LinkBack (1) | Thread Tools |
#1
Full cage
Car is off to have full cage conversion from present 8 point roll bar. Car spent much of the day being prepped as bars have to go through dashboard and the plan is to run them through the outer a/c vents. Then a bar will run from left to right between the steering wheel and dash (so some instrumentation was moved). Bars along the roof and an Xbar added to rear. Car is having a lot of safety welds done at the same time. Technically we don't need this until 9.99 but we won't try the 20 lb tune without it, although we calculate car will run maybe 10.2 or 10.3 with the 20.
2007 Mustang GT
Sounds like you will have one awesome ride when you get done....nice job so far
![]() Hurst Crew Member #15 |
Amazing
One Man Wolf Pack
Sweet. I think you need some nitrous too
![]() ΜΟΛΩΝ ΛΑΒΕ
Safety first is a good way to go... got to get some pics up when you get it back
I am dreading the day when I get down to 11.5. I will have to have a cage and I don't know if there is a decent one that will work in a vert... thinking of a second stang... that would be my biggest mod by far...
![]() 2.6l KENNE BELL 298 Stroker, Ported heads Pro Motion Built 3650/McLeod RST/ MGW Short Throw Long tube/O/R X /Borla Touring 8 rib/65 lb injectors/GT500 twin fuel ET Drag Slicks/3.73 gear Detroit Truetrac /CDC AGR Spoiler |
nice man good luck with it
#8 | |
2005 Mustang GT
10.32@137.70
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system 326 cubic inches of Twin Turbocharged hell will be running soonTuned by Wes @ TPS ![]() |
2007 Mustang GT
hey forensic, what are you going to do with the cage in the car now?!? are you going to build the new one "off" the old one? if it is still mostly intact and you remove it i might be intrested in it. Thanks
Bassani Crew Member #3 |
#10 | |
How is he doing that? Roll bars need to be 1 3/4" to be IHRA/NHRA legal. Roll cages only need to be 1 5/8" to be legal. I suppose you could use 1 3/4" for a roll cage but that would be one heavy SOB. I'd definitely find out how he is doing it so you know what you are getting.
#12 | |
2006 Mustang GT
11.45@123.61
![]() ![]() iTrader: 2 reviews
you should be able to dip in the 9's with the 20Lb. tune, don't you think?
Stock for now.
#14 | |
We're looking into an aluminum intake manifold and 83 lb injectors with the new hat to take three pumps. Then upping boost to 25 lbs should consistently break the barrier. But the track times have come down so much, so quickly with the new turbo setup that we need to maybe slow the progress down a tad, step back and just think about things some more. |
2006 Mustang GT
11.45@123.61
I was showing some co-workers your videos and they can't believe how your car runs AND it's still street legal, also told them that it's limited use on the street.
Stock for now.
#16 | |
#17 | |
2006 Mustang GT
11.45@123.61
How did you'll make out on the bracket race? I want to give it a shot soon.
Stock for now.
#19 | |
Lance dialed in at 10.68. He actually ran a 10.66, so he broke-out and lost. But if you look at the other guy...he dialed in at 11.54 and ran 11.544...so he would have won anyway. Lance made six passes that night and 0.098 of a second separated his slowest from fastest times. He's really consistent.
Golf Pencil Kawk Juggler
Next stop is PINKS ALL OUT!!!!
![]() Procharger D-1SC Kit - Pypes O/R H - FRPP Stingers Team Ricer GT Co-Founder
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/69305-full-cage.html
| Full cage | This thread | Refback | May 4th, 2008 12:12 AM | |
Threads Similar to: Full cage
| Roll cage??? | flamed 98 gt | 5.0 Mustangs | 25 | February 15th, 2008 05:13 PM |
| roll bar/cage | SWEET2KSTANG | 99-04 | 40 | January 29th, 2008 04:52 AM |
| 05-07 mustang roll cage | Norse1974 | 2005 - 2010 | 6 | April 28th, 2007 01:51 PM |
| what speed do you need a roll cage? | jessy_is_rad | Drag | 12 | April 8th, 2007 02:09 AM |
| When is a roll cage required? | 82GT | 5.0 Mustangs | 24 | January 10th, 2007 09:25 AM |
