Dumb Question
I want to kno how the tire size can change ur gear ratio??
Skirt Chasing Phallus Phondler
Kit Car/Ducati/Explorer
Nike Fast
![]() There you go... I was feeling slightly artistic...
QUOTE OF THE DAY (5/24/12): “I not only use all the brains that I have, but all I can borrow.” -- Woodrow Wilson |
2005 Mustang GT
10.32@137.70
the tire is just like gears the shorter tire has less distance to make a complete revolution than a taller tire, it changes the effective gear ratio from the trans,rear gears, and tires
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system 326 cubic inches of Twin Turbocharged hell will be running soonTuned by Wes @ TPS ![]() |
2007 Mustang GT
that picture is sexy
So 18s vs 17s, which one would be better accelerating, and which one better for top end speed?
2006 GTO 6 spd Black on Red SLP Loudmouth I catback SLP Blackwing air filter SLP Predator 93 Diablo Tune Jamesbiz Catch Can |
17's better acceleration and 18's for better top end
![]() JLT CAI: KOOKS LT's: Comp NSR II's: 4.56's: TR6060: Steeda LCA, UCA: QA1's: Roush rear springs...see garage for more. |
2007 Mustang GT
a tire with a smaller diameter will produce higher torque whereas a larger diameter will allow for a higher top speed... but, what i'm not sure of is, does the outer diameter of the tire change though when moving from a 17" to an 18" wheel, or do you just put on a lower profile tire with the same outer diameter?
2005 Mustang GT
10.32@137.70
as long as the diameter stays the same nothing changes in the gear ratio
Example- 255/50/17- 27.4" tall 285/40/18- 27.4" tall the rim is bigger but they use a shorter sidewall tire to keep the height the same. Those numbers are not accurate, i just pulled that out my ass so don't take those numbers literally
2007 Mustang GT
ok, that's what i wasn't sure of, if the total tire height changes from a 17 to an 18. im assuming the jump to a 20 tho changes the tire height?
went from the stock 17" to 20" and have the same diameter due to low profile tires
316rwhp 333rwtq ![]() STEEDA-UDP's CMRPDelete 90mmCAI 4.10's SCTLivewire Hurst Spydershaft 20"Razors Edelbrock Bassani-XPipew/Cats & Axlebacks Hurst Crew Member #4 |
Threads Similar to: Dumb Question
| dumb question | sb2f5marine69 | 5.0 Mustangs | 2 | July 11th, 2010 10:29 PM |
| might be a dumb question.... | usmcsawgunner | 5.0 Mustangs | 22 | October 9th, 2007 03:46 AM |
| Dumb question | MnrlGry01gt | 99-04 | 33 | June 16th, 2007 11:31 PM |
| dumb question here =/ | Dustinv420 | V6 Mustangs | 4 | March 11th, 2007 10:43 PM |
| dumb question | antv20 | General Tech | 4 | February 27th, 2007 09:05 AM |
