cmcv, Installation?
Hey Everyone,
Ive received my cmcv plates from steeda and Im getting my tune from Bama on thursday and going to a shop to get my gears put in on Saturday. Im a beginer/novice when it comes to diy mods. Should I attempt to do the CMCV plates myself? Also If I do the cmcv plates myself and install the tune from Bama can I drive my car without the new gears in? Im going from 3.31 to 3.90s. Thanks!
1994 Cobra - Bassanni Shorties, Borla Catback, JLT CAI, MSD Cap & Rotor, FRPP Spark Plug Wires Coming soon: FRPP Aluminum Driveshaft, Aluminum Flywheel, and X-pipe |
IBEATU
06 GT, 98 GT, & 93 Notch
You'll be fine driving it, you can change the gears you have in the handheld. As far as installation, I havent done it mself yet, but it looks and sounds pretty basic. You should be fine.
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
#3 | |
Moderator
2005 Mustang GT
10.32@137.70
1 point to mention on the cmcv plate swap is to remove the motor that runs them when you have the intake off. i got mine when they first came out and the manual did not say to remove it, so i left it. well when i asked Steeda about it they said to remove it and tape up the connector, it supposedly save like 3 pounds off the front end... just saying that incase it is not mentioned in the manual because you do not need it anymore
326 cubic inches of Turbocharged hell will be running soon Tuned by Wes @ TPS ![]() |
Whats RTFM Zip?
#6 | |
2006 Mustang
13.003@106.2
If you decide to take the fuel lines off you will need that tool. but if you are good you can use 2 flat headed screw drivers. It is an easy swap. Dont let it intimidate you. The motor is for the actuators that control the butterflys that you are removing.
06 Mach 1 Tribute. SOLD! JLT, XCal2/Bama/Brenspeed,Sniper,OR/H, Flows, HT0s, UDPs, CMDP, 4.10s, Hurst 1988 Thunderbird Turbo 3 inch DP to Tips, Walbro 255, Kirban FPR, T-3, gutted/knifed upper/lower. FMIC, Autometer.
RTFM = Read The Fucking Manual
LOL thanks killermach, I had already planned on doing that.
2006 Mustang GT
11.45@123.61
![]() ![]() iTrader: 2 reviews
simple install with basic tools< I believe in the steeda instructions it says to disconnect the fuel rails but you don't have to. there's enough fuel line that you can just move it to the side out uf the way.
Stock for now.
Ok cool I was wondering what tool I would need to disconect the fuel rails but Ill try to just set them aside. Im doing the install next Saturday.
Threads Similar to: cmcv, Installation?
| LED Installation | Devthedevastator | Visual | 1 | November 5th, 2007 08:15 PM |
| My next mod: UDP's or CMCV deletes?? | stanglifemike | 2005 - 2010 | 54 | August 14th, 2007 09:38 PM |
| CMCV tune | leebunnyz | 2005 - 2010 | 10 | March 20th, 2007 12:31 AM |
| CMCV Delete | gx1856 | 2005 - 2010 | 1 | October 10th, 2006 03:58 PM |
