LinkBack (3) | Thread Tools |
#1
May 08 ROTM
2008 Audi S6
Procharged Guys- U Wanna Come In Here
Alright, I'm in the midst of a project of which I've got a few pieces being made but just can't wait to show you guys what I'm doin..
The procharged guys all have one major thing that just sucks about the blower, the air filter is against the damn firewall hovering over a smoldering hot engine.. Enter emay's invention. The Parts not seen right now as I'm having them made: 100 degree angle Inlet tube with welded bung for PCV line, and the just ordered larger 9" long 6" diameter 4"inlet flange K & N filter.. I've found a way to snake dryer duct down along the fender well past the sway bar to right in front of the driver's side wheel. Basically getting me fresh, cold, power making air directly through my cervinis front bumper cut outs. You wouldn't need the bumber, air inlet temperature at the nose of the car with a normal bumper would be significantly cooler before being intercooled even further. Can't avoid using the dryer duct, you need the flexibility for the path, as ghetto as it looks right now, wait to see my finished project, it's going to look slick and fairly un-noticible once done. Shot through the fender: ![]() Apology of this one, I'm shootin pics off the ground best I can to show the new filter location. Ignore my beat up old test filter. The White PVC will be approximately 2" longer prior to heading into the filter.. ![]() The steel hard bracket will hold everything about where the white wire tie is at in this picture: ![]() Shot from up top at inlet point of blower as mentioned previous new custom 100 degree angle inlet pipe will be here so I can gain as much room as possible toward the shock tower before angling down and towards the front: ![]() Once all my custom pieces are back and test fitted, I'm sending em in for powder and I'll have final pics... |
and if u were to be driving through a storm?? (lets say it happens..from what i know ur car is a show car but for others.. dd maybe)
good thinking tho dont forget to dyno after so u can see gains with the cooler air.. |
Big timin' in a small town
Im not a procharger guy but it looks great man
unstoppable @ speed of light
Looks like a good idea, but I'm with jat... What if you get caught in a storm? Maybe some sort of heat/water shield along the bottom and sides, and some drain holes in the bottom of said shield just in case... Just a thought. Still a good idea.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
Very innovative to say the least. Dyno it before and after to look for any gains
May 08 ROTM
2008 Audi S6
I knew you guys would be bringing that up, but the filter is not in direct way of being hit by water. The filter is basically about 6" below the headlamp once bracketed in..
While my car isn't a DD and normally won't be in any rain, I do get caught occasionally. Anyway, I assure you there won't be any hydro-locking going on here. Already accounted for that in positioning things. |
One Man Wolf Pack
Thats a good idea. I was at Advanced the other day and they have fleaxable exhaust tubing that you could use.
![]() ΜΟΛΩΝ ΛΑΒΕ
2007 Mustang GT
13.7 @ 105
Very trick....cant wait to see some dyno #'s
black 07 GT, jlt2 cai, sct2 brenspeed 93 octane tune, UDP's, spydershaft, triax, magnaflow catted x, steeda axleback, bad ass steeda suspensionStealth GT Twin Turbo System On The Way!!!!!!! STEEDA SUSPENSION CREW FOUNDER |
Have you tested the dryer duct hose on any kind of vacuum system? I'd hate to see the plastic get sucked off the hose skeleton and into your engine.
Skirt Chasing Phallus Phondler
Kit Car/Ducati/Explorer
Nike Fast
Nice work Emay, this is a great idea. Definitally should take the IAT down a little, which is definitally a good thing... I cant wait to see your finished product, I know it will look good. Once your done, you should put together a parts list on this...
QUOTE OF THE DAY (5/24/12): “I not only use all the brains that I have, but all I can borrow.” -- Woodrow Wilson |
MM's resident Juice head
07 Mustang GT
I believe that is metal dryer hose he is using.
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
07 Mustang GT
true enough
May 08 ROTM
2008 Audi S6
Already down that path. Hoping the inlet tube can be had for cheap with powder even for those that don't have a hook up.
2005 GT & 69 Mach1
nice man !! If you go to a HVAC supply company they will be able to hook you up with black plastic hose very [FONT='Calibri','sans-serif']similar [/FONT]to the ones on shop vacuums (Flexable pvc). I used it once for the same thing and it works great and looks good as well. good luck and let me know how the project goes
#16 | |
May 08 ROTM
2008 Audi S6
2012 Mustang GT
Cant wait to see the final product and #'s. I was hoping someone would come along and make a fix for this.
2012 Mustang GT - JLT CAI, BBK L/T Headers, BBK X-Pipe, Borla S-Type axle backs, 3.73's *more coming soon* Latest Dyno: 406 rwhp 377 rwtq *need more!* MILITARY CREW
HMC(SW/AW) |
Nike Fast
Hows this coming along there Emay? your leaving us hanging here...
May 08 ROTM
2008 Audi S6
No hanging, just suffering from this damn snow we are getting up here.. No time to get in the garage and work after I plow the damn driveway. Actually there's time, there's no motivation.
I sent the upper intake piece in for powder and prior drilled and tapped that PVC line in. (by the way I got away with using a short 90 degree elbow, rather than a 110). 10 bucks for the stainless tube and I had to plasma cut just a bit off to leave space for getting down in front of the strut tower. I'm trying to also work an oil seperator into the mix so I'm not recycling the blow by back to the throttle body. Honestly my only worry is the dryer duct, but I have a friend whom works at Car X stopping by Friday to let me know if he things he can mock up 3" intercooler tubing with multiple couplers to allow flexing. I'm only worried about the dryer duct because I want it to stay on a specific path and it's ability to move will cause me to use wire ties on it. I'm affraid the wire tires will cut into the duct with engine movement. We'll see.. I'll keep you all in the loop as the parts begin going back in.. I'll also see about getting a pick of the raw inlet tube on here tomorrow. |
Would any sway bar flex cause any issues for that emay?
1998 Trans Am WS6. (Anti Venom) Forged 347, stage 3 T56, and a 76mm Turbo... 659rwhp @ 13.5# ~725rwhp @ 15.5# Meth, C16, and 20psi coming soon 03 Z71 (H/C/I/E/T)...sold 2005 GT, Full Bolt-Ons...12's... GONE |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/44553-procharged-guys-u-wanna-come-here.html
| Procharger guys - WWW.S197FORUM.COM | This thread | Refback | July 18th, 2008 11:29 AM | |
| Procharger guys - WWW.S197FORUM.COM | This thread | Refback | July 17th, 2008 09:34 PM | |
| Procharger guys - WWW.S197FORUM.COM | This thread | Refback | July 17th, 2008 08:40 PM | |
Threads Similar to: Procharged Guys- U Wanna Come In Here
| SRT-4 guys and gals. I wanna know: | homebrewed | The Clubhouse | 63 | October 30th, 2007 05:06 AM |
| Walk-around of the Procharged 05 'Stang | Vabeachmustang | Videos | 2 | April 7th, 2007 01:17 PM |
| Procharged 05... 9.53et | manOwar | Videos | 6 | January 10th, 2007 10:09 PM |
| procharged mustang in car pass 9.30's | Mellon | Videos | 0 | December 1st, 2006 10:34 PM |
| Mustang GT Procharged vs SRT-4 Stage 2 | itschristorres8 | Videos | 5 | November 13th, 2006 07:58 AM |
