intercooler spray bar
Old January 17th, 2008, 02:38 PM   #1
2006 Mustang GT
10.82@125.2
blackhavok is on a distinguished road
would i be able to use this in conjunction with my saleen charger??
Inter-Cooler Spray Bar Kit
Inter-Cooler Spray Bar Kit w/5 lb. Bottle
NOS16034NOS
www.RADMustangs.com
www.s197Performance.com
Bassani Crew Member #2
10.82@125.2
Old January 17th, 2008, 02:56 PM   #2
05mustang_TT_charged's Avatar
2005 Mustang GT
10.32@137.70
05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough
you can but it won't help much because you have an air to water intercooler not air to air.
if you want to help out air temps by a reservoir that can hold more water and you can add ice to
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system
326 cubic inches of Twin Turbocharged hell will be running soon
Tuned by Wes @ TPS
Old January 17th, 2008, 03:00 PM   #3
2006 Mustang GT
10.82@125.2
where can i find one??
www.RADMustangs.com
10.82@125.2
Old January 17th, 2008, 03:16 PM   #4
2005 Mustang GT
10.32@137.70
Supercharger Coolant Tanks
Built from .100 aluminum the tanks are stronger, more reliable, and better looking than stock. #80-235 Oversize battery box mounted Supercharger Coolant tank. Designed for drag racing these tanks have a large top opening to be easily packed with ice to produce power gains.
Aluminum Battery Box Super Charger Coolant Tank 80-235 $166
Tuned by Wes @ TPS
Old January 17th, 2008, 03:18 PM   #5
2005 Mustang GT
10.32@137.70
but with this kit you need to relocate the battery to the trunk, i did this and it helped a little but my intake temps were already low only about 40-50 degrees over ambient temp
Tuned by Wes @ TPS
Old January 17th, 2008, 03:26 PM   #6
2006 Mustang GT
10.82@125.2
so where can i get the tank plus the battery relocation kit and any neccesary hoses or clamps?
www.RADMustangs.com
10.82@125.2
Old January 17th, 2008, 04:07 PM   #7
2005 Mustang GT
10.32@137.70
the kit from Canton and the battery relocation kit from taylor, give me a minute and i will post some links
Tuned by Wes @ TPS
Old January 17th, 2008, 04:32 PM   #8
2005 Mustang GT
10.32@137.70
battery relocation kit....
Taylor Battery Relocation Kits: TAY-48101 - summitracing.com
https://www.jegs.com/webapp/wcs/stor...0002_214290_-1
Supercharger tank....
CANTON Aluminum Supercharger Surge Tank Upgrade Kit 1999-Current SVT Lightning & Harley Truck
Stage 3 Motorsports 2003-04 Mustang Cobra Canton Supercharger Surge Tank
Canton 99-04 Cobra/Lightning Supercharger Coolant Box [80-235] - $154.99 : Performance Parts - Ford Mustang - Cobra - Dodge Viper - Chevy Corvette - C6 - LS1
Tuned by Wes @ TPS
Old January 17th, 2008, 04:32 PM   #9
2006greyGT's Avatar
2006 Satin Silver GT
11.08@125.22
2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about
Send a message via Yahoo to 2006greyGT
I would do this too but If I put the battery in the trunk my clubs won't fit...
[IMG]
2.6l KENNE BELL 298 Stroker, Ported heads
Pro Motion Built 3650/McLeod RST/ MGW Short Throw
Long tube/O/R X /Borla Touring
8 rib/65 lb injectors/GT500 twin fuel
ET Drag Slicks/3.73 gear
Detroit Truetrac /CDC AGR Spoiler
Old January 17th, 2008, 04:37 PM   #10
Trick Tuners's Avatar
KB'd GT
Spraying nitrous on a air to water IC will do nothing. Spraying nitrous on an air to air IC is still stupid. Why waste nitrous trying to get an extra 5hp by spaying a 100 shot on your IC? Have you seen the killer chiller?
Old January 17th, 2008, 09:53 PM   #11
2005 Mustang GT
10.32@137.70
yeah if you have $1000 dollars burning a hole in your pocket, go for the killer chiller, looks like a bad M/F'er
Tuned by Wes @ TPS
Old January 18th, 2008, 12:51 AM   #12
2006 Mustang GT
10.82@125.2
whats the killer chiller?
www.RADMustangs.com
10.82@125.2
Old January 18th, 2008, 01:01 AM   #13
2005 Mustang GT
10.32@137.70
it mounts where the factory Cobra Eaton, Kenne Bell and Whipple intercooler does below the supercharger, it uses the refrigerant from the air conditioning system to cool the water passing through the intercooler to the heat exchanger. it has been proven to low the air temps to below 50 degrees when the blower is making boost and heating the air during the compression before being injested into the motor. the testing on it showed as much as 120 degree temp drop on Eaton powered cars
Tuned by Wes @ TPS
Old January 18th, 2008, 01:02 AM   #14
2005 Mustang GT
10.32@137.70
here is a link
Kincaid Performance - Home of the Killer Chiller
Tuned by Wes @ TPS
Old January 18th, 2008, 10:55 AM   #15
KB'd GT
Not quite, it actually mounts in the bumper by the HE and cools the IC fluid. There is also a bypass kit to remove the HE from the system so you dont heat up the IC fluid.
Old January 18th, 2008, 11:29 AM   #16
2005 Mustang GT
10.32@137.70
your right i just looked at the site, they changed it from the original one my friend has on his lightning, thought they were still in the intake valley
Tuned by Wes @ TPS
Threads Similar to: intercooler spray bar
Intercooler rxnodoze02 2005 - 2010 21 November 28th, 2007 03:38 PM
intercooler darkcyd General Tech 5 June 28th, 2007 10:53 PM
oil in intercooler and s/c piping Drgnracin72 99-04 5 April 25th, 2006 12:24 AM
NEED HELP with Intercooler. fallstar01 General Tech 4 October 28th, 2005 09:38 AM
