SCT Tuner Not Working And Cervini's Muffler Downer
I plugged the unit into the plug under the dash. AND IT ASKED FOR THE TUNE OCTANE I WANTED, 91 Is what I put then hit select. THEN THE UNIT WENT OFF AND DID NOT COME BACK ON..
. WHAT IS UP????? HELP ALSO I PUT THE CERVINI'S SIDE EXHAUST ON THE CAR with the Pyes OR/H pipe, AND TO ME IT SOUNDS LIKE GLASS PACKS ,, GURGGLY AND OBNOXIOUSLY LOUD (Cervini's MUFFLERS are NOT made by Magnaflow anymore but ARE NOW MADE BY PYPES) 14" Polished just like the Magnaflows but say Cervini's made by Pypes.<<>>WILL IT TONE DOWN? At the Red light it has everyones attention. I heard it aprox 1/4 mile away this evening.My biggest downer to the exhaust is it sounds like a truck with Glass packs and that isn't what I was going for. I obviouslly need side exhaust because of the Cervini's side skirts but thought it might sound a little Deeper tone and not as Loud. Any other suggestions or am I stuck.?
2007 Alloy GT. 5 speed, Spydershaft, MGW shifter, 3.55 gears, Sequential tail lights, C 300 Cervini's Full Body Kit, CDC Hood Struts, Whipple HO.SC. 468 SAE RWHP 450.44 RWTQ |
Do you have cats. Maybe batterys on tunner went dead.
make sure its plugged in good.
and get some high flow cats to bring the sound down alittle.. |
#4 | |
Your tuner is powered by the OBD 2 connector,Usually the dome light fuse or the lighter fuse run power to the connector,If the fuses are good and you have power to the OBD 2 connector,Then I would investigate the tuner.Can't help with exhaust question.
^^ thats y i said u sure its plugged in good..
Add catts that will change the tone or change the muffler part
Thanks for the replies. OK I checked the fuses/dome light all working and OK. Made sure the unit is Plugged in properly. Still not working. I can't open the unit to check the batteries as there is a lable that if I open it voids the warranty<<<>(Sucks)
If I put the stock Catted H Pipe back on will that definatly lower the tone or not by much>??
One Man Wolf Pack
Put an x pipe on there.
![]() ΜΟΛΩΝ ΛΑΒΕ
just put on high flow cats on ur h now.. and it runs off the car.. maybe theres a malfunction of some sort...
are u getting power when u plug it in now? car off plug it in. if not thenmaybe 1 of the pins are fucked up.. if not then call who u bought the x cal from. |
2007 Mustang GT
13.7 @ 105
dont know about the tuner, but your stock h pipe will quiet it down alot until u invest in high flow cats
black 07 GT, jlt2 cai, sct2 brenspeed 93 octane tune, UDP's, spydershaft, triax, magnaflow catted x, steeda axleback, bad ass steeda suspensionStealth GT Twin Turbo System On The Way!!!!!!! STEEDA SUSPENSION CREW FOUNDER |
When I first got my sct livewire from american muscle, it did the same thing as yours, wouldn't run a tune. called the tech at american muscle, he said sometimes the dealer changes the tune to not coincide with the computer code on the computer( the four letter code on the outside of the computer itself). he emailed me a new tune and i downloaded it into my tuner and everything works great. Just my experience but you might call the tech where you got your livewire. hope it helps....
316rwhp 333rwtq ![]() STEEDA-UDP's CMRPDelete 90mmCAI 4.10's SCTLivewire Hurst Spydershaft 20"Razors Edelbrock Bassani-XPipew/Cats & Axlebacks Hurst Crew Member #4 |
UPDATE::: I spoke with Dave at Brenspeed. (stand up guy) They are sending me a replacement tuner overnight and I will send the malfunctuning unit back.
Great customer service<<<<<<
Skirt Chasing Phallus Phondler
Kit Car/Ducati/Explorer
Nike Fast
As you know from our discussions before you got the exhaust Im running long-tubes, prochamber, and the cervini exhaust ( magnaflow ). I wouldnt compare my car to a truck with glass packs, but it is definitally loud. Mine has a nice rich deep tone to it. I will try to get some sound clips up for you so you can compare. Shoot Emay a PM as well. He has LTs, unknown midpipe, and the same side pipes as me. He could probably do the same so you can figure out what you need to get you car sounding like you want it to...
QUOTE OF THE DAY (5/24/12): “I not only use all the brains that I have, but all I can borrow.” -- Woodrow Wilson |
May 08 ROTM
2008 Audi S6
Tassy, I have the magnaflows as well, just like fast does. I haven't heard this new pypes set up you mention yet. My car sounds great to me, took a little getting used to at first with the exhaust in your basically because of the side exit. Mines fairly deep, incredible at WOT.
I have the Kooks Long tubes and Kooks high flow catted X pipe. I'll never change it, I'm that stoked with the sound.. Here's a burnout clip... ignore the blow off valve which tends to draw your attention more than the exhaust at times: Heater CMC 07 - Putfile.com |
*stares longingly at Emay's blow off valve*
Nike Fast
Hey Tassy, who did you get your side exhaust through, I know you said that its cervinis kit, but did you get it through someone other than cervinis. I was just talking with my contact ( Jamie ) over at cervinis checking on an order ( vert tonneau cover ), she said they are still running magnaflow exhaust for their kits. I had her double check for me and she confirmed it. She didnt know anything about using pypes... If a new midpipe doesnt fix your exhaust you might want to try a supercharger, that will definitally change your exhaust note... Hope this helps...
#18 | |
May 08 ROTM
2008 Audi S6
Tass, did you see above, Fast was in contact with Jamie today and inquired for you.. He was told they didn't make any change...
Also, do you have headers or no? |
no, stock manifolds with the Pypes O R H pipe. I am putting the stock Converter H Pipe back on Tuesday. If I step on the Gas everyone looks. TOO Much attention. I like it to a degree but with the Cops in my area I am bound for problems.
Threads Similar to: SCT Tuner Not Working And Cervini's Muffler Downer
| Cervini's Stalker | mumbles483 | 2005 - 2010 | 24 | December 20th, 2007 03:20 AM |
| New Cervini's GT500 Cowl Hood | manOwar | 2005 - 2010 | 30 | November 1st, 2007 01:43 PM |
| Cervini's hoods | yamahammer | 2005 - 2010 | 9 | August 29th, 2007 01:10 AM |
| Cervini's Stalker Body Kit | KatTuck013 | V6 Mustangs | 0 | May 18th, 2007 10:39 AM |
| Does anyone have a Cervini's Cobra R Hood? | Chris02 | 99-04 | 24 | December 31st, 2006 12:27 AM |
