How much $$$ to have cams installed in my car and tuned?
Old January 11th, 2008, 06:10 PM   #1
silverstang05 is on a distinguished road
Send a message via AIM to silverstang05
Im trying to figure out how much $$ all together it is going to cost me to put BBR stage 2 cams in my car. Im pretty sure i need vavle springs and retainers. It also says on there website you need 4.10 or higher gears. Is that truely needed? Also there is the tune. Someone wanna take a wild guess on how much money it is going to cost all together including labor costs.
Thanks!
2005 Mustang GT
-STS single turbo kit 478whp/465wtq @10psi
-Fidanza 4.3 clutch
Should i use my race gas tune i have??
Old January 11th, 2008, 06:19 PM   #2
Trick Tuners's Avatar
KB'd GT
Not including the cams i'd say 1500 to $2000. Cams are a very expensive install and require an experienced mechanic to pull the motor to properly degree them. Might as well throw in some forged pistons and ported heads while the motor is out. The 4.10 requirement means you will loose a chunk of low end TQ for the higher hp it gives on the top end.
Old January 11th, 2008, 09:47 PM   #3
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
The motor doesn't come out. I would say around $2400 for everything including 4.10 gears. The 4.10s will make the car feel much faster. The only thing is you lose a little bit of top end. The 4.10s are so that the car doesn't stall in normal driving, and they get it into the range where the cams make the most power.
ΜΟΛΩΝ ΛΑΒΕ
Old January 12th, 2008, 10:36 AM   #4
Well my mind has changed and im getting a good deal on a STS single turbo kit
2005 Mustang GT
-Fidanza 4.3 clutch
Old January 12th, 2008, 10:37 AM   #5
One Man Wolf Pack
2006 Mustang GT
13ish....maybe
Even better
ΜΟΛΩΝ ΛΑΒΕ
Threads Similar to: How much $$$ to have cams installed in my car and tuned?
Getting my car tuned? e3sean 5.0 Mustangs 14 January 3rd, 2008 06:48 PM
Tuned The Car 330CubeGt 96-98 1 December 21st, 2007 09:37 PM
Tuned Up MustangMo V6 Mustangs 14 May 16th, 2007 07:15 PM
Is my car tuned? jagermiester 99-04 7 February 20th, 2007 07:09 PM
Tuned Stock GT vs Bad Tuned Modded GT cobralini Racer's Corner 26 January 14th, 2007 02:47 PM
