BMR uca.....Help
Does any one know what size wrench it takes to adjust the jam nuts. This has been the worst project ive done on a car in a while. You cant get to anything.
2005 mustang gtZex nitrous Tokico D-Spec Hurst shifter Nitto Drag Radials Hooker exhaust Raptor shift light Foose Nitrous Wheels Eibach pro kit 4.10 gears |
Moderator
2007 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
lol that piece is a pain...my friend helped me but we did it on a lift after i failed miserably on jack stands. Does an adjustable wrench fit? I don't remember what size he used
no its to big for a adjustable. What a nightmare!!!!!
Moderator
2007 Mustang GT
hmm i'm trying to remember what it was. It's close to an inch and I know that it's a left handed jam nut meaning it tightens to the left. I remember my friend reaching over the differential with it on the lift and it being a nightmare. I'll say this though, once it's done you will be very happy with it, wheel hop is non existant with that and the bmr billet aluminum lowers
I have non adj billet lowers so I have no wheel hop. Im doing it to get rid of the drive shaft vibration. One piece chromoly d/s is the way to go. Huge difference but I cant take the vibes. Hopefully the uca can adjust it out.
2005 Mustang GT
10.32@137.70
I think the jam nut was a 1 1/2" but I used a 18" cresent wrench
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system 326 cubic inches of Twin Turbocharged hell will be running soonTuned by Wes @ TPS ![]() |
I dont think there is enough room for a 18" wrench on mine. Did you have to adjust your pinion angle? I think that can only be done on a lift.
Moderator
2007 Mustang GT
you can do it on jackstands, you just need to make sure you get the car up high enough and make sure you have the rear stands right under the axles to keep it loaded. If you have access to a lift then I highly recommend it
