2006 Mustang GT
539rwhp / 482rwtq
Aftermarket Oil/Water Gauge Install
I am just curious, those of you that have installed aftermarket gauges like oil presssure and water temp, where did you put the new sending unit with the gauges?
I know with the oil pressure unit, I could just tee it off with the existing and no problems there. However on the temp sending unit not the case, without installing a special hose adapter, is there another port on the block it can go? Obviously I dont want to remove the factory unit, since they are required for the computer. |
F-150 FX4
What do you need an oil and water temp gauge for?
2006 Mustang GT
539rwhp / 482rwtq
Well I have a Oil, Water, Nitrous, Digital Pro Shift System, and Fuel Pressure guages. I got the Oil/Water for Christmas and want to use them since I have places to put them...since I have a two SOS pods, one for the pillar and one on the dash both with 3 three gauges.
2006 Mustang GT
539rwhp / 482rwtq
Is there any reason you couldnt just wire it into the existing ford water temp sensor connector? Therefore not needing the secondary aftermarket sensor.
2006 Mustang GT
539rwhp / 482rwtq
Ok...I should have just looked before posting but its just darn cold outside...
Anyway...I can install on drivers side in the block. That is better location than using the adapter Autometer sells and this will still allow the factory sensor to stay in place. |
Threads Similar to: Aftermarket Oil/Water Gauge Install
| How To Install An Aftermarket Tach | TurboLX | Electrical & Wiring | 4 | March 8th, 2012 11:53 PM |
| How To install an Aftermarket Tach in a 96-98 | MustangMatt96GT | 96-98 | 30 | May 5th, 2008 09:22 AM |
| water pump install | ddashtrois | 99-04 | 1 | January 7th, 2008 03:10 PM |
| gauge install | tommyboy | 2005 - 2010 | 15 | July 11th, 2007 12:38 AM |
| How do you install new seats that are aftermarket | Sithlord | V6 Mustangs | 0 | June 26th, 2006 09:56 AM |
