06 Mustang GT
Headlight Adjust
Hey guys. I needed help with my headlights. Since they've installed the front end I havent been able to see more than 4 feet in front of my car because the headlights are pointing straight down almost. How do I adjust them? I heard there was a screw on the back of the housing but I cant find it.
Thanks! |
You see it directly from the top... its this white/plastic screw in the pic
06 Mustang GT
Ooooh ok. And how do I adjust it? Is it the same for the Shelby lights?
I don't know about the shelby... but turning it left or right will either make the headlight go up, or down... and its pretty visible, since it moves the whole reflector inside the case.
06 Mustang GT
Looks a tiny bit different on the shelby but overall it worked well. I'll have to drive it when it gets dark and see.
Thanks for the help Luis_GT! |
No problem!
you can rep if you like
One Man Wolf Pack
What you should do is park facing a wall at night so that you can level the lights so one isn't pointing higher than the other.
![]() ΜΟΛΩΝ ΛΑΒΕ
Your Mom's Favorite
2007 Mustang GT
Eats Chevys, Shits Imports...
+1 Get about 3 feet from a garage door with your low beams on. Using electrical tape, make a horizontal line on the garage door across the top of the bright spots in the beams. It should be about level. Then drop a vertical line in the middle of each of the beams down from the horizontal line. Those are your reference points. Back the car up about 25 feet from the door. Adjust your low beams so that the TOP of the bright spot of the beams is AT BUT NOT ABOVE the horizontal line with the beams centered on the vertical lines. You should be good to go, the high beams will be good if the lows are adjusted properly.
http://www.moddedmustangs.com/forums...p-vote-me.html ![]() TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER) MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER TRUNK MONKEY CREW FOUNDER |
Your Mom's Favorite
2007 Mustang GT
Here you go...something like this...
Luis my man.....
what is all this "REP ME" stuff about... am I supposed to be doing something I haven't been?????
![]() 2.6l KENNE BELL 298 Stroker, Ported heads Pro Motion Built 3650/McLeod RST/ MGW Short Throw Long tube/O/R X /Borla Touring 8 rib/65 lb injectors/GT500 twin fuel ET Drag Slicks/3.73 gear Detroit Truetrac /CDC AGR Spoiler |
#11 | |
You can positive rep, or negative rep people for either good or bad posts. Of course, you can do it at your own discretion. just click the scale thats beside the triangle at the bottom left corner of a post. |
Threads Similar to: Headlight Adjust
| What do I adjust the timing on crank&cam??? | JONJON | 5.0 Mustangs | 10 | October 17th, 2007 07:53 PM |
| CAn you adjust the gas pedal? | 03_StangGuy | 99-04 | 17 | September 4th, 2007 12:14 AM |
| adjust clutch | 5LBennett | 5.0 Mustangs | 1 | June 22nd, 2007 08:38 AM |
| how to adjust the clutch cable | macnesa23 | 5.0 Mustangs | 0 | September 1st, 2006 08:05 PM |
| Timing Adjust For Nitrous | ChrisJ | General Tech | 7 | July 18th, 2006 09:25 PM |
