Buying a K & N CAI
Ok so I'm going to purchase a K&N cai, I was just wondering where I could get the best deal on the part.
RLY SRS
Does K&N provide a tune wiht CAI?
I would google "Mustang K&N CAI"...It shoudl turn up alot of results |
$260.00 from www.SFXperformance.com
..........05 GT... 2 1/2" DROP.......... |
2006 GT
11.99@114
http://www.lmperformance.com/6202/73.html
No tune needed. Dont forget to remove your postive battery cable before instalation.
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
RLY SRS
I dont see how they can do that...Is the intake so close to stock that it deos not need one?
The tune is needed when the inlet pipe inside diameter is changed,this changes the air speed thru the intake.So i would guess the K&N inlet/plastic tubing is the same size inside diameter as stock,just with a high flow filter.
My theory is is if your going to do the intake,go all the way like the WMS one we talked about in that other thread... Look how big and short inlet piping is on the WMS intake,less bends the better,especially if you add more mods later.Of coarse the price goes way up because it has to come with a hand held tuner...(SCT)...
RLY SRS
I really like that intake set-up...Reminds me of an f-body intake set-up...Is there a Mach3 kind of hood for the new stangs? Seems like you could almost make the mach 3 hoos functional like it is on the foxes with the stormin norman set-up...
So if the K&N is the same size then why not just buy a filter and stick with the stocker? |
$260 on 5hp
i'll leave it at that
#10 | |
06 GT with bolt ons
I sucked
I read an atricle where the tested several diff CAI and the K&N actually cooled the air more than other CAI with tunes. They had the coolant res relocated and a slightly modified radiator cover that allowed cooler air from the grill into the intake. Of coruse the tunes added a tenth or 2 of a second but the cooler the air...well you guys know more than this newbie!!
#12 | |
Heres the same intake i posted above,on the car...they blew away the 3 others tested at the track,not a dyno...heres the results from the tests. -------------------------------------------------------------------------------- Was just reading an article in Mustangs and fast fords... The tested AEM...vs...Steeda.....vs....WMS... And this is a good test because it's not on a dyno (dyno's don't win races,sometimes to get a 2 hp increase at a certain rpm,there giving up mid range torque...not good)).. The car was stock with 20 inch wheels.Outside Air temp,oil temp etc were stickly monitored,and even the air/fuel ratios were monitored to make as identical as possible.3 passes on each intake. DA - 1434 feet above sea-level- Stock..........................13.85 @ 97.28 AEM brute force...........13.83 @ 97.40 Steeda High Volocity...13.76 @ 98.14 WMS.........................13.69 @ 98.68 even though the DA shot up to 2366 feet, and also had the lowest 60 ft times.This intake will most likely respond even better with a few mods and really seperate itself from the others..It also gives the IAT a fixed temp signal of 77* which directly influences power gains.I like it too because it comes straight of the t-body to the front grill,has a modified raditaor cover.Comes with an SCT tuner also
06 GT with bolt ons
I sucked
That looks good! Thanks for the correction, I wish I would have read that before I bought my SLT2. But I am happy with the increased throttle response I got with my setup. Check out ssinserts.com they have some nice stainless access for under the hood.
#14 | |
Threads Similar to: Buying a K & N CAI
| Buying a new car | okcmustangfan | Modular Mustangs | 3 | April 13th, 2007 07:53 AM |
| serious about buying this one | joe 5.0 | 5.0 Mustangs | 3 | March 30th, 2007 08:02 PM |
| buying a 88 89 need some help | g-string | 2.3 Mustangs | 5 | March 26th, 2007 03:59 PM |
| Buying a cam? | NATE | V6 Mustangs | 6 | March 23rd, 2007 05:45 PM |
| buying 95 GT | delgadog | 5.0 Mustangs | 6 | March 14th, 2007 02:42 PM |
