2005 Ford Mustang ( 6cyl. and 8cyl.) TSB's!
Old August 14th, 2005, 04:10 PM   #1
Casper98GT's Avatar
Technical Service Bulletins
2005 MUSTANG - US (English) UPDATED: 6-6-07
07-7-8
RCM FAULT REPORTING USING DTCS AND BIT-MAPPED PARAMETER IDENTIFIERS (PIDS) - SERVICE TIPS
07-5-13
DISCHARGED BATTERIES - VEHICLES IN STORAGE/LIMITED USAGE
07-5-8
BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS
07-4-3
LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE
07-3-9
MIL ON - DTC P0456
07-1-7
MERCONŽ ATF REPLACED BY MERCONŽ V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS
06-26-2
CARPET REMOVE AND REPLACE
06-26-1
MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS
06-25-15
ALUMINUM BODY PANELS - CORROSION - SERVICE TIP
06-22-18
POWER WINDOW DIAGNOSIS
06-22-16
CONVERTIBLE TOP WEAR - BUILT BEFORE 10/11/2006
06-21-19
HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY)
06-21-7
AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES
06-19-12
DTC P0340/P0344/P0345/P0349 - 4.6L 3V AND 5.4L 3V
06-19-8
TICKING AND / OR KNOCKING NOISE / STARTUP RATTLE FROM ENGINE - 4.6L / 5.4L 3V
06-19-2
8.8 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS
06-18-16
IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES - SERVICE TIP
06-17-8
SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
06-15-8
KEYPAD DIAGNOSTICS - DEALER INSTALLED ACCESSORY
06-14-3
AIR CONDITIONER COMPRESSOR CLUTCH FAILURE - REVISED COMPRESSOR CLUTCH
06-12-11
06-10-13
MIL P0463 OR ERRATIC FUEL GAUGE
06-10-10
06-10-1
06-9-9
HESITATION ON ACCELERATION AFTER LONG CRUISE
06-7-10
MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020 - 4.6L 3V
06-5-4
PARK BRAKE CABLE FREEZING/REAR BRAKES DRAGGING
06-4-9
A/C COMPRESSOR NOT OPERATIONAL / LOW FREON - SHAFT SEAL LEAKS
06-4-7
TICKING AND/OR KNOCKING NOISE FROM ENGINE - 4.6L/5.4L 3V
06-4-2
06-4-1
RATTLE/NOISE FROM THE CENTER STACK (RADIO/HEATER) OF THE INSTRUMENT PANEL OR GEARSHIFT AREA
06-3-13
FUEL FILL SLOW, OR DIFFICULT TO FILL
06-2-9
05-24-6
CONVERTIBLE SYSTEM CONCERNS
05-22-8
WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING
05-21-2
05-20-2
REAR AXLE NOISE
05-19-10
LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT
05-18-10
BRAKE NOISE - VEHICLES BUILT BEFORE 3/8/2005
05-16-12
05-15-13
FRONT SIDE MARKER LAMP RETAINING TAB BREAKING
05-15-12
FUEL FILL SLOW, OR DIFFICULT TO FILL - VEHICLES BUILT BEFORE
4/26/2005
05-15-8
05-15-2
GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 2/21/2005
05-14-4
WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
05-10-19
INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS
05-9-18
DISCHARGED BATTERY - CHARGING SERVICE TIPS
05-9-14
CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS
05-9-11
FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
05-9-3
INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
05-8-6
EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION
05-7-3
AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004
05-6-15
AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004
05-3-1
MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
04-26-22
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE
04-26-16
WELD BONDING PROCEDURE
04-24-20
LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS
04-24-14
GENERAL PCM PROGRAMMING PROCEDURES
04-24-5
REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-16-1
ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS
04-9-6
BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
91 LX, 5spd.
Ex:Toyota/Ford tech
Old August 14th, 2005, 04:28 PM   #2
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
Great post.
Old August 14th, 2005, 04:30 PM   #3
Casper98GT's Avatar
Its just something that is a MUST. The 05's as we all know are not the greatest stang ever built. :wink Anyone else needs TSB's RECALLS... Just ask for them and they will be presented.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old February 14th, 2006, 04:05 PM   #4
RoboMax is on a distinguished road
I'd like to see this one, but I don't seem to be able to download?
05-15-8
Old February 14th, 2006, 06:24 PM   #5
L33T is on a distinguished road
Send a message via Yahoo to L33T
Yes great post.
The problem is you have to convince Ford that you are experiencing the issue without mentioning the actual TSB. They absolutely hate it when you go in and say hey I've got TSB blah blah.
I've got one of those TSB's that only rears it's ugly head every so often, but we couldn't produce it at the dealership so I must not have a problem because they weren't hearing that TSB stuff.
Old February 14th, 2006, 07:03 PM   #6
Casper98GT's Avatar
Robo, sorry you cant download, but if you try and put a link to the TSB's Ford has its own secure site and it doesnt work. So i have to put in my "secret" password in when i sign in. But i can email it to you ?
Yeah, they hate it when the customer diag's their own cars. If yes, if we cant produce youre problem, "there isnt one"
I understand how you feel though.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old July 14th, 2006, 05:14 PM   #7
zeplman is on a distinguished road
I have been getting the same error code " P0506 Idle Control System RPM lower than expected" for about a month. The only mod I have done is a Shaker Hood and a custom tune with an X Cal 2 from Blownbyracing out of Fla. This system came with a Oil treated Air filter. Well, I took it to my dealer and they tried to blame the filter and more over claimed it was going to Void my Warranty! Has anyone gotten this code and have a list of possible causes?
