Trunk Release Button Mod
Old December 19th, 2007, 10:27 AM   #1
partsbill's Avatar
partsbill will become famous soon enough
easy mod to do yourself. I used OEM part# 3W7Z 9B242 AA retail $15.58 or you can use a momentary push button switch (McMaster Carr P/N 6915K22 or Radio Shack Cat # 275-646), and solder two leads to it.
Next, Squeeze the sides of the glove box and it flips down. This will give you access to mount the switch. Drill a hole in the glove compartment box. Note there is a metal bar behind the right side of the glove compartment box. There is one spot that has a hole in it. Drill the hole in the plastic to match up with this hole. My button was 1/2" so I used a uni-bit that went up to 1/2"
Remove the retainer nut from the switch and insert the switch and the leads into the hole. Thread the leads through the nut and onto the switch and tighten the nut up. Next, attach one of the leads to ground. I loosened one of the ground bolts all ready in the glove box and attached the lead to it and retightened.
Next pull off the kick panel on the passenger side, just lift up on the cover and pull off the cover. Find the large wire harness and unwrap enough of the tape to reveal the wires. Find the skinny White wire with a pink stripe. This is the one we will be using. Carefully strip a small piece of insulation off this wire without cutting it. Strip a piece of insulation off the remaining lead from the switch and tightly wrap it around the exposed copper on the White/pink wire. Test your switch, You can solder this connection if you’d like or just tape it up really good.
When finished, rewrap the wire bundle with electrical tape and place it back as it was. Replace the cover and the glove compartment box.
Note that if the switch you chose is too big, the trunk might open sometimes if you slam the glove compartment box or if your knee hits the corner of the glove compartment door.
If this is a problem, replace the rubber bumper on the glove compartment door with one that is a little larger and made of a harder rubber. Ace Hardware or Home Depot should have these
06 Black GT 5sp/JLT II CAI/XCALSCT2/B a m a 93 Oct Race Tune/FRPP Stingers/Hurst Shifter/GT500 Spoiler//Steeda ultralite Springs & rear pan hard rod/Bullitt Strut tower brace/07 Gt manifold cover/Shelby Lip/Sequential
HURST CREW MEMBER #17
Old December 19th, 2007, 10:31 AM   #2
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
so the 05+ didn't come with the button already in the glove compartment??
2008 Acura TL-S - 2008 Honda Pilot EX-SE
Old December 19th, 2007, 10:35 AM   #3
partsbill's Avatar
yea, no button 2005 +, which really isn't a problem for couple owners that lock their keys in the trunk because you can fold down the rear seat, convertible owners can not fold down the rear seat, so unless they have their spare key fob close by it's time to call a locksmith.
Old December 19th, 2007, 10:38 AM   #4
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
iTrader: 10 reviews
huh. that's wierd that they would leave the little option out of the new stangs. i love having mine in my 04
Old December 19th, 2007, 10:45 AM   #5
tsp_2177's Avatar
2005 Civic
GAY!
tsp_2177 will become famous soon enoughtsp_2177 will become famous soon enough
yeah pissed me off when i found that out about my car, but i have a walkthrough somewhere saved, that redfire gave me...
let me see if i can find it.
it has pics too!
slow car member twinky times two
the stangs gone
pypes mid muffler catback with their X-pipe
In the top 20 cool peoples list on MM
potsticker in training
Old December 19th, 2007, 10:47 AM   #6
tsp_2177's Avatar
2005 Civic
GAY!
here we go enjoy! i haven't had time to actually do it yet but it looks like its pretty much straight forward.
the stangs gone
Old December 19th, 2007, 10:49 AM   #7
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
iTrader: 10 reviews
nice find
Old December 19th, 2007, 10:52 AM   #8
tsp_2177's Avatar
2005 Civic
GAY!
thank you thank you, redfire gave it to me now i just have it saved if needed lol
the stangs gone
Old December 19th, 2007, 12:56 PM   #9
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
*pats self on back*
ΜΟΛΩΝ ΛΑΒΕ
Old December 19th, 2007, 03:06 PM   #10
tsp_2177's Avatar
2005 Civic
GAY!
the stangs gone
Old January 3rd, 2008, 06:21 PM   #11
Look Ma! My First Post!
2005 Mustang GT
LouMcIntosh is on a distinguished road
Unhappy
Tried
I found a white/pink stripe wire and tested it by grounding it with a test lead. Nothing happened? I would very much like to make this work!
Help
Old January 3rd, 2008, 06:32 PM   #12
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
In the little compartment in the passenger side footwell, the white wire with a pink stripe should be the one. Try it again and hit the button on the remote to open the trunk. See what happens.
ΜΟΛΩΝ ΛΑΒΕ
Old January 3rd, 2008, 08:15 PM   #13
Pastor J is on a distinguished road
Thanks for posting this. This seems like an easy enough install and I can't count the number of times that I've wanted something out of the trunk in the garage but not had the keys with me.
So where did you get the OEM part from? Online or at the dealership?
www.mustangministries.net
Old January 3rd, 2008, 08:47 PM   #14
partsbill's Avatar
I work at a Ford dealership so I bought the switch there, but a easier solution to getting into your trunk when you don't have your keys is this.
just enter your 5 digit code, press the 5/6 button and your trunk opens.
Old January 3rd, 2008, 09:04 PM   #15
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
Hoiw much did you pay for that? And does it just stick on the inside of the fuel door?
ΜΟΛΩΝ ΛΑΒΕ
Old January 3rd, 2008, 10:02 PM   #16
psycho bob's Avatar
07 GT
12.86@104
psycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to all
Send a message via Yahoo to psycho bob
it sticks any where you chose to put it. just like other cars that come with similar key pads.
https://www.tituswillfordparts.com/i...acturers_id/38 here ya go. look at the bottom. $72.89
Originally Posted by RZNCAIN View Post
I didn't check for spelling so fuck off with your grammar police.
http://www.moddedmustangs.com/forums...build-bob.html
Old January 3rd, 2008, 10:14 PM   #17
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
Hmm, I know I use it all the time on my Expedition.
Thanks for the link.
ΜΟΛΩΝ ΛΑΒΕ
Old January 3rd, 2008, 10:16 PM   #18
psycho bob's Avatar
07 GT
12.86@104
you wouldn't have to worry about locking your keys either. cost about the same as a locksmith in some places.
Old January 3rd, 2008, 10:20 PM   #19
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
Good point, and you wouldn't have to bother with the trunk button.
ΜΟΛΩΝ ΛΑΒΕ
Threads Similar to: Trunk Release Button Mod
Sticking Gas Cap Release Button (Glove Compartment) Blown5.0 5.0 Mustangs 23 December 2nd, 2007 09:06 PM
hey is there a button BWAL The Clubhouse 1 September 12th, 2007 08:58 PM
trunk release button 06RedfireGT 2005 - 2010 32 July 11th, 2007 08:24 PM
Where is inside trunk release on 2006 Convert Roush? cobralini 2005 - 2010 3 August 31st, 2006 10:02 PM
