Engine light is on....y?? (CAI and Tune just installed)
Old April 9th, 2008, 06:30 PM   #1
06 Mustang GT
no idea
lockhat17 is on a distinguished road
Ok so i installed my cold air intake and a 91 octane tune today. I took it out for a spin and went fine cept for some heavy shifting which I guess is normal at first. Well, a few hours later I had to go to class and it stuttered on me and then the second time I turned the key it started, but the engine light was on. I'm running 91 octane fuel and everything is connected and bolted well on the cold air intake. Also, when the tune completed it said it was successful and I followed all instructions. Is this normal or what? The car still feels kinda jumpy and stuttery tho.
Arizona's S197
JLT CAI + Diablosport
Koni shock/spring adjustables
Saleen Front Sway Bar
SLP Loudmouth Axel Back
Trufiber heat extraction hood
Old April 9th, 2008, 06:32 PM   #2
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
MAF installed correctly and hooked up?
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old April 9th, 2008, 06:33 PM   #3
07 STROKER's Avatar
07 Mustang GT
run the trouble code checker on the tuner...it should tell you whats wrong as well...as well as clear it (shut off the engine light)
Old April 9th, 2008, 06:36 PM   #4
mustangrebuilder will become famous soon enough
get the code but dont clear it right away, find otu what is wrong first, cause when you clear codes you also clear all the modules memory too. if its nothing bigg then clear it but i would hold off on clearing it right away.
Old April 9th, 2008, 06:37 PM   #5
07 STROKER's Avatar
07 Mustang GT
ya thats what I meant...I always write them down before clearing them
Old April 9th, 2008, 06:39 PM   #6
06 Mustang GT
no idea
Ok, yes the MAF is connected correctly. Is it bad to be driving with it on because as i said, i'm a school and my tuner is at home....
Arizona's S197
Old April 9th, 2008, 06:40 PM   #7
no its fine you can drive with it on
if for some reason it started to flash PULL OVER!!!
Old April 9th, 2008, 08:50 PM   #8
fosted285's Avatar
2006 Mustang GT
11.85@116
fosted285 is on a distinguished road
Send a message via Yahoo to fosted285
Just an odd thought, but could the greater air flow take the stock MAF bayond it's capabilities of accurate reading and require an attenuator such as the MAFiA? I know this is usually not an issue, but perhaps....
Old April 9th, 2008, 08:52 PM   #9
qwik48r's Avatar
alotta shit
no fat girls fast
qwik48r is a jewel in the roughqwik48r is a jewel in the roughqwik48r is a jewel in the rough
Send a message via AIM to qwik48r
load stock tune, dont start car. disconnect battery, hit breaks turn on lights, honk horn, connect it back after 10 minutes. reload your tune as usual
mind your business what i drive... i'm on a fucking mustang forum.
qwik's build
Old April 10th, 2008, 01:57 PM   #10
06 Mustang GT
no idea
OK, these are the trouble codes i'm getting:
P0148 - Fuel Delivery Error
P0171 - System too lean (Base 1)
P0174 - System too lean (Base 2)
P1000 - OBD Systems Readiness
The car feels sluggish so if its having trouble getting enough fuel this makes sense. But I have no clue why its occuring. Is there a specific parameter on the diablosport I need to adjust to coincide with my JLT CAI?? Who else has this combo of intake and tuner?
Arizona's S197
Old April 10th, 2008, 02:04 PM   #11
qwik48r's Avatar
alotta shit
no fat girls fast
hmm did you do the above^ and reset everything?
qwik's build
Threads Similar to: Engine light is on....y?? (CAI and Tune just installed)
Installed brenspeed tune...just put in gears Rico-mofos 99-04 3 February 20th, 2008 11:03 AM
Where to TUNE new Engine.... NY NJ PA OnePass2Many 99-04 7 December 2nd, 2007 06:31 PM
Having a supercharger installed by a friend - how to tune? silvel2edge 2005 - 2010 3 May 21st, 2007 06:40 AM
How much is it to get an engine installed? (351w in a 65) nba1341 Classic Mustangs 3 May 1st, 2007 09:29 PM
engine tune Mustangfan99 Modular Mustangs 4 April 3rd, 2007 08:46 AM
