Body Kit Installation Help Needed And Spoiler Removal Help
OK, About removing the rear spoiler. I unbolted it but that sucker is on there. Is it 3 M'ed also under the to pedistal mounts? What is the best way to remove it??
As for applying the 3M tape on the parts. It is in the 50's here in my area. Will the 3 M tape still stick or should I be worried about application. Thanks. TASSY5
2007 Alloy GT. 5 speed, Spydershaft, MGW shifter, 3.55 gears, Sequential tail lights, C 300 Cervini's Full Body Kit, CDC Hood Struts, Whipple HO.SC. 468 SAE RWHP 450.44 RWTQ |
May 08 ROTM
2008 Audi S6
It is 3m'd on, get some fishing line an try using it to cut through the 3m tape all the way around the feet of the spoiler, it will easily pop off.
Cleaning it all up isn't quite so easy, goof off, rubbing alcohol and adhesive remover will be needed to get the left over tape off.. 50 degrees is no good for mounting new 3m tape.. Do you have access to a heated garage or a heat gun to warm the surfaces you are sticking to? If you do, you will be fine, but also leave the car in direct sunlight for extra cure time.. |
2007 Mustang GT
yah i had taken mine off and it def 3M but i used fishing line like emay said and then it takes a while but you can get it all off with some work, i have it back on now tho cuz my daddy got pissed cuz all i did was put caps over the holes but he payed for half the car so i gotta listen
but you should def have no problem doin it and good luck with the whole body kit deal
![]() nothing special |
Threads Similar to: Body Kit Installation Help Needed And Spoiler Removal Help
| Whipple Supercharger - Installation Tips Needed | sechmura | 2005 - 2010 | 1 | June 6th, 2007 08:18 AM |
| Advice on body upgrade to 99 needed | Buddydank | 99-04 | 7 | March 13th, 2007 11:04 PM |
| will a 94' to 98' body style rear end fit under a fox body | frankenstein | 5.0 Mustangs | 3 | July 13th, 2006 09:53 PM |
| spoiler removal | lemon | Visual | 7 | February 28th, 2006 10:07 PM |
