2008 Mustang GT
2nd to 3rd grinding
Two things:
1) I picked up my 08 Alloy Mustang GT on New Year's Eve. Been too busy driving like a teen with a new license... all through a 6" dump of a snowstorm. hehe ![]() 2) It's got a 5spd and occasionally when I shift normally from 2nd to 3rd when the lever is going into 3rd with the clutch all the way on the floor it'll grind. I've noticed that when I shift, if I pause momentarily between gears it'll go into 3rd without a problem. I just started driving stick 4 years ago, but have about 60k miles across two cars in experience - is this a techinique issue or mechanical with the transmission? Will getting an aftermarket short throw fix this or is it something that should work perfectly fine? I guess I should have driven some of the other Mustangs on the lot.... Car's got 150 miles on it and I put 130 of those on it. Thanks and hope everyone's having a great year!
Experience is what you get when you didn't get what you wanted.
MM's resident Juice head
07 Mustang GT
How often is ocasonally ?
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
2008 Mustang GT
I dunno the ratios yet, I've been actively trying to avoid it by pausing between gears. Plus I've only had the car a few days.
I heard it once when I test drove it for four hours a month ago, didn't hear it at all the day I bought it, and I heard it maybe 5 times yesterday and none today. I tried searching the forums and it seemed people were having problems with the shifter completely missing shifts which isn't the problem I'm having. Was just wondering if it was common with new cars? Or common at all? Or if I'm horribly cursed and will be visited by three car demons during the night to show me the error of my ways?
2007 Mustang GT
i get the same grind sometimes going into 3rd. it's not a huge or persistent grind and i can more feel it then hear it but it doesnt feel normal
07 Mustang GT
well I dont think any grind is normal....Check your fluid level in your gear box??? Other than that maybee its a bad syncro?
Mine has only grinded second
I took it to the dealership and they didn't find anything wrong, yet I can still get it to lock up while idle.
i never had the problem when i had the stock shifter nor now that i have the tri axe
2012 Mustang GT
I have an occasional grind going into 3rd as well. Few times a week.
2012 Mustang GT - JLT CAI, BBK L/T Headers, BBK X-Pipe, Borla S-Type axle backs, 3.73's *more coming soon* Latest Dyno: 406 rwhp 377 rwtq *need more!* MILITARY CREW
HMC(SW/AW) |
2008 Mustang GT
Well now I feel like an idiot, I swear I searched the forums for previous threads about this - sorry if I wasted anyone's time reposting an old discussion topic.
And thanks for confirming that the problem isn't me either. I'll check the gearbox fluid later this evening. After another hundred miles today I think I need to learn more about synro gears specifically and manual tranmissions in general (automatic transmissions will always work solely on indescribable magical phenomenon and the pressurized remnants of stars long ago pulvarized by comets). I tend to keep a really loose grip on the shifter - and when I pause between gears going from 2nd to 3rd I actually let go for about a half second. The stick springs to neutral and then I push it up to 3rd. When I do that it works 100% of the time with no abnormal noise, vibration or harshness, et cetera. When I push the stick in one motion from 2nd to 3rd it has grinded every time. I really don't want to try to work it out as it sounds bad. Exactly like it did on my old car when I went into reverse (which did not have a syncro) while the car was still going backwards even though the clutch was floorboarded. That is leading me to believe it's a syncro issue on 3rd. But I don't know enough about syncros - is there just one for the entire transmission or is there one for each gear syncroed? Another factor that was brought up in that earlier thread was cold weather. Yesterday and today have been between 0 and 20 degrees fahrenheit. We'll see how it works in the 100 degree+ summer.
07 Mustang GT
ya but after rowing thru the gears and driving the car for a few minutes that fluid should be at operating temp....It is starting to sound like a bad syncro...good luck!!
i would say its the syncros on third gear, i would take it back to ford and show them. and tell them its not your driving
Stage 2 Mutha Thumprs,FRPP 4.10s, Pypes O/R X pipe, Violator axleback, JLT CAI, GT500 spoiler, 18x9/18x10 (255/285) H&R lowering springs Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
2007 Shelby GT500
For those having gear grind problems, it comes from the clutch not engaging and disengaging. This is a known problem and really heavy with the GT500's right now. The grind is a known issue and has to due with the clutch dragging due to no lubricant applied to the clutch splines during assembly.
Here is the service tip that is used for replacing the clutch under warranty for the GT500's. My tranny & clutch was replaced due to the issue at 4800+ miles. Ford Service Tip: "19802 2007-2008 Mustang Shelby GT500 Clutch Service Tip" The grind is a known issue and has to due with the clutch dragging. The clutch assembly needs to be replaced (part# 7R3Z07B546-B ), and Motorcraft PTFE lubricant (Part# XG8 or D2AZ-19590-A) needs to be applied to the hub splines. With some reseach, I am sure there is probably a service tip for the Mustang GT and one could find out by contacting Ford AAI in Detroit, not the dealers.
2007 Red w White Shelby GT500 Took delivery 10-25-06 at MSRP Mods: 2.6 pulley, JLT CAI, NGK TR6 plugs, Ford Racing axlebacks, BMR LCA's, BMR driveshaft loop, & tune by Jon Lund My car domain: http://www.gotstang.com/profile.php?LSR#jump
#13 | |
2008 Mustang GT
Wow, thanks for the heads up! I'll try to do some digging around on that. I'm guessing Ford's going to warranty it when it fails, in the meantime should I begin a documentation on this by bringing it into the dealer I bought it at and force them to acknowledge the grinding even if they don't do anything to it right now? I wonder if that's the holdup that's delaying January Bullitt production....
I have 2800 miles on my '07 GT500 Should I or a qualified mechanic lubricate the clutch spines now?
#15 | |
2007 Shelby GT500
If you are experiencing gear gring going into 1st or reverse then you do have a problem. PM me if you need direction.
No grinding problems so far, except for a busted racing stripe above the faux gas cap everything is really really fun. Started out as an area that came unstuck a day after I bought it and is now broken due to cold weather. I will take it to the dealer and/or the local ford racing speed shop and make them fix it. I think it was originally applied to tight.
Look Ma! My First Post!
my friends car did that everytime he threw it into 2nd or 3rd it would grind. We found out it was his tranny idk with you cause its a new car if anything get it checked out to make sure
Reverse only grinds when I am doing about 90
2007 Shelby GT500
#20 | |
One Man Wolf Pack
![]() ΜΟΛΩΝ ΛΑΒΕ
Threads Similar to: 2nd to 3rd grinding
| Grinding... Help! | Reset | 99-04 | 21 | February 23rd, 2008 06:40 PM |
| Grinding after the track | weems | 99-04 | 58 | July 13th, 2007 07:37 AM |
| grinding noises? | blue03mach1 | 94-95 | 4 | July 3rd, 2007 06:57 PM |
| t5 grinding in reverse | tayboo24 | 5.0 Mustangs | 19 | June 4th, 2007 12:20 AM |
| 1st gear grinding | Luis_GT | 2005 - 2010 | 9 | April 4th, 2007 07:05 AM |
