Belt Squeak
Old November 13th, 2007, 12:33 PM   #1
gw604z2jnpps is on a distinguished road
Belt Squeak
My current issue is related to belt squeak. The belt squeak is constant, and occurs at idle or during engine load.
Please make note of description #2 below.
1. The belt squeak progressively worsens after a new belt is installed, and may reduce in severity as the engine warms up. However, the problem will worsen to the point that belt squeak is audible from engine start to engine shut off regardless of engine temperature.
2. It may be important to note the following. The vehicle suffered front end damage that caused the driver side frame rail to push against the power steering pump. There seems to be a lot of fore/aft movement in the power steering shaft. Completely removing the pulley results in the same fore/aft movement. See the video below for evidence of this movement. The video is more "audible" since you really can't see the movement.
3. While the vehicle was being repaired, the engine was pulled and an 8 rib kit was installed. The belt squeak did not occur before the accident. Again, the power steering pulley was damaged during the accident, and the 8 rib kit was installed during collision repair.
4. Replacing the belt with a new belt, completely eliminates the belt squeak.
5. Completely removing the belt eliminates the noise.
6. Water sprayed on the belt eliminates the squak momentarily.
7. Belt dressing sprayed on the belt actually made the squeak worse.
8. I purchased an automotive stethoscope. However, I'm not able to really listen to the A/C, power steering, crankshaft, alternator, supercharger, and tensioner pulley because the pulley and fasteners all rotate. The remaining pulleys don't make any audible squeak noise.
9. The crankshaft is approximately 0.175 inches from the timing chain cover. The instructions that GI Joe includes with the 8 rib kit reference a need for approximately 0.200 inches.
10. I have replaced factory tensioners, and installed both Kenne Bells tensioner and currently have Thump RRRs tensioner.
11. Increasing tension on the belt does not eliminate the noise. I have adjusted Whipple's sliding idler pulley for maximum tension. I have also applied maximum tension on the tensioner pulley using a lever to increase tension while at idle.
12. Since the squeak can audibly minimize after the engine heats up, I thought I might try using a propane torch and heat the pulleys to see if I could draw any conclusion. If I heated the crankshaft pulley, it would instantly change in sound, but the squeak never went away. Heating any other pulley resulted in no audible change in the squeak.
Old November 13th, 2007, 12:45 PM   #2
mdvaldosta's Avatar
11.47@120.58
The belt squeel has to be either a loose belt or the belt not tracking right. Even with the excessive power steering pump play I would think that the belt would still track fine assuming everything else is in line. What about the length of the belt? Maybe the tensioner's stretched to the max? Maybe a pulley is cocked to the side or not lined up well with the rest of the pulleys? With GI Joe's 8 Rib kit there really shouldn't be any belt slip ever (I'm sure you know that though).
Old November 13th, 2007, 12:56 PM   #3
Proud American
MustangMatt96GT's Avatar
I agree with thebelt lenght. Also, make sure that all the pullies r all completly in line. It could be a factory defective pulls.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old November 13th, 2007, 10:27 PM   #4
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
Eats Chevys, Shits Imports...
Grabber523 has a spectacular aura aboutGrabber523 has a spectacular aura aboutGrabber523 has a spectacular aura about
Or it could be the bearings in one of your accessories. I have a sealed-bearing idler pulley (brand new, dammit...waiting on a replacement) that makes kinda a squealing noise, but it sounds a little more like dry bearings than belt squeak...I used a piece of rubber fuel line to chase it down to the offending pulley, didn't have to touch any acessories or get close enough to the belt to be dangerous.
http://www.moddedmustangs.com/forums...p-vote-me.html
TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER)
MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER
TRUNK MONKEY CREW FOUNDER
Old November 14th, 2007, 12:54 PM   #5
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
I should have something to do with the belt or pulley alignment
ΜΟΛΩΝ ΛΑΒΕ
Old November 14th, 2007, 01:01 PM   #6
They sell two different types of automotive stethoscopes. One is the standard metal rod, the second is a cone type.
I'm picking up the cone type tomorrow so I can get a better listen to the pulleys that I'm not able use the standard auto. stethoscope.
Old November 14th, 2007, 01:04 PM   #7
I went an purchased a carpentry level to use as a straight edge. I'm going to take some measurements soon.
Hopefully it is an alignment issue, so I can be done with this problem and move next one.
Threads Similar to: Belt Squeak
Windows Squeak? Reset 99-04 11 August 6th, 2007 10:02 PM
drivebelt squeak HeLp slow98gt 96-98 3 March 18th, 2007 09:56 PM
squeak mustang1072 V6 Mustangs 5 February 21st, 2007 10:34 PM
squeak stang638 V6 Mustangs 31 February 11th, 2007 03:33 AM
Squeak Squeak! DC97Cobra General Tech 4 November 26th, 2005 11:13 AM
