Effect Of Cold Weather On Poly Bushings
Old January 20th, 2008, 11:09 PM   #1
Jon_Purdy is on a distinguished road
It's rather cold here in southeast Michigan. Is it normal for poly bushings to squeek a bit when it is so cold outside?
Jon
Old January 21st, 2008, 02:10 AM   #2
TheUNZippee!'s Avatar
Yes.
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old January 22nd, 2008, 06:14 PM   #3
Pontisteve is on a distinguished road
Control arms with poly bushings will always squeek because the poly bushing tries to rotate in the control arm. The only half-fix is to keep pumping in grease to the zerk fitting, but even that doesn't really cure the problem.
Control arms with poly bushings and a delrin sleeve between the bushing and the control arm bolt allow the bolt to rotate inside the bushing, without trying to rotate the bushing. (Delrin is a self-lubricating hard nylon material). This eliminates the need for using any grease, and eliminates the squeek. It also stops the bushing from breaking down over time because of the grease. Squeek-free and maintenance free.
Threads Similar to: Effect Of Cold Weather On Poly Bushings
Clutch sound in cold weather.. DanTheMan 99-04 3 December 28th, 2007 05:29 AM
Does a turbo effect your gas much? Steam V6 Mustangs 10 November 10th, 2007 01:50 PM
metal solid mount or poly motor mounts? knskit 5.0 Mustangs 5 February 16th, 2007 06:54 PM
Cold weather problem? 04Pony 99-04 5 January 21st, 2007 08:56 AM
bushings of poly or thane? WVSNS& General Tech 4 May 1st, 2006 10:13 AM
