Roush Rear Wing
Old December 5th, 2007, 11:38 PM   #1
black07cs is on a distinguished road
Roush Rear Wing
Have any of you installed this yourself? It says that it comes with a template and 3M tape so you can do it yourself.
I really like the looks of it and plan on adding to my car at some point.
I am not a mechanic but have done my own UDP's and suspension, but how much of that thing called "patience" and a steady hand do you need not to screw this up?
If you paid someone how much was it?
Thanks
Old December 5th, 2007, 11:39 PM   #2
Regency 2007's Avatar
F-150 FX4
Regency 2007 will become famous soon enough
are you a good artist? That should answer your question if you need to put it on or a body shop, paint shop...
Old December 5th, 2007, 11:42 PM   #3
Artist? Hell no. I am all about the impact wrench and a cold one.
It comes painted to match so it is tempting given that they send a template, but it is 3 piece and I could see how it could be screwed up.
Old December 6th, 2007, 12:08 AM   #4
Wado is on a distinguished road
I did mine, it wasn't to bad.
Old December 11th, 2007, 05:33 AM   #5
SchatzieII's Avatar
SchatzieII is on a distinguished road
Roush Wing
Lightly center tap holes on side. Remove masking tape on wing that were painted, almost missed those holes. Takes more time getting wing and gasket off then installing it. Touch up all holes drilled with primer and seal with silicon. Do not leave any burrs or filings around as they will rust immediately through paint. Best wing out there!
Old December 11th, 2007, 05:39 AM   #6
Pastor J is on a distinguished road
I love my wing. Mine came with it but I've seen a few installed and even I could do it, which is saying a lot.
www.mustangministries.net
Old December 11th, 2007, 09:53 AM   #7
Gunny's Avatar
Gunny is on a distinguished road
I installed mine (as well as the hood scoop) myself. The templates Roush provided are excelent and simply match to known locations on your car. Just tape them down with painters tape and measure and re-measure to make sure everything is even. Like the post above, center-punch each hole prior to drilling so the drill bit doesn't slip. All-in-all, this was an easy install. Just take your time and you'll be proud pof the work you did yourself. The most tedious part was cutting out the damn templates.
2006 GT 5 Speed Convertible
Whipple HO SC (461 RWHP / 444 Torque)
4.10 Gears
Pypes O/R H-Pipe
Borla Stingers Cat Back Exhaust
Various suspension goodies
For more info, visit: http://www.themorgansite.com/Mustang/mustang_info.htm
Old December 11th, 2007, 09:23 PM   #8
Thanks for the info. I was hoping it wasn't too bad. It is a sweet looking wing
Old December 12th, 2007, 02:27 AM   #9
Moses's Avatar
2005 Mustang GT
Moses is on a distinguished road
It's very easy to do .. just take your time and you'll be fine -- you really can't mess it up as it has a template to follow
Threads Similar to: Roush Rear Wing
Rear wing and side badges mustang fanatic 2005 - 2010 6 August 21st, 2007 05:02 PM
03 cobra rear wing jfizzle02 5.0 Mustangs 2 July 19th, 2007 09:38 AM
Roush Wing Bayouboy4.6 2005 - 2010 2 May 6th, 2007 11:23 PM
Rear Wing Spoiler V6RedMustang Visual 5 March 4th, 2007 09:25 PM
rear wing question JASonic V6 Mustangs 43 March 4th, 2007 06:56 PM
