Spydershaft Rubbing On Tri-ax Shifter
Old December 29th, 2007, 04:37 PM   #1
05mustang_TT_charged's Avatar
2005 Mustang GT
10.32@137.70
05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough
it sounds and feels like the driveshaft are making contact under hard acceleration. when the car squats it has a rubbing sound coming from under the shifter, and i can feel it in the shifter when i hear the noise.
anyone else have this problem? how did you fix it?
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system
326 cubic inches of Twin Turbocharged hell will be running soon
Tuned by Wes @ TPS
Old December 29th, 2007, 04:43 PM   #2
06GT4RAD's Avatar
2006 Mustang GT
06GT4RAD will become famous soon enough
Get in touch with Mr. Spyder and see what he says. I am certain he will have a solution for you.
2006 Mustang GT-Borla Stingers, MGW Billet Interior & Underhood, Eibach Pro Kit w/Tokico D-Specs, Steeda Sway Bars, CHE Suspenson Upgrades, BBR Billet Control Arms, Foose 20" Nitrous, BFG g-Force KDWII
Old December 29th, 2007, 06:11 PM   #3
kenneth's Avatar
2006 Mustang GT
11.45@123.61
kenneth has a spectacular aura aboutkenneth has a spectacular aura about
Do you still have the stock upper control arm?
I want to say I read somewhere that a few people were having problems with the stock UCA, switched to the adjustable UCA and it ended their problems.
they claim it was due to the flex of the rear end under pressure.
Stock for now.
Old December 29th, 2007, 06:35 PM   #4
Gunny's Avatar
Gunny is on a distinguished road
Are there any marks on your drive shaft indicating something hit it? I bought the BMR adjustable UCA and it works fine. On my car, when I firt put my blower on and launched it, the driveshaft made contact with a piece of metal in the drive shaft tunnel. I "fixed" it my molding the metal. Later, I got the UCA. Likely that would have fixed it. I don;t know if any of this helps, but it's what I did.
2006 GT 5 Speed Convertible
Whipple HO SC (461 RWHP / 444 Torque)
4.10 Gears
Pypes O/R H-Pipe
Borla Stingers Cat Back Exhaust
Various suspension goodies
For more info, visit: http://www.themorgansite.com/Mustang/mustang_info.htm
Old December 29th, 2007, 08:19 PM   #5
TASSY5's Avatar
2007 Alloy GT
TASSY5 is on a distinguished road
Send a message via AIM to TASSY5
Mine rubs upon hard launches or hard braking. Seems to be hitting the Exhaust on decell when hitting the brakes hard and on the hard one in a while launch it must be rubbing the UCA.
I am putting the Steeda Billit NA Lowers and a Adjustable upper control arm. Should cure the problem.
2007 Alloy GT. 5 speed, Spydershaft, MGW shifter, 3.55 gears, Sequential tail lights, C 300 Cervini's Full Body Kit, CDC Hood Struts, Whipple HO.SC. 468 SAE RWHP 450.44 RWTQ
Old December 29th, 2007, 08:59 PM   #6
2005 Mustang GT
10.32@137.70
[/quote=spyder7724;1041807]yeah John I've heard about that a few times from different people. other than the saleen short throw adapter I've not heard of any shifter clearance problems with the driveshaft itself just the loops.
BJ..just wondering a little about the car, d/s loop? if so what type? does it happen in every gear? are there any marks on the driveshaft? (also look at the rubber boot covering the slip joint on the driveshaft cause the shifter arm is in this area). if so where are they? have you upgraded any of the rear suspension other than the springs? if you have a stock UCA with that much power it's probably just rotating the rear end housing too much and making contact when you are under hard acceleration.
call or email if you need anything.[/quote]
straight from the makers fingers, i will put my control arms and pan hard bar on this week
Tuned by Wes @ TPS
Old December 29th, 2007, 09:41 PM   #7
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
That will most likely cure ethe problem.
ΜΟΛΩΝ ΛΑΒΕ
Threads Similar to: Spydershaft Rubbing On Tri-ax Shifter
spydershaft Bhblondguy The Clubhouse 31 October 27th, 2007 03:29 AM
rims rubbing sway bar... screwthisname V6 Mustangs 14 September 5th, 2007 02:06 PM
Just installed Mac pro dumps.. sounds like rubbing?? Timm10221 99-04 4 August 15th, 2007 01:20 PM
exhuast rubbing against tire jersey98gt 96-98 3 June 24th, 2007 03:21 PM
rubbing and clicking noise Warlord Modular Mustangs 2 January 7th, 2007 01:47 PM
