2006 Mustang TSB's
Technical Service Bulletins
2006 MUSTANG UPDATED: 3-17-07 07-5-13 DISCHARGED BATTERIES - VEHICLES IN STORAGE/LIMITED USAGE 07-5-8 BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS 07-4-3 LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE 07-3-9 MIL ON - DTC P0456 07-1-7 MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS 06-26-2 CARPET REMOVE AND REPLACE 06-26-1 MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS 06-25-15 ALUMINUM BODY PANELS - CORROSION - SERVICE TIP 06-22-18 POWER WINDOW DIAGNOSIS 06-22-16 CONVERTIBLE TOP WEAR - BUILT BEFORE 10/11/2006 06-21-19 HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY) 06-21-7 AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES 06-19-12 DTC P0340/P0344/P0345/P0349 - 4.6L 3V AND 5.4L 3V 06-19-2 8.8 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS 06-18-16 IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES - SERVICE TIP 06-17-8 SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS 06-15-8 KEYPAD DIAGNOSTICS - DEALER INSTALLED ACCESSORY 06-14-3 AIR CONDITIONER COMPRESSOR CLUTCH FAILURE - REVISED COMPRESSOR CLUTCH 06-12-11 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS 06-10-13 MIL P0463 OR ERRATIC FUEL GAUGE 06-10-10 AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES 06-10-5 5R55S - TRANSMISSION FLUID LEAK 06-10-1 AIR CONDITIONER COMPRESSOR CLUTCH FAILURE - REVISED COMPRESSOR CLUTCH 06-9-11 LOUD TICKING NOISE - 3-VALVE ENGINES - STUCK LASH ADJUSTER 06-9-9 HESITATION ON ACCELERATION AFTER LONG CRUISE 06-7-10 MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020 - 4.6L 3V 06-5-4 PARK BRAKE CABLE FREEZING/REAR BRAKES DRAGGING 06-4-2 BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS 06-4-1 RATTLE/NOISE FROM THE CENTER STACK (RADIO/HEATER) OF THE INSTRUMENT PANEL OR GEARSHIFT AREA 06-3-13 FUEL FILL SLOW, OR DIFFICULT TO FILL 06-2-9 DTC P0340/P0344/P0345/P0349 - 4.6L 3V AND 5.4L 3V 06-1-5 DTC P1000 MAY NOT CLEAR IN HIGH ALTITUDE CONDITIONS 05-24-6 CONVERTIBLE SYSTEM CONCERNS 05-22-8 WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING 05-20-2 REAR AXLE NOISE 05-18-7 WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS 05-16-12 SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS 05-9-18 DISCHARGED BATTERY - CHARGING SERVICE TIPS 05-9-3 INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
1993 5.ohhhh
12.97 @140mph
Thanks a bunch!
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
i have a ratlle coming from my center console when i hold the gas steady like very slightly.
i also had the fuel monitor where it says W/E miles to empty..it malfunctioned i guess because i know i had 60 miles left to empty then it jumped to 2 miles to empty then to 0.... i also hear a noise coming from the shifter i would be in park and i would tap the brake then here a click noise and i repeated tapping it one time to see if it was just me or it really was the brake and everytime i hit the brake and let go i heard a click near the shifter... is this a recall thing or normal? i dont know its my first car... its an automatic gt 06 |
#4 | |
06 Mustang GT
12.837 @ 107.7
What was it? |
Jat, the brake click is probably the pre-shift lock that is disengaged to prevent going into gear without the brake pressed...most of your newer cars have it, and if you listen you can hear the click...check for any kind of change in your console, if not, some could have fallen down your parking brake rubber...other than that, its under the plastic, talk to ford...
Bring the car in for serivce on the 20th ill let every1 know... also I got my oil change and they said comething might be wrong with my rear left brake they can see the piston more or something...
Do these these technical service bulletins apply to the 07's. I just ask because it say 06 for the date. Thanks
67 Mustang = 492 HP/478 TQ 07 Mustang GT = JLT CIA with SCT Tune, Drops 95 MarkVIII= Project/ resurrection |
Are these recalls ?
Vroom <~~~ Stock Vr0oOm <~~~~ me 2006 silver/Black, red interior, moon roof, shaker 1000 JLT Cai, Steeda TB spacer, Hurst Short Throw Shifter, Pypes O/R H, MangaFlow AxelBack, Diablo Pedator... |
Proud American
TSB= Technical Service Builten
I belive if the car is underwarrenty the dealer is suppost to fix these for free. And if it is not underwarrenty they will charge you to get these fixed. |
Moderator
+1
It's similar to a recall, except that if a recall comes out on your car, usually the dealer will repair/replace the item even if your warranty is over.
These clear up alot of problems, thanks for the info!!!
Thanks. Now... can we let this post go away now ?
Tdog 2007 mustang GT 5speed, Black |
This needs another section then. Not here. It is getting OLD !
Moderator
Dude. Who cares. It's a sticky at the top of a forum to help people, how can it bother you, just don't read it. Other people may want to know this information.
It is bugging me. If sticky needs to do it then create a 2006 listing. This is bothering those that do not have a 2006. This is a 2005+ section. Create a 2006 section then
Moderator
Okay, I don't know what to say. It's a forum thread, I'm not quite sure what bugs you about it, seeing as it's important information for our year of car. Half the sections in this forum have sticky's to help people. I really can't see how it bothers someone, the whole idea of a technical based forum is to make important relevant information available to us.
The name of this forum section is 2005+. I doubt mdvaldosta is going to make an entire 2006 section for TSB's. These TSB's are for an 06, and so fit in the 2005+ section. And just because those TSB's say 2006 doesn't mean they won't apply to an 05 or 07. I found two TSB's for my car from this thread, and mine is an 07. I'm still not quite sure why it bothers you to have to look below one sticky. Also with the sticky here, we can have it updated when new TSB's come out. But hey, it's not my call. If it bothers you, PM a mod about it, and if it moves, I guess I'll have to keep track of it and go digging for stuff if I need this information.
Hey...UnZippee !. You had it dead on ! "Okay, I don’t know what to say". You should have stuck with that and then just shut the hell up. I never asked you for a comment. You are not the author of "sticky" ..What purpose it serves you is just that "personal". You really need to follow you own advise with you clever signature and "RUN YOUR CAR, NOT YOUR MOUTH"
dont worry TheUNZippee! ..... This post isnt going anywhere.
Threads Similar to: 2006 Mustang TSB's
| 2003 Mustang TSB's | Casper98GT | 99-04 | 2 | March 4th, 2011 12:46 AM |
| 2007 Mustang TSB's | Casper98GT | 2005 - 2010 | 38 | March 14th, 2009 11:30 PM |
| TSB's and RECALL Information Here. From 1996-2006 | Casper98GT | Modular Mustangs | 6 | September 30th, 2007 11:06 AM |
| 2004 Mustang TSB's | Casper98GT | 99-04 | 2 | August 19th, 2006 05:22 PM |
| 1999 Mustang TSB's and RECALLS | Casper98GT | 99-04 | 0 | September 6th, 2005 12:23 AM |
