Whipple or kenne bell - Page 2
Old January 1st, 2008, 11:16 AM   #21
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
I wouldn't put more than 460rwhp. They can take more than 430, as long as you have an excellent tune.
ΜΟΛΩΝ ΛΑΒΕ
Old January 1st, 2008, 12:21 PM   #22
05mustang_TT_charged's Avatar
2005 Mustang GT
10.32@137.70
05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough
they don't recommend it because they have a lot of belt slip issues when they try running some boost through it, plus that magnacharger is an hEATON based design(ROOTS) so it isn't very efficient.
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system
326 cubic inches of Twin Turbocharged hell will be running soon
Tuned by Wes @ TPS
Old January 1st, 2008, 12:30 PM   #23
MaverickMLFD371's Avatar
2005
MaverickMLFD371 will become famous soon enough
Send a message via AIM to MaverickMLFD371 Send a message via Yahoo to MaverickMLFD371
whipple!!
Old January 1st, 2008, 12:32 PM   #24
2005 Mustang GT
10.32@137.70
Originally Posted by MaverickMLFD371 View Post
whipple!!
ELECTRIC SUPERCHARGER FROM EBAY FTMFW
Tuned by Wes @ TPS
Old January 1st, 2008, 12:37 PM   #25
catchtheroadrunner's Avatar
catchtheroadrunner will become famous soon enough
The article had nothing to do with belt slippage or the type of charger being used. The consultant clearly felt that 430hp was the max number that he felt was unquestionably safe. That's not to say that 500hp isn't safe on any particular car. I think what he meant was that beyond 430, the safety factor is out of your hands and more at the mercy of unknowable flaws present in any large chunk of metal. If the alloy in your crank was mixed more thoroughly than mine, if yours cooled more evenly, your crank will take more HP than mine. Same for the rods, pistons, etc..
I think!!!
Old January 1st, 2008, 12:47 PM   #26
2005 Mustang GT
10.32@137.70
i am sorry, i miss read the post and thought it was in reference to there supercharger, i did a lot of reading and waiting for there supercharger and was planning on getting it till i seen it and talked to someone that used to work there. he told me that for what i eventually wanted to end up with there ste up wasn't gonna cut it.
i think 450 rwhp is the limit for 06+ 3v's
Tuned by Wes @ TPS
Old January 1st, 2008, 01:28 PM   #27
Wado is on a distinguished road
intake temperature will limit boost from heat of compressed air, if you have 175 degree air entering motor it will pull timing to surpress detonation, so figure the air under the hood being sucked into the supercharger is 120 degrees and the supercharger compresses the air and the temp rises to 175 degrees and goes through the intercooler and air temp drops to 120 again and you are running 20 degrees of timing, then the computer will pull some timing because of the hot air, if you could get 70 degree air into the blower and when compressed it is 125 degrees and after the intercooler it is 80 degrees then the 20 degrees of timing will not be affected.
the more timing, air, and fuel you can get into the motor the more horsepower, my car only makes 427 rwhp at 16 degrees of timing, yet with 23 degrees it makes 466 rwhp, that was proven on back to back runs on the dyno with the same tune except we put 7 degrees of timing into the car and and picked up 39 rwhp from 7 degrees of timing
Absolutely correct and when I can't put out more HP then the motor can handle due to the temp I'll get interested. All I'm saying is that it has no bearng here because the whipple easily makes more HP then the motor can take. The Whipple is extremely effecient just compare a 10psi motor on KB to a 10psi motor on KB. If you can show me significant difference then it matters.
Old January 1st, 2008, 02:10 PM   #28
2005 Mustang GT
10.32@137.70
it doesn't mean much in the lower boost applications, 8-15 psi. but when you start running 20-25 psi. it does make a difference.
but there are no significant differences, both have the best intercooling systems for the twinscrew superchargers
Tuned by Wes @ TPS
Old January 1st, 2008, 03:22 PM   #29
06VistaGT's Avatar
2006 Mustang GT
06VistaGT will become famous soon enough
Either the Whipple or KB kit would be badass, but I wouldn't push more the 9psi on stock internals.
Dyno vid: http://youtu.be/TkxUrW-mpBw
Threads Similar to: Whipple or kenne bell
Which One... (Whipple or Kenne Bell) mustangrebuilder General Tech 13 November 29th, 2007 09:09 AM
Kenne Bell hellbred07 2005 - 2010 34 November 9th, 2007 06:33 PM
clutch change with whipple,kenne bell, roush 05mustang_TT_charged 2005 - 2010 15 July 15th, 2007 11:25 AM
kenne bell punkafi888 General Tech 43 April 4th, 2007 03:52 PM
Kenne Bell 03blownmach1 99-04 11 June 28th, 2006 01:04 AM
