tire marks on inner fender wells
Ok, so I have tire marks on my inner fender liners, and when i go over speed bumps, and sometimes just potholes, my car makes funky ckrunkling (yea thats technical) sounds. kindof like popping. i am thinking that i might have some suspension problems. I just had an alignment done and my caster and camber were out of specs, and they said that mustangs did not have adjustable caster nor camber. i dont have any specifics, and i hate taking my car to the stealership. any ideas? i was already planning on replacing springs, shocks, and putting steeda upper shock mount plates on.
any other thoughts?
-1970 428 Mach 1 456 hp 4spd Tangelo Pearl -2007 Mustang GT Alloy Metallic *(awaiting modification) Hurst Crew Member No. 5 |
you can get camber plates to fix it
Are you using stock wheels?
![]() 2.6l KENNE BELL 298 Stroker, Ported heads Pro Motion Built 3650/McLeod RST/ MGW Short Throw Long tube/O/R X /Borla Touring 8 rib/65 lb injectors/GT500 twin fuel ET Drag Slicks/3.73 gear Detroit Truetrac /CDC AGR Spoiler |
stock 18 fan blades. i cant figure out where the tire marks are coming from.
I would take it back to the dealership... are the fender liners attached well?
^ my guess
One Man Wolf Pack
Is the suspension stock?
![]() ΜΟΛΩΝ ΛΑΒΕ
stock suspension everything, i did hit a curb at a point in the past...
but it keeps getting wierder, i just pulled out of the garage and got a "clunk" then parked at target. same kluck. its going to the dealer this week. (if its under warranty do they charge you to give you an estimate?)
IBEATU
06 GT, 98 GT, & 93 Notch
No they won't charge you for an estimate. Won't charge you for anything unless its from the curb
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
Golf Pencil Kawk Juggler
if its under warranty they should fix it for free. Its not a 10k honda. Its a 29k+ high end vehicle.
![]() Procharger D-1SC Kit - Pypes O/R H - FRPP Stingers Team Ricer GT Co-Founder
if i could buy a new honda for 10 grand it would be my dd. the absolute base model civic is 15 grand.
Threads Similar to: tire marks on inner fender wells
| Water Marks | johnbarberr | V6 Mustangs | 11 | September 4th, 2007 10:33 AM |
| Inner front fender wells | WAR-PARTY | Drag | 6 | June 18th, 2007 06:55 PM |
| Painting wheel wells. | 1LOUDGT | Visual | 5 | February 7th, 2007 09:08 AM |
| Fox body fenders/wide wheel wells. | Mr_Evil | 5.0 Mustangs | 0 | December 5th, 2006 02:46 AM |
| HELP!!! w/fender...... | Ricerssuck88 | Visual | 3 | April 28th, 2006 08:57 PM |
