2007 Mustang GT/CS
13.89 @101.34
1st to 2nd Shift???
Does anyone have problems with the 1st to 2nd shift when racing. My car did it with the stock shifter, so I threw in a hurst. and it's not as bad, but it still catches right between the gears and doesnt allow me to get in 2nd when I get on it and shift hard. If I baby it it is fine. Any Ideas...
![]() 2007 Mustang GT/CS JLT II Intake SCT X3 W/ Brenspeed tune Flowmaster Axel Backs Pypes O/R H Pipe Hurst Short Throw Upper Billet Grille Front & Rear Blackouts 3.55 Gears |
Worn synchros or a bent shift fork are most likely the problem
I get the same problem from time to time under hard acceleration. I have a Hurst also.
07 GT-- Gone But Not Forgotten Military Crew E-5
MM's resident Juice head
07 Mustang GT
same here...it rings slightly....woith the MGW in its not as bad...syncro probably..Luis GT has it BAD
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
2007 Mustang GT/CS
13.89 @101.34
Dont you have to pull the tranny to replace syncros or a fork? Even When it does go in gear while racing, I still have to put some muscle into it.
07 Mustang GT
07 Mustang GT
ff to 205 in the vid a listen closly to the 1 to 2 shift
2007 Mustang GT/CS
13.89 @101.34
I can hear the shift... Thats what mines does if I can even get it in to second.. Sometimes it just stops dead in between the two... and I end up in neutral...and put the clutch back in and then shift into second... Its really embarrassing...
Yea I get that shift scratch at times. Not to thread jack but I noticed a whining while accelerating in 3rd. Not hitting the throttle hard just normal acceleration. No, I don't have a s/c. Yes, I'm sure....
. Has anyone else heard that
MMs Ford Racing Nut Swinger
2007 MUSTANG GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Guess Ive been lucky. No problems ever 1st to 2nd or from 3rd to 4th to 5th. Under hard acceleration 2nd to 3rd was a bitch with the stock shifter.
Have had 0 shifting issues since installing the HURST... |
2007 Mustang GT
usafimj, i know the sound you are refering to, and all the s197s that i have drove (lots of them, i work at a dealer) make that noise. Dunno why or what it is.
Bassani Crew Member #3 |
yes you do. and its extremely extremely expensive. My car's in the shop right now, they're replacing my 3rd gear synchros and its $990!
2007 Mustang GT/CS
13.89 @101.34
Whats the best way to tell if you have bad syncros??
07 Mustang GT
Gear lockout is a sure way to know...kind of what the OP is describing
I can't tell you... mind grinds and lock up when I get on it, normal cruising it works marvelously... and what I got from y dealership was "it's normal behaviour of the car"
07 Mustang GT
that is so wrong....
I no longer care... it's now nothing more than a car to get me to point A to point B... it's not even worth bragging about it.
07 Mustang GT
sell to me for parts car???
and what em I supposed to drive then... I don't have another car.
07 Mustang GT
just messin
Threads Similar to: 1st to 2nd Shift???
| Slight raddle around 3000rpm in 1st and 2nd. | Arikara | 2005 - 2010 | 8 | February 26th, 2008 07:50 PM |
| 96GT T-45 1st-2nd Grind... Help! | KaskaB | 96-98 | 4 | November 12th, 2007 02:18 PM |
| Kissing on 1st,2nd,or 3rd date? | MustanG_guy17 | The Clubhouse | 19 | October 7th, 2007 02:36 PM |
| 1st and 2nd | hmotes | 5.0 Mustangs | 27 | November 9th, 2006 07:02 AM |
