BMR Lower Control Arms
I received my lower control arms the other day and in the instructions it says after installation to lube them with a silicone base polyurethane lube. I have been to 2 different auto parts stores and they do not carry this, it is all lithium or petroleum based. Does anyone know what I should use? And where can I get it? One guy said EP grease should do the trick but I hate to take the word of someone I do not know especially if it will cause any problem later.
MM's resident Juice head
07 Mustang GT
I use red tac in my BMR lowers...works fine
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
Thanks
I just used regular automotive grease on mine. Im sure it was wrong but it stopped them from squeaking.
2005 mustang gtZex nitrous Tokico D-Spec Hurst shifter Nitto Drag Radials Hooker exhaust Raptor shift light Foose Nitrous Wheels Eibach pro kit 4.10 gears |
i use a synthetic grease on all my lube points. lca's, panhard bar, and what ever other ones there are.
![]() heads, cams, and eforce using up all the air around |
66 Fairlane
10.28@135.65
Use a synthetic based grease if possible.If you have any kind of marine supply place around you they should have some.Do not use lithium grease it will eat the bushings.
Fordman351 |
i get my synthetic at the local auto parts store. think it was auto zone or oreilly
2006 Mustang GT
11.45@123.61
![]() ![]() iTrader: 2 reviews
+1 synthetic grease works fine.
Stock for now.
Threads Similar to: BMR Lower Control Arms
| Upper Control Arms & Lower Control Arms | LUV2XLR8 | 2005 - 2010 | 6 | October 6th, 2007 12:45 PM |
| For those with Upper/Lower Control Arms... | the real shocker | 99-04 | 26 | September 19th, 2007 06:49 AM |
| Steeda lower control arms (Trailing arms)? | kmjsmith | 2005 - 2010 | 6 | July 4th, 2007 05:59 PM |
| Lower control arms | Clockman | 94-95 | 8 | April 4th, 2007 05:31 PM |
| lower control arms | reeds98gt | General Tech | 6 | November 19th, 2006 12:27 PM |
