Rear brake pad install problem
Old January 12th, 2008, 04:14 PM   #1
2006greyGT's Avatar
2006 Satin Silver GT
11.08@125.22
2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about
Send a message via Yahoo to 2006greyGT
I just installed drilled and slotted rotors on my 06. I couldn't get the pistons pressed back in on the rear calipers enough to get the new pads on. I had no issue with the front.HELP!!!
[IMG]
2.6l KENNE BELL 298 Stroker, Ported heads
Pro Motion Built 3650/McLeod RST/ MGW Short Throw
Long tube/O/R X /Borla Touring
8 rib/65 lb injectors/GT500 twin fuel
ET Drag Slicks/3.73 gear
Detroit Truetrac /CDC AGR Spoiler
Old January 12th, 2008, 04:36 PM   #2
blownsnake96's Avatar
1996 Mustang Cobra
blownsnake96 is on a distinguished road
Don't know if you tried this or not, but the pistons on the rear calipers have to be turned as they are pressed in, like you're scewing them back into the caliper. Hope this helps...
96 Cobra
Procharger D1SC at 15 psi
BBK Longtubes, Magnaflow exhaust
Tremec trans, 4:10's, the works...
Built and tuned by Atlanta Chassis Dyno
530 hp / 420 tq at the tires
Old January 12th, 2008, 05:50 PM   #3
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
^ correct
Old January 12th, 2008, 06:58 PM   #4
06GT4RAD's Avatar
2006 Mustang GT
06GT4RAD will become famous soon enough
That is correct and you may need a special tool to accomplish this.
2006 Mustang GT-Borla Stingers, MGW Billet Interior & Underhood, Eibach Pro Kit w/Tokico D-Specs, Steeda Sway Bars, CHE Suspenson Upgrades, BBR Billet Control Arms, Foose 20" Nitrous, BFG g-Force KDWII
Old January 12th, 2008, 09:31 PM   #5
2006greyGT's Avatar
11.08@125.22
I was wondering what those notches in the face of the piston were....Damn...Well I guess I can borrow one from O'riley....Thanks for the replies...
[IMG]
Old January 12th, 2008, 09:32 PM   #6
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
any time.
Old January 13th, 2008, 04:17 AM   #7
X2RTION GT's Avatar
02 GT
X2RTION GT is on a distinguished road
ohhh thats how you do it
Threads Similar to: Rear brake pad install problem
brake problem 00redgt 99-04 3 January 5th, 2008 08:12 PM
Hey Brake Problem Killax15 99-04 6 August 23rd, 2007 12:45 PM
brake problem spero 99-04 2 April 2nd, 2007 06:02 PM
Brake Install ? formgen General Tech 2 December 11th, 2006 11:06 AM
having a problem depressing rear brake piston blue6er99 General Tech 5 June 19th, 2006 08:12 PM
