Tire Rot
Old December 7th, 2007, 09:56 PM   #1
2005 GT & 69 Mach1
rxnodoze02 is on a distinguished road
Tire Rot
I was looking at my tires when i noticed that they had small little cracks in them on the sidewall and in the treads. Its not a serious case but you can notice it when you look at the tire. They are the stock tires that came with the car but its only an 05 and has 21,400 miles on the car. I just wanted to hear some opinions on asking the dealer to replace the tires for me bc i still have the bumper to bumper warranty on the car and i figure the tires have to be covered for 35,000. let me know what you think
Old December 7th, 2007, 10:19 PM   #2
Modern_Muscle's Avatar
Modern_Muscle is on a distinguished road
Send a message via AIM to Modern_Muscle Send a message via Yahoo to Modern_Muscle
tires are a wearable part, no replacing buddy.
that could just be stress.
my first set were stressed from so much cornering and high speed that the tread wanted to peel, but then again, they were all season tires.
my nittos are perfect tho.
1998 Trans Am WS6. (Anti Venom)
Forged 347, stage 3 T56, and a 76mm Turbo...
659rwhp @ 13.5#
~725rwhp @ 15.5#
Meth, C16, and 20psi coming soon
03 Z71 (H/C/I/E/T)...sold
2005 GT, Full Bolt-Ons...12's... GONE
Old December 8th, 2007, 08:54 AM   #3
2005 GT & 69 Mach1
Wearable is different from defective.
Old December 8th, 2007, 10:35 AM   #4
TheUNZippee!'s Avatar
Tires are typically not covered under warranty but the dealer will make exceptions depending on the issue. Normal wear is not covered. If say, you had a broken belt in a tire, they would then MAYBE give you warranty, and even then you would only get a percentage of the tire based on wear. I know this to be true because I've had this happen to me with my last Ford.
It will also depend on your dealer & service manager. I would say that cracks in your sidewall would be considered normal wear by the dealer, particularly if your car sits outside in the sun for long periods of time.
All you can do is go by the dealer and ask, but I would doubt if they cover them. If you get lucky and they do, it will be based on a percentage of wear on your tire(s).
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old December 8th, 2007, 11:08 AM   #5
IBEATU
stanglifemike's Avatar
06 GT, 98 GT, & 93 Notch
stanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nice
Yea, what Zip said
98 GT: some stuff
06 GT: more stuff
93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper
Paxton/Vortech Crew Member #3
FRPP's #1 Dealer
Injected Engineering
BMR Suspension
Old December 8th, 2007, 12:15 PM   #6
2002 BMW 530i
don't know and don't care
Luis_GT is a jewel in the roughLuis_GT is a jewel in the roughLuis_GT is a jewel in the roughLuis_GT is a jewel in the rough
Send a message via MSN to Luis_GT
Earth to rx... you have 21,400+ miles on your tires... they are not defective... they are used up... Big difference...
Old December 8th, 2007, 12:27 PM   #7
I had 18000 miles on my tires when they gave me partial warranty on 3 tires for broken belts in them.
Old December 8th, 2007, 12:52 PM   #8
2002 BMW 530i
broken belt =/= as normal cracks which could be a cause of running on low PSI, or not maintaining the tires.
Old December 8th, 2007, 01:04 PM   #9
This was my point to him in my initial post. That the service manager will determine the decision on it. Most would call that normal wear, but it depends on how bad it is. Tires with only 21000 miles on them should be worn, but they should not have cracks in the sidewall.
Old December 8th, 2007, 01:05 PM   #10
2002 BMW 530i
Mine will be waisted before they reach 10,000 miles
Old December 8th, 2007, 01:10 PM   #11
I managed to get almost 25k on mine, although the fronts are now just about done, as I actually do more corner carving than I do launching.
Old December 8th, 2007, 01:11 PM   #12
2002 BMW 530i
mine are equaly used... weird...
Old December 8th, 2007, 01:12 PM   #13
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
I find my 235's pushing big time when I corner i little aggresive....Now that Zip enlightened me on my 18 x 8.5!! rims ive been looking for tires for all four corners AGAIN!
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old December 8th, 2007, 01:14 PM   #14
2002 BMW 530i
I understeered last night around a corner... why that sucked...
Old December 8th, 2007, 01:17 PM   #15
07 STROKER's Avatar
07 Mustang GT
crapy huh?
Old December 8th, 2007, 01:19 PM   #16
2002 BMW 530i
Stock BFG 235/50/18's FTMFL!
Old December 8th, 2007, 01:20 PM   #17
before, with the factory height tires, my handlign wasnt that great.
but after putting the 275 40s on front and 315 35s on the back, it lowered the car what seems like an inch, and drastically helped the handling.
before, I could go over speed bumps with no problems.
Now, I felt the tranny hit one, so i have to go around.
these nittos grab more with gas into the corners, than just coasting around.
659rwhp @ 13.5#
~725rwhp @ 15.5#
Old December 8th, 2007, 01:20 PM   #18
Nitto FTMFW
oh and BFG too
659rwhp @ 13.5#
~725rwhp @ 15.5#
Old December 8th, 2007, 01:21 PM   #19
07 STROKER's Avatar
07 Mustang GT
ya but how wide are your rims Modern...you dont have 275's on the front stock rims do you?
Old December 8th, 2007, 01:21 PM   #20
2002 BMW 530i
I'm going for some nittos... the normal ones, not the DR's though.
Threads Similar to: Tire Rot
Tire burin_rubber V6 Mustangs 38 November 28th, 2007 06:28 PM
Tire Help... Onemanzu The Clubhouse 29 October 13th, 2007 06:28 PM
Tire ? Psychojimmy 5.0 Mustangs 7 October 12th, 2007 11:15 PM
Tire and rim help hubba076 99-04 20 July 10th, 2007 03:46 PM
Tire for 03 GT donny82277 General Tech 0 January 25th, 2007 05:59 PM
