LinkBack (1) | Thread Tools |
#1
Mufflers are not even
Okay, I recently installed some JBA Axel-back Mufflers onto my car. I put the right one on fine and also the left one. I lowered the car back onto the ground and noticed that my left one is lower and sticks out further than the right one. Now, I am not mechanically inclined, but I swear I followed the directions to the T. What is up with that? Do I need to take the left one off again and try to bang the "hooks" on the muffler itself to try to make it even with the good one? Or do I remove it and bang out the "hangers" on the underside of the car?
If you need to, click on the pic below to blow it up.
K&N CAI, JBA Exhaust, Ford Racing X-Pipe, Billet Chrome Fuel Door (with the contour line), SCT X3 Tuner...more to come ![]() http://www.yikers.com/video_kid_cras...y_mustang.html |
MM's resident Juice head
07 Mustang GT
loosen it at the axle back and adjust accordingly...it takes a bit but you will get it...you shouldint have to bend anythig.
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
2005 Civic
GAY!
it was a pain to get my left one right. ( grinding some of the holes deeper for better adjustment, blah blah blah)
but mine is a six and i didn't have the gt hanger so it coulda been just me
slow car member twinky times two the stangs gone ![]() ![]() pypes mid muffler catback with their X-pipe In the top 20 cool peoples list on MM potsticker in training |
One Man Wolf Pack
![]() ΜΟΛΩΝ ΛΑΒΕ
2006 Mustang GT
11.45@123.61
![]() ![]() iTrader: 2 reviews
I think the JBA's are the hardest to get straight, the way I got mine is after I got it close I loosened up the clamps at the H-Pipe and finished adjusting from there.
Stock for now.
2007 Mustang GT
my bassanis where very uneven for a while, it took a lot of work to get them right.........it ended up needing adjusted where the "over axle" pipe met the x pipe....... i just loosened the clamp, twisted it a little bit and BAM, it was right!!!! lol
Bassani Crew Member #3 |
2006 Mustang GT
i had the same issue with my Magnapaks...you can carefully adjust them.
my deletes by pypes where way off... so i cut the hanger and welded em back at the correct angle
that because when you buy a mid muffler, you get two glasspacks and two muffler deletes for however much it is..
IBEATU
06 GT, 98 GT, & 93 Notch
My FRPP Stingers took a little bit of finessing too.
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
Absens haeres non erit
'11 Performance Package
4.61@356.68
I upgraded my hangers and my left is still a little off. I broke it in, then adjusted it some more. Its not noticeable any more unless you are just that anal.
![]() Current: '12 VW CC Sport 6MT | '10 Jetta TDI | '08 350Z Vert | '95 S14 | '85 325e BUY MY SCT X3 UNLOCKED USED TWICE |
Fixed
I found out why my mufflers looked "off." When I put the X-pipe on, I didn't cut one pipe as long as the other one. I shortened the longer one to fit. It's looking good now.
2008 Mustang GT
i had t get someone to watch from the back of the car while i adjusted the pipes at the x-pipe then tightened them down to make them even
Vortech Supercharger,Hurst shifter, Diablo Sport Predator tune, Pypes O/R x-pipe, Super 44 Flowmasters,Hawk HPS Brake pads, Granitelli Slotted and Dimpled Rotors, Goodrich Steel braided brake lines, FRPP 3.73 |
2008 Mustang GT
11.65@122
Just installed my FFRP Stingers today and I have the same problem, except it's my right pipe that's off. I'm gonna loosen the clamp on the axleback and (if need be) the h pipe, have a buddy hold it where it needs to be and tighten accordingly.
Scroll down to the 3rd picture from the bottom. Small paragraphs above & below the picture.
FRPP / Borla Stinger exhaust install - The Mustang Source Forums
07 GT-- Gone But Not Forgotten Military Crew E-5
[QUOTE=jv262002;1247897]I found out why my mufflers looked "off." When I put the X-pipe on, I didn't cut one pipe as long as the other one. I shortened the longer one to fit. It's looking good now.
[/QUOTEMy JBA's are also not completely even, but I am not going to worry about it now. Have compared the sounds between x-pipe, JBA axleback with h-pipe and JBA axlebacks?
RIP 06 Mustang GT New Ride 04 GTO K&N intake, Dynatech Long Tube Headers, Magnaflow catted X, Flow 40s, MS3 Cam and dynotuned by Texas Speed. |
I would just run it down to an exhaust shop. They do it all the time I'm sure they could do it pretty cheap and less time. I hate going to the shop but sometimes it's just worth it.
2010 Roush 427R Convert.
My Corsa's fit perfect the first time, But they should have for what they cost!
![]() Some old men need Viagra, my 427R works just fine!
2008 Mustang GT
I had the same issue installing the Borla axleback.
I ended up loosening the next set of clamps back on the exhaust and that gave me plenty of play to get the pipes in the right spot. I then put a towel on a floor jack to keep the pipes where I wanted them and cranked all the clamps down. Ended up perfect
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/66880-mufflers-not-even.html
| Mufflers are not even | This thread | Refback | June 28th, 2008 09:15 AM | |
Threads Similar to: Mufflers are not even
| mufflers | 95stangvert | 94-95 | 5 | February 20th, 2008 01:02 PM |
| 5.0 Mufflers! | 78mach1 | 5.0 Mustangs | 23 | November 18th, 2007 10:24 PM |
| mufflers | SLNGT2007 | 2005 - 2010 | 18 | October 21st, 2007 08:14 PM |
| mufflers | 96gtponyred | 96-98 | 1 | August 21st, 2007 09:11 AM |
| No mufflers | Boris | General Tech | 2 | April 12th, 2007 01:15 AM |
