Whipple or kenne bell
i am going to get a supercharger but i am not sure witch one to go with. after researching i narrowed it down to the whipple or kenne bell. what is your apinon about these
I would go with the Whipple HO kit. It comes with everything you need. Only thing you may need are different spark plugs. Contact Gunny or Grabber523 on that issue. Pretty sure theres others on here with whipples. Also gauges to keep a check on everything. Good luck
07 GT-- Gone But Not Forgotten Military Crew E-5
2006 Mustang GT
+1 on the Whipple. The kit comes with absolutely everything you need. The KB is badass but would require more work and money to get running right. I am probably gonna strap on Whipple once i get back home.
2008 Mustang GT
I'm ordering the Whipple in a week. I was hoping to go with the 500hp kit, but I don't have the extra $1500 ( that's for installation
)I think they are both very comparable, but I like the looks of the Whipple, honestly, over the KB. Seems easier to upgrade to the 500 kit, too.
SMR #0513 |
#5 | |
2006 Mustang GT
If the KB came with a more complete kit like the Whipple i would probably get it. I've always heard good things about KB. +1 usafimj on getting the HO kit. Get it all done right from the start.
2008 Mustang GT
I have a stock GT. Can you bolt the 500 kit right on to a stock motor? I've heard contradicting things...
To be honest, I would rather do that!
SMR #0513 |
06 GT
35.9@15.5MPH in reverse
between KB and Whipple, which one has a more pronounced whine to it?
In order to live, you must be willing to die. 06 Torch Red GT: pypes axleback, Kooks LT's, o/r H pipe. JLT bama 91 Race Tune, 4.10's |
You should be able to bolt up the 500hp HO kit. Just dont get to close to the 500hp mark cuz then your pushing it with the internals
I don't know about a Whipple but my KB 2.6 really doesn't make that much whine,in fact it is more of a whooop. the only time you can hear whine much is at idol. I didn't have to buy anything extra to install this SC. It came complete as well.
One Man Wolf Pack
I would say the Whipple because it has the same capability as the KB, but the HO kit is more complete because it comes with the GT500 fuel pumps, where the KB has the BAP.
![]() ΜΟΛΩΝ ΛΑΒΕ
I would highly recommend the Whipple its quiet and the kit is very complete. The quality of this kits is OEM level Whipple worked with Ford on this product and it shows.
The air cleaner set up on the KB was a real deal breaker for me, you have to cut the core support and hang the air cleaner out in the breeze. I found the Whipple design to be a much more elegant solution. |
2005 Mustang GT
10.32@137.70
326 cubic inches of Turbocharged hell will be running soon Tuned by Wes @ TPS ![]() |
#14 | |
2005 Mustang GT
10.32@137.70
![]() another thing everyone is complaining about complete kits. if you do not get everything you need in the kit to put the car together and drive it then it isn't a complete kit. the whipple kit comes with a GT500 fuel pump setup and kenne bell uses a boost a pump, well guess what they BOTH provide you with fuel needed to support the horsepower. (SORRY) there is no 2 ways about it, they took different roads to get the problem fixed and guess what they both did. i did not have to purchase anything for my kenne bell kit, I opted to buy new colder plugs but they weren't mandatory. nothing against whipple and don't want to sound biased to kenne bell but unless something changed the whipple is a 2.3l and the kenne bell a 2.6l, which makes the kenne bell more efficient because it is a larger displacement compressor. i like the whipple kit because you don't have to cut into your main wiring harness like the kenne bell kit. i also like that the whipple doesn't need an upgraded housing 2.6l "S" (8-14psi.) and 2.6l "H" (15-24psi.) to up the boost into the higher boost range. but i do like that kenne bell does offer 2 kits and makes the higher boost kit more efficient when running higher boost. that is all i can think of for now.
i say both whipple and kenne bell are
fantastic kits. most anyone , would be happy with either one really.
2006 Mustang GT Whipple HO FRPP Hot Rod Cams |
#16 | |
2005 Mustang GT
10.32@137.70
intake temperature will limit boost from heat of compressed air, if you have 175 degree air entering motor it will pull timing to surpress detonation, so figure the air under the hood being sucked into the supercharger is 120 degrees and the supercharger compresses the air and the temp rises to 175 degrees and goes through the intercooler and air temp drops to 120 again and you are running 20 degrees of timing, then the computer will pull some timing because of the hot air, if you could get 70 degree air into the blower and when compressed it is 125 degrees and after the intercooler it is 80 degrees then the 20 degrees of timing will not be affected.
the more timing, air, and fuel you can get into the motor the more horsepower, my car only makes 427 rwhp at 16 degrees of timing, yet with 23 degrees it makes 466 rwhp, that was proven on back to back runs on the dyno with the same tune except we put 7 degrees of timing into the car and and picked up 39 rwhp from 7 degrees of timing
2005 Mustang GT
10.32@137.70
i didn't realize you had to chop into the wiring harness for the whipple too, i thought that was something that wasn't well thought out at kb
I compared the KB,Whipple and Procharger (they build them here in KC) and ended going with my Mechanic's advise. He didn't go into why but he has been doing this for a while and I trusted him. It has been great so far.He told me about the wiring situation, but if its done professionally who cares. I have had zero problems.
A Steeda mechanic stated in a magazine article that Steeda didn't recommend pulling more than 430rwhp from the stock internals.
Threads Similar to: Whipple or kenne bell
| Which One... (Whipple or Kenne Bell) | mustangrebuilder | General Tech | 13 | November 29th, 2007 10:09 AM |
| Kenne Bell | hellbred07 | 2005 - 2010 | 34 | November 9th, 2007 07:33 PM |
| clutch change with whipple,kenne bell, roush | 05mustang_kb_charged | 2005 - 2010 | 15 | July 15th, 2007 12:25 PM |
| kenne bell | punkafi888 | General Tech | 43 | April 4th, 2007 04:52 PM |
| Kenne Bell | 03blownmach1 | 99-04 | 11 | June 28th, 2006 02:04 AM |
