LinkBack (1) | Thread Tools |
#1
2007 Mustang GT
Double Clutching?
OK, possibly a stupid question. I recently read an article on double clutching, where it says to depress the clutch, shift to N, release the clutch, tap the gas, depress, shift to lower gear, release.
This is my first manual car, but when I downshift I've been just skipping the 2nd 'clutching', meaning i depress, then tap the gas as i'm shifting to match RPMs, release. Is there a big difference btw the 2, and if so what is it? |
<quote = "wikipedia">
The purpose of the double-clutch technique is to match the rotational speed of the input shaft being driven by the engine to the rotational speed of the gear you wish to select (directly connected to rotating wheels). Once the speeds are matched, the gear will engage smoothly. If the speeds are not matched, the dog teeth on the collar will "crash" or grate as they attempt to fit into the holes on the desired gear. A modern synchromesh gearbox accomplishes this synchronization automatically. </quote> source = Double clutch - Wikipedia, the free encyclopedia The biggest concern of people I have talked to about this is wearing out the clutch. By using the clutch twice per shift you will wear it out quicker. However, you can do a lot more damage to it by rev'ing up the engine real high and dropping the clutch. So I say if you want to (or are used to) double clutch, than go for it, otherwise don't worry about it.
too close for missiles... i'm switching to guns |
#3 | |
http://www.youtube.com/v/GMc2RdFuOxI&rel=1
![]() 2007 gt (blue devil) 4.10 gears airaid cai cmc delete plates bassani ss offroad x frpp GTA axle backs cdc shaker hood 302 rwhp 322 rwtq tuned by dayton performance |
One Man Wolf Pack
Double clutching is also called "heel and toe" but it isn't neccessary with these cars.
![]() ΜΟΛΩΝ ΛΑΒΕ
2007 GT
Only time i ever thought real double clutching was nescessay was old semi's.
Heel toe is different in that it is for racing. downshifting going into a turn it is nescessary, left foot on the clutch right heel on the brake, toe on the gas, bump the gas when you shift to avoid wheel hop. It is never needed or even advantagous in up shifting. |
just dont left off the gas, and forget about the brakes.
2007 Mustang GT
ok im still a little confused. so is what im doing considered double clutching or not exactly?
#8 | |
2008 Mustang GT
![]() I currently have a Scion tC (that I'm trading in next week on a Mustang GT!) and it doesn't have a synchro in reverse. First few hundred miles driving it I was accidentally mashing gears whenever I put it in reverse - darn thing has to be completely still before dropping the stick into reverse - even with the clutch all the way to the floor. ![]() The car I had before the Scion had double synchros on a 6-speed and spoiled me to no end. I'd never let the clutch out in reverse until I was dead still, but I'd at least drop the stick into reverse while coming to a stop.... Synchro gears are nice.
#9 | ||
2008 Mustang GT
Does that make it clutching or single clutching? I dunno, as long as it's not crunching I think you're ok.
2007 Mustang GT
alright good as long as im not hurting anything i'm happy
2007 Mustang GT
thanks again
2005 Mustang GT
10.32@137.70
if you want to learn go watch Fast and Furious again
326 cubic inches of Turbocharged hell will be running soon Tuned by Wes @ TPS ![]() |
#13 | |
actually, thats wrong... Heel toe is rev matching but you only depress the clutch once as if you where down shifting normaly, I do it all the time and its a lot better than normal downshifting as it doesn't jerk the car to a halt waiting for the revs to pick up. |
#14 | |
I do it the other way... My heel on the gas and my toe on the brake. |
#15 | |
2007 GT
Good luck with that on a track luis
![]() push the clutch in, take it out of gear, tap the gas go into the next gear, it is still one smooth shift though. this is not something you have to do on the road though. But yea if you are going really fast at high rpms and now want to downshift for a turn you need to do it or else the wheels will hop and you will spin out. And the point of the heel on the brake is that you are pushing hard on the brakes to slow for the turn while you are shift. |
Skirt Chasing Philanderer
Kit Car/Ducati/Explorer
Nike Fast
Double clutching is a thing of the past. There is no need to double clutch in our cars thanks to the syncros... Mustang forums are more informative than the movies, I know Vin Diesel and Paul Walker look like they know what they are talking about but they are reciting a script written by some egg head in an office that has driven festivas and metros his whole life. Kind of like how all the cars in the movie are 10 sec daily drivers that they built off of what they made delivering pizzas...
Might want to consider writing down what is said above, it will help you at some point or another in your life!
satans movie
KB'd GT
Wow! You must have some skills, my foot wont bend like that. I keep my foot at about a 45* angle pushing the brake with the center of my foot, then blip by rolling my foot onto the gas. The good thing is when you are braking hard the gas is right there.
Wiki source When a driver performs a heel-and-toe downshift, they will first use the ball of their right foot (toe) to depress the brake pedal and slow the car down sufficiently.After that, the driver lets go of the clutch and rotates their right foot to operate the throttle with the outside edge of their foot (heel), increasing the engine rpm to match the required rpm for the selected gear.
#20 | |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/48167-double-clutching.html
| YouTube - Bullitt - Steve McQueen Famous Car Chase | This thread | Refback | January 10th, 2008 04:43 AM | |
Threads Similar to: Double Clutching?
| First Double Green Rep | mdvaldosta | The Clubhouse | 33 | November 30th, 2007 02:15 PM |
| Double DIN in 99-00? | energiesource | 99-04 | 2 | May 4th, 2007 11:10 AM |
| Is double clutching still relevant? | torquecars | Racer's Corner | 79 | April 20th, 2007 04:57 PM |
| Power shifiting, granny shifiting, double clutching? | dmachine22 | Modular Mustangs | 18 | February 21st, 2007 11:41 AM |
| clutching times | inthered03 | 99-04 | 2 | January 29th, 2007 01:40 AM |
