, and the Motorcraft plugs just work better. And yes, they are the stock heat range!! So for all of you who are brainwashed into thinking you need to run a colder plug, I'd be happy to discuss that with you on another thread. Who installed your blower?? There is no way you could be pushing 10 psi, in my turbo days I'd check for a vacuum problem, BOV or wastegate, or boost solenoid...but it's a blower...it will only boost what your pulley tells it to, plus or minus a couple pounds depending on weather, i found out the other day...
http://www.moddedmustangs.com/forums...p-vote-me.html ![]() TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER) MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER TRUNK MONKEY CREW FOUNDER |
You're right i couldn't be pushing 10psi unless kenne bell f...ked up in the tune.I going to get a second review on another dyno because those guys seem a bit upset i din't pay them near $2,000.00 to do somehting i can do myself.I'm going to look at the plugs today k/b suggested one heat range cooler especially in my case no ic,which is all going to change pretty soon.My numbers were 382 rwh 369 rtq k/b said if i was pushing 10 i would make 450 or so but no ic hot ait timing being pulled by the engine who the hell knows.been also worried about those cats probably going to try pypes o/r h descent price and would sound awsome.
Your Mom's Favorite
2007 Mustang GT
I've talked to Jim Bell personally on the phone about the plug heat range this summer when I first started having the spark blowout issue. From his mouth he told me the only reason they suggest a colder plug is because that's what everyone else does. You're not heating the air charge or compressing the air as much as a roots blower, plus the knock sensors will detect any knock while under WOT, so you still have that layer of protection. I'm not experiencing any problems whatsoever running stock plugs gapped properly. The only downside is that if it's really hot, you will lose some power due to the ecu pulling timing. But that's with any vehicle.
There's no way the tune will affect the pressure coming out of that blower...just the belt. It sounds like the shop you were at needs some serious help of their own. I would definitely go somewhere else. And yes, you will almost never see the max h.p. that your combo is tuned for, your car will pull timing anytime it detects knock, so in the summertime when it's hot, you'll never get the full h.p. that it's set up for. That's true for every car, any power adder, no matter what. I've had the best power between 50-60 degrees ambient temp on 92 octane, but it's still just a little shy of the 445 h.p. at the wheels that they advertise. It's the nature of the beast. Every car's a little different.
2005 Mustang GT
10.32@137.70
grabber523 what did the high rpm look like on the dyno, my car from 4800 rpm to 6000 rpm spikes alot, thought is was spark blow out so went to ht0 and gapped to .035" and still doing it, who told you to gap down to .025"
So you suggests removing the autolite htos, by Monday i would knoew if i could order a intercooler or not,its just the lope you talked about that i feel i don't like also that sound of a burble at idle i also don't like and to make matters worst Jim Bell said he suggest something because another manufacturer said so.Dam it what ever happened to extensive research.Man i tell you the blower is wonderful and powerful but i feel they diregarded the rest of the car, the windshield washer best i have seen now it uis limp because the pump has so much further to push.
intercooler 7psi pulley and hopefulley i would be intirely happy.I wanna drop bombs on these other car owners who pulled up next to a older not concerned with racing driver and blow them away,which the car did with a cai and a shelf tune.One car thought he got me and thatsb because he is at least a thousand pounds lighter and pushing a turbo,and still he had hell with someone that don,t powershift and rolling battle armored vehicle.
May 08 ROTM
2008 Audi S6
05 mustang, grabber and I worked on a majority of his blow out problems. JDM and several other shops are taking the gap down as far as .021 on several of their 10 to 14 psi cars to cure the spark blow out issues.
I did a turbo car for a local about 2 months ago and the only way to stop blow out was at .025 and he's still running strong now. Grabber went in increments of about .002 until he eliminated the blow out. Last I heard he still felt a little something not sure it's cured all the way. I'm running hto's on my conservative tune gapped at .032 with no trouble and on my race tune with 110 in the tank I run on another set of hto's gapped down to .028 I haven't had any blow out but the tuner (Kurgan) up front suggested gapping down to eliminate any blow out troubles. |
What does it feel like when there is blow out and could that happen at 5psi
#20 | |
Your Mom's Favorite
2007 Mustang GT
Threads Similar to: Kenne Bell
| kenne bell | ZoomZoomMFer | 96-98 | 6 | August 27th, 2007 11:16 AM |
| Kenne Bell ??? | silverstang0988 | General Tech | 17 | April 7th, 2007 11:38 AM |
| Kenne Bell On 2V? | GTSilver | 99-04 | 14 | October 14th, 2006 01:31 PM |
| Kenne Bell | 03blownmach1 | 99-04 | 11 | June 28th, 2006 01:04 AM |
