06 GT with bolt ons
I sucked
Injectors or ?Lifters?
I have an 06 GT with just bolts ons. I have just under 28K on her. Synthetic oil changes every 5K. Run 89 OCT. On the right side I have a loud ticking it doesn't sound like a lifter. Not sure if the 197's have em....newbie ?. any help out there?
Kyle Busch Haters Club!! Member Uno! Tony wrote "Blowers blow, turbos suck, and nitrous rules!!! lol " Borla cattless L/T's topped with Flowmasters , Roush short throw, JLT2 CAI w/ X-CAL2 from Brenspeed, Bullit 18X9 and 18X10 deep dish. |
2005 Mustang GT
10.32@137.70
could be an exhaust leak
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system 326 cubic inches of Twin Turbocharged hell will be running soonTuned by Wes @ TPS ![]() |
MM's resident Juice head
07 Mustang GT
sewing machine "ticking is normal for the s197's" Is it getting worse or staying the same?
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
Your Mom's Favorite
2007 Mustang GT
Eats Chevys, Shits Imports...
I got the same thing on the same side. If it's a lifter, no big deal...It's just a clogged lifter resulting in low oil in the lifter. If you ever pull your valve covers off, just clean 'em up.
http://www.moddedmustangs.com/forums...p-vote-me.html ![]() TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER) MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER TRUNK MONKEY CREW FOUNDER |
mod motors dont have lifters
07 gt-20"maas/toyo t1r-frpp handling pac-frpp drag pac/3.55-manual-frpp x pipe and exhaust-frpp headershurst short throw shifter-frpp/whipple 500hp twin screw kit, cervinis ram air iv, mcleod twin disc clutch, billet flywheel, zex 75/175 shot
you can test the injectors by applying voltage to them (12v) but anything longer than a split second could burn them out. i had some clogging and had to clear them. use a extra injector elect plug to ease the process and when making the elect contact for the split second you will hear them click. clicking is usually a good sign that their working, could still be plugged or? but at least its doing something.
2006 Mustang GT
539rwhp / 482rwtq
This motor has a camshaft roller follower which has a valve lash adjuster,.....they do tick but not really loud. However this car did have a recall for the valve lash adjuster which resulted in loud ticking but given the mileage, I don't think it may apply but I could be wrong. Could see if the recall applies, if so then that is likely your culprit. I think this was noticable once the car was at normal operating temp, or after a long run on the highway
Either way if you running headers, then it could be an exhaust leak. If stock then I doubt its exhaust. As for the injector, not sure, as an injector that was acting up would set a code on our cars, it just real finnicky in that area. |
06 GT with bolt ons
I sucked
yeah i will have to look for when it's the worst. I have been running the alternative fuel safe for regular engines. So I thought that might have plugged up an injector. It's not an exhaust leak more on the top of the engine.
Threads Similar to: Injectors or ?Lifters?
| Lifters Going Bad | burnout5.0 | 94-95 | 11 | November 6th, 2010 11:40 AM |
| sticking lifters | stephen | V6 Mustangs | 1 | October 18th, 2007 11:48 AM |
| Solid lifters | JBIGBOOTSY | 5.0 Mustangs | 4 | September 21st, 2007 01:39 PM |
| roller lifters | Steves LX | 5.0 Mustangs | 7 | April 9th, 2007 09:29 AM |
| Hydraulic Lifters | ssajdowitz | V6 Mustangs | 2 | October 30th, 2006 10:23 PM |
