2008 GT
My 08 GT sometimes makes a strange, well, for a lack of a better word, buzzing noise,
when idling high during warm up. It sounds like when the wind is blowing really hard and it makes that thin metal weatherstripping on the doors of the house vibrate and buzz. I never heard it when I had the stock air cleaner on the car, but it was fairly warm when I bought it and the car didn't idle as high or take as long to warm up, so I'm not sure there's any relation to the new CAI system. I've checked all the clamps on the CAI and everything is tight and sealed well, so I don't think its coming from the CAI. Its not a constant buzz, just lasts for a few seconds then stops and does it intermittently until the car is warmed up some. I usually turn on the heat in the car when I start it so that the inside will be warm by the time the engine is warmed up, but I've left the heat off inside and it makes the noise anyway, so I know its not the fan motor. I've opened the hood and waited for the noise to occur, but have been unable to determine where its coming from. Any ideas what this could be?
2007 GT
what temps. are we talking
2008 GT
in the 30's to low 40's, like I said its been fairly warm here.
But the last time I heard it was a few days ago, very briefly and the temps were in the low 50's that time. Its always been in the first 3-5 minutes or so of starting the car. As soon as the idle starts dropping back down toward normal, the noise stops.
2007 GT
my 06 ford e350 makes the a whinning noise at start up when it really cold out but I'm talking like -10 to 30 degrees
2006 Mustang GT
maybe just the car warming up, not sure though. If it continues or gets worse i'd take it to get checked out.
Your Mom's Favorite
2007 Mustang GT
Eats Chevys, Shits Imports...
It's probably the power steering pump. Fords have always had noisy steering pumps. Mine makes the same noise.
http://www.moddedmustangs.com/forums...p-vote-me.html ![]() TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER) MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER TRUNK MONKEY CREW FOUNDER |
2008 GT
Thanks Grabber, I'll pay close attention to the PS pump next time I'm trying to track
down the source of the noise. I see you have a 3.73 rearend, I assume you upgraded from either a 3.31 or 3.55. I've got 3.31 and am thinking of going to 3.73. Could you tell a substantial difference in acceleration when you upgraded yours? Also thinking of trashing the Hurst shifter that's been giving me problems and the Ford dealer is giving me the run around on. I've been looking at the Steeda Tri-ax, how do you like yours?
One Man Wolf Pack
MGW is the best shifter for Mustangs. I would look into 4.10s also.
![]() ΜΟΛΩΝ ΛΑΒΕ
#9 | |
2005 Mustang GT
Just installed the MGW Shifter and 4.10's about 2-weeks ago. I love'em. We could argue about the gears depending on your other mod's . . . but the MGW Shifter is BADASSSSS! Highly recommended. |
+10 on the MGW.
#11 | ||
Your Mom's Favorite
2007 Mustang GT
http://www.moddedmustangs.com/forums...p-vote-me.html ![]() TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER) MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER TRUNK MONKEY CREW FOUNDER Last edited by Grabber523; January 21st, 2008 at 05:44 AM. |
2008 GT
Thanks guys, yeah I knew I'd get a lot of MGW guys chiming in on the shifter.
They're only ~ 2 hours from me and I have family in Augusta. Sounds like a good excuse to go see them. I'll call MGW and find out if they have a retail location or if I have to order it. Since this is a new car I wanted to stick with Ford speed parts and service so the warranty would hold up, but with every Ford I've owned I've ended up getting the run around from the dealer on defective parts or shoddy service or both. I swore after my last Ford that I'd never buy another because of that, but here I am again with a great car and becoming a little disappointed in it simply because of BS service. As for 4.10's, I don't intend to do any drag racing with it, other than maybe a few times just to find out what the car will do. That's why I was thinking of 3.73's, still have more acceleration but I won't run out of the gears as quickly. So far my only power mod is the addition of a K&N CAI. Was thinking of the Brenspeed X-cal2 tunes, but held off when my shifter started acting up because I wasn't sure at the time that it was the shifter making the noise. Was concerned Ford might have to do engine work and then reflash the computer. Now I've decided to go ahead and do the gears (I guess I'll have Ford do those and pray they do it right and that the gears are not defective) and maybe an aluminum driveshaft and underdrive pulleys, and then get the tuner from Brenspeed. I guess the main reason, other than Steeda's good rep, I was looking at the Steeda shifter over the MGW is out of laziness, I can get the tuner, driveshaft, pulleys and Tri-ax all from one location.
2005 Mustang GT
Heard a lot of good things about Steeda Tri-Ax as well . . . almost bought it . . . but the reason that I ultimately ended up going with the MGW was a lot of discussion about transmission noise. I read some threads where the Hurst and Steeda worked well but added a lot of in-car noise. Apparently, MGW has some kind of "patent-pending" sound design that eliminates those types of problems. Whatever. All I can tell you is that there is no additional cabin noise in mine when compared to the stock shifter . . . just super tight shifting and a lot better feel.
If noise in the car is an issue . . . you may want to go with the MGW. Just what I heard . . . or more . . . what I don't hear. |
#14 | |
Your Mom's Favorite
2007 Mustang GT
Threads Similar to: My 08 GT sometimes makes a strange, well, for a lack of a better word, buzzing noise,
| Strange noise | willsurforbeer9 | V6 Mustangs | 9 | January 3rd, 2008 10:13 AM |
| Car Exhaust makes Whining noise | Gweedoe | 5.0 Mustangs | 9 | December 25th, 2007 11:51 AM |
| War is makes strange bedfellows | WAR-PARTY | The Clubhouse | 9 | November 10th, 2007 10:09 PM |
| What makes that cool compressed air noise? | AggieStang | General Tech | 6 | October 16th, 2007 03:51 PM |
| Strange Noise Coming From My Rear | 92_fox | 5.0 Mustangs | 12 | November 14th, 2006 09:58 AM |
