Rebuild ideas - Forums at Modded Mustangs
post #1 of 14 Old January 4th, 2017, 04:30 PM Thread Starter
Rebuild ideas
So I've decided to just pull my motor and have it rebuilt. I found a shop here in Fresno that if I bring them my engine, they will do everything for 2,000. I had mentioned to the owner that I've thought about upgrading parts and he said whatever I want upgraded, he will put in for me.
Question 1. Is 2,000 acceptable for machining, new crank pistons, rods, gaskets and whatever else is needed?
Question 2. If I decide to upgrade, what should be upgraded? Long term goal for the car would be no more than 550 rwhp and that wouldn't be until I could get around to a supercharger in the not-so-near future.
I still haven't pulled the motor. I'm going to buy an engine hoist and hopefully do it this weekend. We've been having some awful weather so I haven't been able to do much the past couple of weeks.
Brandon08GT is offline
post #2 of 14 Old January 5th, 2017, 10:33 AM
The 2000 is just for labor I'm assuming. I don't think it is unreasonable depending on the quality/rep of the shop. Any dyno testing/break in with that? Tuning?
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #3 of 14 Old January 5th, 2017, 02:16 PM Thread Starter
The 2,000 was labor and parts if I wanted a full stock rebuild. He said he has a tuner that will handle that aspect. But that's me bringing him the motor, then pick it up after. I would remove and install into the car. If I just brought him my car, he said around 3,500. There really aren't any good shops that I've been able to find in Fresno. This guy at least is a certified jaguar and Land Rover mechanic, and pictures of his shop show full tear downs on lamborghinis and skylines. Those aren't easy to work on, so he must be doing something right.
post #4 of 14 Old January 5th, 2017, 04:37 PM
Well you were talking about wanting to eventually running 550 rwhp. You're not going to do that with a stock rebuild.
Forged pistons and rods will cost about 1200-$1300. Rings and fasteners probably a few more hundred. If you want a forged crank that's another $750. So your at $2000+ in parts without touching the top end.
If you're going to do just a stock rebuild I think that's a great price including parts. But you are never going to be able to run the power you want. Just saying.
07 Boss is offline
post #5 of 14 Old January 5th, 2017, 06:09 PM Thread Starter
Yeah that's kind of what I'm debating right now. I've been looking at parts all day and I think I'm going to talk to him about just doing the forged rods and pistons for now. I'm gonna try to stop in and meet him face to face tomorrow morning. If he's getting parts already and that's including new pistons and rods, maybe it'll only been 500 or so more for upgraded parts.
Figure while the motor is out, I might as well do long tubes as well. There is no way I want to install those with the motor in. They are just so damn expensive. Which ones are you using?
post #6 of 14 Old January 6th, 2017, 10:29 AM
To me , that is a smart compromise. The rods and pistons are the weak points. The stock crank can hold a ton of power and I haven't heard about many, if at all, failures of the stock crank. The only reason i would change it is if I wanted to stroke it for more cubes.
You can get headers in with the motor in. They're just a PIA. It will be a ton easier to do with the motor out or with an aftermarket K-member. I run Pacesetters but that might not suit you depending on what kind of weather you drive in. They are way inexpensive but are not made of stainless. I don't have to worry about rust so it is a non-issue for me.
07 Boss is offline
post #7 of 14 Old January 6th, 2017, 12:33 PM Thread Starter
I was actually researching to try to find anyone that had a crank fail and I couldn't find any. I think people who go for that much power just go away from the stock motor altogether.
I thought that's what you were running. I'm headed back home to Florida in a few months so rust is absolutely an issue for me though. Otherwise I would just go with what you have. Most of your setup is what I'm going for. Whipple superchargers is literally two minutes from my house. I wish they did service work and I could just bring my car to them.
post #8 of 14 Old January 6th, 2017, 01:54 PM
gtscrewd
faym 08's Avatar
The headers on our cars are not as bad as people say. If cash is that tight wait on headers and put everything you have into the engine.
July 2013 rotm winner
faym 08 is offline
post #9 of 14 Old January 8th, 2017, 11:39 PM
Mustang Performance Racing, Boynton Beach FL built my stroker.
http://i489.photobucket.com/albums/rr254/svtwin73/image_zpsc7776416.jpg
5.0 stroker, Roush 2300 w/3.2", 10% overcrank, Bullet-RGR spec cams, Kooks LT w/cats, FM axle back, TruTrac 3.73
Svtwin73 is offline
post #10 of 14 Old January 9th, 2017, 07:36 PM Thread Starter
If I was back home that'd be an option. I won't be until May though and only having a motorcycle when I work 50 miles from where I live is miserable. How much do you spend if you don't mind me asking?
post #11 of 14 Old January 9th, 2017, 10:47 PM
$4k for a competition built forged 302 stroker with my 4.6 block.
Svtwin73 is offline
post #12 of 14 Old January 10th, 2017, 11:20 AM Thread Starter
That's pretty much what I'm looking at right now for stock parts and labor alone.
post #13 of 14 Old January 10th, 2017, 12:07 PM
MPR has a pretty good reputation as well, if you can hold out that long. IDK if you have the option, but you may be able to get a used stock longblock, from a junkyard, on the cheap to hold you over if need be. If you are pulling the engine yourself anyways then it won't be to hard to drop a stock replacement in. Would also keep the car running and driving while your new engine is built.
2003 Redfire & Black V6. Full suspension, 8.8 w/ 4.10s, tuned. 4.3L stroker + turbo capable of 550 hp soon
DD: 2015 SHO PP, 12.87 @107 1/4 mile (1.8 60') on 93 octane tune/CAI only. SAE corrected: 369.4/451.4 on E20, full Bolt On
Derfdog15 is offline
post #14 of 14 Old January 10th, 2017, 05:45 PM Thread Starter
I wish I had that option, but I don't. I only have a motorcycle to get me around and I also don't have any of my tools. All my stuff is back home in Florida. I'm gonna drop it off with a local shop tomorrow to have everything done.
Been looking at parts online and was wondering if anyone has any experience with mod max racing? They have decent prices for what I'm looking for, just haven't heard of anyone purchasing from them.
Human Verification
