LinkBack (1) | Thread Tools |
#1
Whipple issue
Hello everyone! I have a near stock manual 2007 Mustang GT that has a whipple HO I had the dealership install around 5-6 months ago. If any of you have experience with superchargers I would greatly appreciate your help. I am having an issue with accelerating and I'll try my best to describe it. Around 2 to 3 seconds, after starting out in first gear, my car seems to lose power and sputter out for a about a second, then the power will kick back in and it will throw my car forward again and run smoothly. Kind of like a whiplash reaction. This also happens when I downshift from 4th to 3rd gear on a roll. Mind you that this only happens when I'm actually putting the pedal to the floor and getting on it a little bit. The only thing that comes to my mind is that I am not getting enough gas to sustain the power, but the HO kit came with dual GT500 fuel pumps so I don't see why this would be the issue. Any thoughts?????
Silver '07 GT 5spd
<dealer installed Whipple.
My stock fuel pump went out at around 5K miles, had much the same issues as you are describing. F-ked up my plugs too, and they ain't cheap (zero heat range, like $145 a set). Stealership wanted me to cover them, claimed plugs weren't a warranty item. I pushed on the premis that if my warrantied fuel pump hadn't petered out then the plugs wouldn't have been cratered. Final score: me 1, stealership 0.
FI FTMFW!!! 445rwhp, 426rwtq If you're in a fair fight, your tactics suck. |
2005 Mustang GT
10.32@137.70
sounds like a fuel issue, how many miles on car? When was fuel filter changed last? Might be fouled plugs or a dead spot in the tune
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system 326 cubic inches of Twin Turbocharged hell will be running soonTuned by Wes @ TPS ![]() |
sounds like a fuel issue to me as well...have ford check the fuel system wiring.
![]() Under Construction |
1997 Mustang GT
13.56@102.94
![]() iTrader: 1 reviews
Sounds like a fuel system problem. I'd stop driving it hard until I got it fixed as not to damage the motor. Boost + lean condition = damage!
![]() 1997 Mustang GT Aluminum Block PI swap & 4R70W to TR3550 swapped. Best 1/8: 2.04 60ft 8.74@81.85 & Best 1/4: 2.045 60ft 13.56@102.94 all on stock 245-17's My Garage |
could be bad gas... mine was acting like that and I filled it up with BP 92 and it cleared it up
![]() 2.6l KENNE BELL 298 Stroker, Ported heads Pro Motion Built 3650/McLeod RST/ MGW Short Throw Long tube/O/R X /Borla Touring 8 rib/65 lb injectors/GT500 twin fuel ET Drag Slicks/3.73 gear Detroit Truetrac /CDC AGR Spoiler |
Thanks for your replies. The car has around 4500 miles on it. As for the gas, I have been strictly filling it up with 93 octane ever since the whipple was bolted on. I'm going to take it to the shop tomorrow and see what they can come up with.
let us know what the dealership
finds
2006 Mustang GT Whipple HO FRPP Hot Rod Cams |
Sometimes you will get bad gas regardless of it being 93 octane every time...go through a few more tanks of 93 from Shell, BP, or Exxon and see if the problem persists. If it does, then take it in...just DO NOT drive it too hard
Smelly Fists, Socking Cocks
Millenium Falcon
I've been noticing if i shop at name brand gas stations, my tank tends to go to 250 instead of 220, same driving conditions.
Your Mom's Favorite
2007 Mustang GT
Eats Chevys, Shits Imports...
What's your A/F ratio at WOT?
http://www.moddedmustangs.com/forums...p-vote-me.html ![]() TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER) MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER TRUNK MONKEY CREW FOUNDER |
06 GT with bolt ons
I sucked
Maybe a tune issue?
Kyle Busch Haters Club!! Member Uno! Tony wrote "Blowers blow, turbos suck, and nitrous rules!!! lol " Borla cattless L/T's topped with Flowmasters , Roush short throw, JLT2 CAI w/ X-CAL2 from Brenspeed, Bullit 18X9 and 18X10 deep dish. |
my guess it could be a tune issue.
but also check everything on the fuel system, check to make sure that the dealer installed both Fuel Pump Drive Modules since 2 come with the kit. have you had this problem since you installed the whipple or did it start happening just recently? |
gap em to .36
May 08 ROTM
2008 Audi S6
I hope your kidding qwik??? you maybe missing a digit??
On a blower set up we should be starting at .032 if there is blow out reduce the gap in .002 increments until blow out is gone. High boost applications can be as low as .021-.022 |
haha not kidding go ahead and gap them to .36.. see how many times the piston can hit the spark plug.... oh wait they are strapped. damn ford motors
yes i missed a digit Last edited by qwik48r; May 5th, 2008 at 11:19 AM. |
MM's resident Juice head
07 Mustang GT
I have a couple that are strapless
speaking of gapping not to thread jack but does the gap hold true for nitrous app.? My tuner gapped mine to .045
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
May 08 ROTM
2008 Audi S6
Seems a bit open, but you said everything was working okay, just keep an eye things when you spray. Any sign of a missfire, and get out of it. Gap down as needed.
07 Mustang GT
cool i check my trouble codes after almost all my nitrous hits with my tuner to check for misfire codes...then at the end of the night I pull at least 2 or 3 random plugs...its the price i pay...
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/69317-whipple-issue.html
| Whipple issue | This thread | Refback | May 3rd, 2008 09:48 PM | |
Threads Similar to: Whipple issue
| Whipple | usafimj | 2005 - 2010 | 16 | December 26th, 2007 06:27 PM |
| 3.4L Whipple on a 3V! | KBpowered05GT | 2005 - 2010 | 16 | November 14th, 2007 12:36 PM |
| KB vs Whipple | 00GT | 99-04 | 15 | September 13th, 2007 11:19 AM |
| whipple is in just about done | spkb25 | 2005 - 2010 | 12 | April 4th, 2007 08:41 AM |
| 03 whipple | pack01 8 | Multimedia | 0 | August 31st, 2006 12:54 AM |
