07 mustang gt
Sniper Tuning Software
i was wondering if anybody has experiance with the sniper tuning software, i'm considering it for my 07 kb blown gt.
its good because you can tune more than one vehicle... (two out the box)
and it allows adjustment of EVERYTHING.. i compare it to HPTuners. |
07 mustang gt
do you have any personal experiance with it? i was wondering if it even works for the 07 models because it does not say 07, only 06
48.47@ 12.58
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 10 reviews
it should work with 07 models as well.
<-- on the SCT side of the house if you decide to go that route.
07 mustang gt
so whats the no BS assessment of the sniper tuner, and is it good for supercharged cars. i know that it works with s/c cars but how well i wonder. also which one is the best to get, i know one type is more for shops and pros but is that still the best one to get?
Works great , more conservative so you dont mess anything up than needed sometimes but none the less will make the car run great usually right off the bat , Special Forces is all 9 out of 10 guys need , Commando is more for people that know a little more about tuning .....
07 mustang gt
sounds pretty good, i'm having a problem with my stock kenne bell tune that's why i'm looking into other options. i had a local shop run my car on the dyno and the car was no where near the advertised power rating. when i returned the tuner back to kenne bell they said it was fine and could not explain the poor performance, they keep asking me if i have a vac leak and to double check everything, which i have multiple times with no luck. one thing i realized was that the sniper software does not have a 39lb (cobra) injector option that the kenne bell runs. also what do you set the maf at for the 90mm lightning maf that the kb uses? ill be ordering the sniper if these things will not be a issue
07 mustang gt
thanks for the help.
39s are now included with the newer versions of the Special Forces ....and yes just set the MAF to FORD and then to the 90mm lightning calibration
07 mustang gt
oh, ok i see now, ford than 90mm lightning. thanks i think ill be picking a sniper soon.
Threads Similar to: Sniper Tuning Software
| sniper tuning software....what do you guys think? | 7-up man | The Clubhouse | 6 | January 17th, 2008 07:53 PM |
| In regards to Sniper Software | RStrick0352 | 2005 - 2010 | 1 | July 10th, 2007 08:51 PM |
| anybody using sniper tuning software | dumps | 2005 - 2010 | 2 | July 10th, 2007 10:30 AM |
| Sniper tuning software | silver99gt | 99-04 | 2 | April 29th, 2007 06:29 PM |
| Looking for a copy of Sniper tuning software. | Juggalo_X | V6 Mustangs | 11 | January 24th, 2007 09:43 PM |