Thanks
Old July 14th, 2006, 05:38 PM   #8
What does she idle at?
Do you own the Xcal2?
Have you cleared the code and it comes back?
Take it to a shop, get a dyno graphed custom tune for best results.
Old July 14th, 2006, 06:03 PM   #9
Yes it's the XCal 2, idle just under 1k,cleared it many times. Because the Dealer claimed the filter being at fault I have used the original, the K&N, and a new Motorcraft, same results. Dyno cost $450 :-(
Old July 14th, 2006, 10:10 PM   #10
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Thanks a bunch!
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old July 15th, 2006, 07:20 AM   #11
Send DTP an email. They can get you a good custom tune without taking it to the dyno and it shouldn't cost alot.
Yeah it costs a bit to get a custom dyno tune, but it's soooo worth it. Each application differs a little bit from the next, so without it, you are getting a more 'generic' tune to keep things safe. Once you get a good graph of what your car is doing it can be tuned accordingly.
I've got mine set to idle at 900 and have never seen that code. There must be another switch the computer needs for it to be happy with the lower idle.
From things I've read BBR is still on the fence as being a trusted tuner in our community.
I have nothing negative to say about them, but have read alot of other folks posts who do.
edit: Oh and the problem is in the tune, the car doesn't care what filter you have in place, it's bitching about an idle setting. I'd go back to your mod air filter.
edit2: And if you are really worried about keeping the warranty valid, but still want to mod, you are going to have to find a SVT dealership that installs Ford Racing Performance Parts while maintaining the factory warranty. There aren't alot out there but there are some.
Old July 15th, 2006, 12:29 PM   #12
Okay, thanks for advise! Dropped them an email hope they can help.
Old July 15th, 2006, 01:49 PM   #13
Originally Posted by L33T
Yes great post.
which TSB??
88 Mustang Coupe
www.rickscarcare.net
Old July 15th, 2006, 01:57 PM   #14
Nothing major, I plan on upgrading the brakes anyway and I can't reproduce it at will.
I was just hoping they would see it, but didnt.
Old July 15th, 2006, 02:51 PM   #15
Some 2005 Mustang vehicles built before 3/8/2005 may exhibit occasional brake noise during light to moderate decelerations from speeds below 40 MPH (64 Km/h), often described as a high-pitched squeal or screech.
ACTION:
Install revised rear brake linings following procedures in Workshop Manual Section 206-04. Do not replace or turn rotors, and do not service the front brakes for this condition.
PART NUMBER PART NAME
5R3Z-2200-B Disc Brake Lining
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
If the build date fits your car, I can take care of it for you. Just let me know.
88 Mustang Coupe
Old August 24th, 2006, 06:41 AM   #16
Look Ma! My First Post!
andreas.e is on a distinguished road
We have that on a car over here in Sweden. What is the problem?
Old August 24th, 2006, 07:18 PM   #17
Casper98GT's Avatar
This TSB is basically for technicians. It tells you how to use the FORD specail scan tool and diagnose the bad coil pack.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old September 6th, 2006, 10:09 PM   #18
das50cal's Avatar
das50cal is on a distinguished road
Mine is doing this, does anyone know what this means??
A dealer tried to tell me it was the gears in the trani and they wanted to charge me $1200.00 just to pull it out. I called bullshit and told them no.
I have a vortech on it also and they said that is what caused it so it was not under warrenty blah blah blah.
can anyone help. I was told it might be the t/o bearing also.
it only make a noise around 2300 rpm for like a second and stops??
it does not do it when I am over 2500 rpm???...........
Old September 6th, 2006, 10:10 PM   #19
das50cal's Avatar
granny shifting, not double clutching like ya should. You could win by an inch or a mile...winning is winning.
Old September 6th, 2006, 10:22 PM   #20
Casper98GT's Avatar
ISSUE:
Some 2005 Mustang vehicles equipped with 4.6L engine and the TR3650 manual transmission built before 2/21/2005, may exhibit an intermittent raspy grinding noise while driving in 2nd and/or 3rd gear during deceleration. The noise may sound like a bearing growl, screech or scraping noise. Noise intensity may be light to medium, and is more likely to occur during the first few minutes of warm-up.
ACTION:
Order a synchronizer kit and a snap ring kit. Replace the reverse gear and synchronizer on the main shaft, and the associated snap rings. Refer to Workshop Manual Section 308-03B.
NOTE: METAL SHAVINGS, PARTICLES OR FLAKES FOUND ON THE TRANSMISSION MAGNET ARE NORMAL.
2R3Z-7124-CA Reverse Gear And Synchronizer
4R3Z-7109-AA Snap Rings
Thats the TSB... sound like youres?
It pays 5.5 hours. At our shop it would be about 500. Thats warranty time. We usually multiply warranty time by 1.5 and thats customer pay time. So it still wouldnt be near the money they told you!
91 LX, 5spd.
Ex:Toyota/Ford tech
Threads Similar to: 2005 Ford Mustang ( 6cyl. and 8cyl.) TSB's!
2003 Mustang TSB's Casper98GT 99-04 2 March 3rd, 2011 11:46 PM
2006 Mustang TSB's Casper98GT 2005 - 2010 29 March 9th, 2008 03:30 PM
2004 Mustang TSB's Casper98GT 99-04 2 August 19th, 2006 04:22 PM
