2008 mustang gt
crank bolt and udp's
i am about to install steeda udp's and have heard that i will need a new crank bolt. anybody install these withour buying a new crank bolt and have problems?
pypes violators, jlt/x3 93 oct. from BAMA, pypes o/r x pipe, steeda udps |
2007 GT
I reused the stock bolt and havent had a problem. just make sure you tq it the way it says and you can not reuse it more then once.
I reused the crank bolt and haven't had a problem but if I had known ahead of time that it is supposed to be replaced then I would have. The $6 for the bolt is probably worth it for the peace of mind.
2006 Mustang GT
+1 on reusing the crank bolt. No issues here either.
2008 mustang gt
thanks guys i thing i might just go to ford and get a new one just to be safe
like mike said i would rather be safe then sorry
IBEATU
06 GT, 98 GT, & 93 Notch
Are you refering to the longer one that they send you with udp's?? You have to use the new one to get your crank pulley started, then you remove the new bolt and reinstall the original one.
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
Its the factory crank bolt he is talking about. For some reason they are not supposed to be taken in and out more than once.
IBEATU
Never heard that before
2007 GT
Ford started saying that when they started recomending the different tq sequence for it. Ford also recomends that you dont mod your car. but it is only 6 bucks and if he is worried about it then get one. The directions that come with it should say that you will be alright to reuse it once.
autozone sell them from mr gasket...make sure u perm tec the key slot in damper..or u will leak oil..
SECTION 303-01B: Engine — 4.6L (3V)
2006 Mustang Workshop Manual IN-VEHICLE REPAIR Using a new crankshaft pulley bolt, install the bolt and washer and tighten the bolt in 4 stages. Stage 1: Tighten to 90 Nm (66 lb-ft). Stage 2: Loosen 360 degrees. Stage 3: Tighten to 50 Nm (37 lb-ft). Stage 4: Tighten an additional 90 degrees ford part number on the bolt is F5RZ 6A340-B
06 Black GT 5sp/JLT II CAI/XCALSCT2/B a m a 93 Oct Race Tune/FRPP Stingers/Hurst Shifter/GT500 Spoiler//Steeda ultralite Springs & rear pan hard rod/Bullitt Strut tower brace/07 Gt manifold cover/Shelby Lip/Sequential HURST CREW MEMBER #17 |
Threads Similar to: crank bolt and udp's
| New Crank Bolt for UDP's - which one? | black07cs | 2005 - 2010 | 3 | December 8th, 2007 09:27 PM |
| UDP's | 07 STROKER | 2005 - 2010 | 7 | November 21st, 2007 03:53 PM |
| Which UDP's? | DCstangGT | 99-04 | 5 | June 10th, 2007 07:36 PM |
| Crank pulley bolt? | 88gtstang | 5.0 Mustangs | 3 | March 9th, 2007 10:23 PM |
| Are all UDP's the same? | 2ndChildhood | 5.0 Mustangs | 7 | August 21st, 2006 06:36 PM |
