Side exhaust and suspention hitting/ Side exhaust Gurus Questions???
OK, my car is presently in the shop right now getting the Whipple HO. installed.
When I get it back at some point I have to fix the mid muffler side exhaust problem i am having. Here's the situation: On hard braking in a strainght line(hard braking mind you) the rear end seems to be hitting the exhaust somewhere around the flange at the rear end causing a ting ting ting noise. I seem to have enough room between the flange and the exhaust to put 1 finger on top of the other at the closest point. Is that just not enough? does the rear end nose dive that much on braking hard? Also. the original Side exhaust from Cervinis had seperate flow tubes to connect to the mufflers with a slight bend in them and the new ones from Pypes don't ( more straight line with no bends ) Could that be the issue? could that slight bend be keeping my exhaust too close to the flange? Any Ideas hop to fix? My remedy so far as I will be doing this already is a Adj UCA and Solid LCA's is this my BEST solution to stop diving and raising of the rear end. Or do I need Adj Lowers and a Adj Upper too? Lowering of some sort will come in the future at some point.
2007 Alloy GT. 5 speed, Spydershaft, MGW shifter, 3.55 gears, Sequential tail lights, C 300 Cervini's Full Body Kit, CDC Hood Struts, Whipple HO.SC. 468 SAE RWHP 450.44 RWTQ |
2005 Mustang GT
When I get it back at some point I have to fix the mid muffler side exhaust problem i am having. Here's the situation: On hard braking in a strainght line(hard braking mind you) the rear end seems to be hitting the exhaust somewhere around the flange at the rear end causing a ting ting ting noise. I seem to have enough room between the flange and the exhaust to put 1 finger on top of the other at the closest point. Is that just not enough? does the rear end nose dive that much on braking hard? Also. the original Side exhaust from Cervinis had seperate flow tubes to connect to the mufflers with a slight bend in them and the new ones from Pypes don't ( more straight line with no bends ) Could that be the issue? could that slight bend be keeping my exhaust too close to the flange? Any Ideas hop to fix? My remedy so far as I will be doing this already is a Adj UCA and Solid LCA's is this my BEST solution to stop diving and raising of the rear end. Or do I need Adj Lowers and a Adj Upper too? Lowering of some sort will come in the future at some point. |
WTF
sorry my friend I don't.
Threads Similar to: Side exhaust and suspention hitting/ Side exhaust Gurus Questions???
| Dual exhaust better then side exit exhaust? | boblongtv | V6 Mustangs | 24 | January 11th, 2008 08:56 AM |
| Side Exhaust | Rated_R | V6 Mustangs | 22 | August 31st, 2007 01:29 AM |
| Side Exhaust | RandoGT | 96-98 | 5 | August 23rd, 2007 08:49 PM |
| Side Exhaust questions... | El_Cangri | V6 Mustangs | 44 | May 2nd, 2007 04:46 AM |
| Side exhaust | 2000Mustang | General Tech | 1 | March 9th, 2007 04:06 PM |
