check engine light
Old April 4th, 2008, 09:09 AM   #1
06blackonblack's Avatar
2006 mustang gt vert
12.2@117 at 498 rwhp on stock tires
06blackonblack is on a distinguished road
check engine light
I just finished installing my whipple and I have a question. I started the car before I hookied up the fuel level wires and I got a error message on the control panel and the check engine light was on. I fixed the gauge wiring and the error message went away but the check engine light is still on. If the check engine light turned on due to this code will it turn off by itself? Another angle is there was another problem would it be listed like the fuel gauge problem was? The car starts and runs fine so what do you think?
I will list another post regarding the install, impressions, etc.... I just want to fix this first. THANKS
Old April 4th, 2008, 09:13 AM   #2
kenneth's Avatar
2006 Mustang GT
11.45@123.61
kenneth has a spectacular aura aboutkenneth has a spectacular aura about
unhook your battery for about 1/2 hour it should clear the check engine light, if there is still a problem with something the light will come back on.
Stock for now.
Old April 4th, 2008, 10:27 AM   #3
presto!!! it is gone. Thanks for the tip on the battery.
Old April 4th, 2008, 10:29 AM   #4
kenneth's Avatar
2006 Mustang GT
11.45@123.61
Glad to help out.
Stock for now.
Old April 4th, 2008, 10:42 AM   #5
2005 Mustang GT
MustangMark is on a distinguished road
Send a message via MSN to MustangMark
Now that is all solved so you can do a nice write up on ur experience with the install and some tricks and tips etc....lookin foreward to the post.
Old April 4th, 2008, 11:08 AM   #6
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
06 black, what are using as a handheld? If it's an SCT when you reset codes it also resets the check light. If the light were to have returned immediately after then you know you have more trouble.
I see you got it all straightened out, but this was another alternative.
FLICKR Unique Imagery
Old April 4th, 2008, 11:36 PM   #7
no scanner just the ford flashing device.
I will post info hopefully helpful to any other takers looking to get this very soon as time permits for me.
Old April 4th, 2008, 11:45 PM   #8
onederful100's Avatar
2007 GT 2000 GT
onederful100 has a spectacular aura aboutonederful100 has a spectacular aura aboutonederful100 has a spectacular aura about
congrats on the whipple!
http://i243.photobucket.com/albums/ff26/onederful100/avatars/sig-52.gif
2007 GT 5spd
2000 GT 5spd
whipple crew member
2-Stang Crew
My Car
Threads Similar to: check engine light
check engine light manny122 94-95 4 March 16th, 2008 03:42 PM
NO more check engine light badf150boy123 99-04 3 March 4th, 2008 12:21 AM
Check Engine Light On... Racerchik02 V6 Mustangs 34 November 30th, 2007 12:27 PM
Check Engine Light skimboard71104 V6 Mustangs 5 November 27th, 2007 05:34 AM
Seriously need Check engine light help!! jsteves1313 V6 Mustangs 4 November 5th, 2006 02:24 PM
